New 14 bolt 5 and 6 lug hubs. - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > Vendor's Marketplace > Axles/Tires/Wheels
Old 12-15-2009, 10:52 AM   #1 (permalink)
Member # 81421
SpynTec is proud to announce new forged 5 and 6 lug hubs for 14 bolt axles.
The 14 bolt hubs were designed and manufactured with input from customers and dealers to design the GM 14 bolt hubs with an improved wheel flange offset, to not only convert to 5 or 6 lug patterns, but to also narrow overall axle width by 2.25 inches.
Features
• Wheel hubs designed for strength and durability.
• Hubs are CNC machined from a forging.
• Utilizes standard components (studs, bearings, seals) readily available at local parts stores.
• These are a Solid Axle Industries product and are not remanufactured OEM Hubs.
Benefits
• Fits GM 14 bolt spindles
• Replaces cast units
• Converts to 5 on 5.5 or 6 on 5.5 wheel pattern
• Reduces axle build cost by eliminating the need to shorten housing.
Note: Axle shaft flange must be turned to fit the wheel over the shaft flange.
$400 per pair. Call us direct or support our dealers.
On a side note, MAC from C&M Performance is offering shafts and flanges for these hubs. I'm sure he'll chime in here.
Your source for every axle building part you need. housings, knuckles, hubs, and spindles.
Check out our complete line of hub conversion kits for Ford, Dodge, and Jeeps.
888.290.AXLE
234.759.3105
Solid Axle is offline   Reply With Quote Quick reply to this message
Old 12-15-2009, 06:08 PM   #2 (permalink)
jpcrawleram's Avatar
Member # 18734
Very sweet boys! Glad were doing business with you! Nice option to add!
LetzRoll Offroad / LetzRoll offroad Racing 4493
480 797-0469
All your Hardcore Crawling / Racing needs!
PSC Motorsports, 4340 Axle shafts (many brands) Custom or factory, Gears, Lockers, Yukon gear and axle, Reid racing, Advance Adapters, TeraFlex, Ballistic Fab, RuffStuff, 7075 t-6 links, Custom axles, 9'' 3rd members, Mads Smarty, Solid (spintec), Rock Krawler, Artec Industries, ADS racing shocks, Rugged Radios
jpcrawleram is offline   Reply With Quote Quick reply to this message
Old 12-16-2009, 11:24 AM   #3 (permalink)
Wilson's Avatar
Member # 7233
Man, I wish you'd posted this a week ago Would have allowed me to keep the walkers and not order new wheels. I still may depnding on the following questions...
1. Is the offset you are describing comparable to the dually hubs? I'm desiring a 63" WMS, with a single wheel housing. Using factory stuff, this is done by using dually hubs.
2. Are these in stock and ready to ship?
3. I assume, but want to verify that these will accept stock shafts?
Old 12-16-2009, 12:17 PM   #4 (permalink)
Member # 81421
1. Measured from the face. SRW are 1.81, DRW are 3.85, these are 3.00
2. Of course
3. Yes, but you will have to turn your shaft flange to get the wheel pilot over the flange.
Let me know if you have any more questions.
Matt
888.290.AXLE
234.759.3105
Old 12-16-2009, 12:57 PM   #5 (permalink)
Member # 9233
Will be ordering sometime after the new year.
Thanks
woods is offline   Reply With Quote Quick reply to this message
Old 12-18-2009, 12:04 PM   #6 (permalink)
Member # 81421
Thanks
Sounds good.
888.290.AXLE
234.759.3105
Old 12-21-2009, 05:19 AM   #7 (permalink)
Member # 100847
Hallelujah! I've been doing websearches off and on for a few months trying to track someone down to do this. Questions:
1) Maximum axle size - 35 spline?
2) Bearing and seal sizes - stock?
3) Recommend anyone for 35 spline side gears or lockers?
Need to go back and figure out measurements compared to front axle - but this should be perfect. Can save my Walkers!
sputnik40 is offline   Reply With Quote Quick reply to this message
Old 12-21-2009, 01:04 PM   #8 (permalink)
Member # 81421
The hubs are for common 30 spline 14 bolt shafts which come out to right around 1.5 inches.
These use all stock bearings and races.
888.290.AXLE
234.759.3105
Old 12-29-2009, 09:05 PM   #9 (permalink)
Member # 18734
Will have my set Tomorrow and bouncing off them this weekend.
Thanks Matt / Solid for putting out SOLID products for us to use!
Keep posted for some pics of them being installed on one of our buggys
480 797-0469
Old 12-30-2009, 07:45 PM   #10 (permalink)
MerMan's Avatar
Member # 106428
Send a message via Yahoo to MerMan
NICE!
AZ Undertakers
BALLISTIC FABRICATION
JM Rigging Supply
Sparks Transmission
Trail-Gear
ADS SHOCKS
Bent Fabrication
BRANIK MOTORSPORTS
RAD Designs Products
MerMan is offline   Reply With Quote Quick reply to this message
Old 01-03-2010, 02:26 PM   #11 (permalink)
Member # 18734
These things came together perfect. Will post up build / pics this week
Thanks guys!
480 797-0469
Old 01-03-2010, 03:47 PM   #12 (permalink)
Member # 98165
Any chance in getting these in 8 lug?
FJ40Nightcrawler is offline   Reply With Quote Quick reply to this message
Old 01-05-2010, 09:40 AM   #13 (permalink)
SPLIT PEA's Avatar
Member # 15764
I ordered a pair today, 6 lug, Iam going to build a 14 bolt, Thanks Solid Axle, and Spyn Tec.
Half Wacked FJ40, Dana60&14bolt, BigBlockChevy292,Dual Fuel, 465,Atlas,488s,Spool,ARB,40s,& ExoCage,
SPLIT PEA is offline   Reply With Quote Quick reply to this message
Old 01-05-2010, 10:10 AM   #14 (permalink)
Moderator
geberhard's Avatar
Member # 5861
Wow! Awesome product. Two of my buddies shoudl be jumping on this as it will make going 14 bolt in the rear a no brainer and save them the $ and hassle of changing wheels, etc. Killer product idea.
geberhard is offline   Reply With Quote Quick reply to this message
Old 01-15-2010, 09:15 PM   #15 (permalink)
gtxracer's Avatar
Member # 25303
Do these fit an Eaton rear end? Specifically the ho72?
97 TJ 4500 wannabe Build Thread:
Instagram: @DukeEngineeringSolutions
Builds, Swaps, Axles, Engines, Turbos, Diesels, Suspensions, Fab, and more!
gtxracer is offline   Reply With Quote Quick reply to this message
Old 03-26-2010, 09:34 AM   #16 (permalink)
Member # 81421
PM's sent.
Matt
888.290.AXLE
234.759.3105
Old 07-16-2013, 08:53 PM   #17 (permalink)
Member # 135403
sick ill be calling you guys
Birdman69 is offline   Reply With Quote Quick reply to this message
Old 07-17-2013, 09:09 AM   #18 (permalink)
Moderator
geberhard's Avatar
Member # 5861
Any plans for a 5 on 4.75 (120mm?) Thanks!
Old 01-11-2014, 10:35 AM   #19 (permalink)
Member # 208027
x2 on this?
godgunplay4 is offline   Reply With Quote Quick reply to this message
