Twisted Customs/Spidertrax complete 609 F&R axle packages - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > Vendor's Marketplace > Axles/Tires/Wheels
Old 10-17-2007, 10:21 PM   #1 (permalink)
Brian E's Avatar
Member # 3632
For those of you that have not see the article featuring our custom build axles using Spidertrax parts, here you go.
http://www.pirate4x4.com/tech/harry/...toms/index.php
Because we have had tons of interest, we are going to offer complete F&R 609 axle packages. These axles are assembled with the best of everything, absolutely nothing spared. These are exactly the same axles we have put into many different WEROCK and XRRA competition vehicles with outstanding results. You will see they are still very reasonably priced.
The package will start at $13,750.00 for both axles, and will include:
-Spidertrax .25" wall Spider 9 housings. (can be upgraded to 3/8" wall)
-Spidertrax Ultimate 60 knuckles.
-True Hi9 diff's with Detroits, your choice of ratio, 2nd load bolt on the rear, and solid spacers F&R. (can be upgraded to ARB or spool)
-4 brand new F-450 unit bearings machined to your choice of 5x5.5, 6x5.5, 8x6.5, or Super Duty metric 8 lug.
-Rear full floater setup.
-Spidertrax 14" disk brakes all around, with Willwood calipers.
-Spidertrax 4340 Ultimate 60 front axle shafts.
-CTM D60 joints.
-Spidertrax 4340 double splined rear full floater shafts.
-2 pairs of drive flanges
-Twisted Customs fabricated steering arms.
-Twisted Customs .3125"wall DOM tie-rod w/ Heims.
-These axles will be fully assembled using our alignment bar, caster and pinion angle set, and fully welded.
-You will have your choice of width and pinion offset.
-These axles will allow for about 50 degrees of turn depending on your chassis. If you are looking for 60 degrees of steering we can do that as well. Give me a call to discuss those options.
-These axles will have NO link brackets. The housings are all plate steel and very easy for you to build your own link mounts.
-Please allow about 3-4 weeks as all packages will be custom.
-We will be offering this package for about a month.
-Give me a call or email me if you have any questions or need to place an order.
Thanks,
Brian
605-923-7288
info@twistedcustoms.biz
Brian E is offline   Reply With Quote Quick reply to this message
Old 10-18-2007, 04:23 PM   #2 (permalink)
2D EDGE's Avatar
Member # 47600
Wow!!! How about a price on the front only?
Team 2D EDGE would like to thank
as well as pirate4x4!!\
2D EDGE is offline   Reply With Quote Quick reply to this message
Old 10-18-2007, 05:16 PM   #3 (permalink)
LazyDog's Avatar
Member # 25216
Price for rear only
[B][SIZE="4"]#327 Lambert Motorsports[/SIZE][/B]
and
Thanks to our sponsors:
LazyDog is offline   Reply With Quote Quick reply to this message
Old 10-18-2007, 07:47 PM   #4 (permalink)
Brian E's Avatar
Member # 3632
$8500 with all the parts from above that apply to a front axle.
Old 10-18-2007, 07:48 PM   #5 (permalink)
Brian E's Avatar
Member # 3632
Originally Posted by LazyDog View Post
Price for rear only
$5500 with all the parts from above that apply to a rear axle.
Brian
Old 10-18-2007, 09:43 PM   #6 (permalink)
I'm back and watchin
Easy Rick's Avatar
Member # 43607
Wow that is a kick ass deal!
Rick.
KOH racer #554
Huge thanks to our partners:
Trick Toys Fabrication, NITTO Tires, Longfield Super Joints, PSC steering components, Brian Smith
Easy Rick is offline   Reply With Quote Quick reply to this message
Old 10-08-2009, 04:25 AM   #7 (permalink)
Member # 105205
How does this translate in todays dollars?
Save Our Trails, Support Your Local Offroad Park
If you want to see God laugh, show him your plans
Have Cam, Will Travel
nuthinfancy is offline   Reply With Quote Quick reply to this message
Old 01-18-2014, 09:51 AM   #8 (permalink)
Member # 213465
Do you guys do installs?
I have been eying these Front and rear differentials. Looking at 5.71, ARB air Lockers…
MarkDML is offline   Reply With Quote Quick reply to this message
