Dana 60 or 14 bolt disc brake kit $315 shipped - Page 6 - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > Vendor's Marketplace > Axles/Tires/Wheels
Old 01-26-2010, 10:42 AM   #126 (permalink)
Member # 124076
The hell of it is that I've got the RuffStuff Bent D60 caliper brackets, the Chevy 3/4 ton Rotors and front calipers...
I'm concerned that the studs are either going to be too short or the knurl on the studs is going to be too short to hold the rotor to the backside of my hub...
Dejomo is offline   Reply With Quote
Old 01-26-2010, 11:30 AM   #127 (permalink)
GubNi's Avatar
Member # 25927
For some reason I've had several people ask about studs recently. There's no need to change the studs except on semi-float 14 bolt axles.
Dana 60 or 14 bolt disk brake kits $315 shipped --> click here
Dana 70 kits $300 --> click here . . Sterling 10.25 kits $390 --> click here
Dana 60 front 3/4 ton kits $350--> click here
GubNi is offline   Reply With Quote
Old 01-26-2010, 10:33 PM   #128 (permalink)
Member # 146785
Is there a problem or a difference running your kit on a dodge van dana 60 1996 with the offset rear pumpkin? with the abs sensor in the pumpkin
Im not going to use ABS, just stateing what axle i have.
seems to me the brakes would not be effected by the offset pumpkin
Heartburns26 is offline   Reply With Quote
Old 01-27-2010, 06:17 AM   #129 (permalink)
GubNi's Avatar
Member # 25927
No problem - that's in my list of supported axles.
Old 03-03-2010, 06:41 AM   #130 (permalink)
yj92jeep's Avatar
Member # 130962
Got my kit in today Shawn, Top notch stuff!
Thanks for the great service/price
www.doctorwheels.com
Call or PM for the Best prices on RCV axles and ORI struts!
Goat1 Ibex Chassis build
yj92jeep is offline   Reply With Quote
Old 03-08-2010, 06:01 AM   #131 (permalink)
Member # 113594
Interested in one of your kits for a Dana 60. Haveing trouble identifying exactly what 60 I have. BOM appears to be gone. There is a C 32055 part number on the housing. Is there any other way that I can figure out what axle this is and what kit I need?
prox621 is offline   Reply With Quote
Old 03-08-2010, 06:19 AM   #132 (permalink)
GubNi's Avatar
Member # 25927
No other easy way. We might be able to take a good guess based on the bolt pattern of the flange where the backing plate mounts to.
Old 03-09-2010, 01:24 AM   #133 (permalink)
somer1's Avatar
Member # 135958
Just sent you some money for a full set up for 78' ford ff 60 rear.
Build,Break,Repeat,smokin:
somer1 is offline   Reply With Quote
Old 03-12-2010, 12:49 PM   #134 (permalink)
sweetness meatness
southernwonton's Avatar
Member # 120695
how much for the tail end of your list shipped to 34479
grade 8 annodized mounting hardware
new GM rotors
rebuilt GM calipers with steel pistons
semi metallic brake pads
new inner hub seals
caliper pins
rubber flex hoses
banjo bolts with copper washers
anti-rattle clips
southernwonton is offline   Reply With Quote
Old 03-12-2010, 01:40 PM   #135 (permalink)
GubNi's Avatar
Member # 25927
new GM rotors
new inner hub seals
caliper pins
rubber flex hoses
anti-rattle clips
I think you are trying to say no brackets or spacers. If so then that saves $40 so the price would be $275
Old 03-19-2010, 07:51 PM   #136 (permalink)
generalee7's Avatar
Member # 16522
Any ideas if your kit will work on a 70's Ford D60HD? Not exactly sure on the year yet but will get the BOM this weekend.
-Brian
01 4 door Taco- soon to be 3 link on tons with 40's
generalee7 is offline   Reply With Quote
Old 03-20-2010, 05:31 AM   #137 (permalink)
GubNi's Avatar
Member # 25927
Yes, it will work on all Ford 60's.
Old 03-20-2010, 07:22 PM   #138 (permalink)
Member # 35820
Send a message via AIM to Sound_Man
quote on everything but the brackets and spacers
Sound_Man is offline   Reply With Quote
Old 03-21-2010, 11:16 AM   #139 (permalink)
GubNi's Avatar
Member # 25927
That saves $40. $275 shipped
Old 04-09-2010, 06:06 AM   #140 (permalink)
GubNi's Avatar
Member # 25927
btt
Old 04-21-2010, 08:14 AM   #141 (permalink)
Member # 142584
Hey, how much for shipping on the 14 bolt sf 6 lug to 14226?
Thanks!!!
Matty
Matgyver is offline   Reply With Quote
Old 04-21-2010, 10:22 AM   #142 (permalink)
GubNi's Avatar
Member # 25927
Thanks!!!
Matty
Free shipping. Semi-float is $335
Old 04-21-2010, 10:52 AM   #143 (permalink)
Member # 142584
Awesome! Be in touch tomorrow!
Old 05-05-2010, 03:44 PM   #144 (permalink)
Newbie
Member # 157605
Still have any Eldo Calipersleft to go with your kits?
olanchamedic is offline   Reply With Quote
Old 05-06-2010, 05:07 AM   #145 (permalink)
GubNi's Avatar
Member # 25927
Yep.
Old 05-22-2010, 05:51 AM   #146 (permalink)
GubNi's Avatar
Member # 25927
btt
Old 05-25-2010, 08:46 PM   #147 (permalink)
generalee7's Avatar
Member # 16522
Great deal! I will definitely be buying a kit once I find one that fits a D60HD from a 70's Ford. The only difference between that and a regular D60, as far as I can tell, is the axle tubes are 3 1/8" in diameter and the center section has extra webs on it for strength. Any idea if your caliper brackets fit? If not, I'm guessing only slight modification is necessary to open up the center hole a little.
-Brian
Old 05-26-2010, 05:52 AM   #148 (permalink)
GubNi's Avatar
Member # 25927
My ford kit fits that axle.
Old 05-27-2010, 10:34 AM   #149 (permalink)
generalee7's Avatar
Member # 16522
Awesome! Will be ordering soon
-Brian
Old 05-28-2010, 05:13 PM   #150 (permalink)
Member # 84758
ordered
Thanks
1997 Chevy K2500: Vortec 454 with upgrades/5.38 Yukons/Detroit- Soon to be SAS
Smith97_454 is offline   Reply With Quote
