HEMTT wheel to 6 lug adapter plates. - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > Vendor's Marketplace > Axles/Tires/Wheels
Old 03-12-2010, 03:53 PM   #1 (permalink)
Member # 156145
I'm pleased to offer adapter plates for using HEMTT 20" rims on a 6 lug Rockwell bolt pattern.
I am a Military vehicle enthusiast and Veteran who happens to own a Manufacturing company based in Michigan.
My plates are 1/2" steel, and the outer holes are sized to accept the outer studs. This allows you to mount the wheel with the plate to the hub.
They come chamfered on both sides
I'm selling them for $130.00 each plus shipping..
13 MIKE is offline   Reply With Quote Quick reply to this message
Old 03-12-2010, 03:57 PM   #2 (permalink)
angryblack's Avatar
Member # 142394
Now thats how you come to pirate..with real hardcore parts.
Maintenance clerk wanted for fulltime work in Food manufacturing. It's a clean refridgerated enviroment usually at 34-40 degrees.
The plant is located in the nj 07004 area. PM me for details.
angryblack is offline   Reply With Quote Quick reply to this message
Old 03-12-2010, 06:13 PM   #3 (permalink)
'97 V8's Avatar
Member # 73452
i bought a set and will hopefully have pictures up of these next week. I'm stoked!
01 XJ 60/14 C/O's...in progress
'97 V8 is offline   Reply With Quote Quick reply to this message
Old 03-13-2010, 11:15 AM   #4 (permalink)
Member # 156145
Here are a few pics showing the wheel assembled with the plate behind. This keeps the tire, and wheel from sitting too far inboard.
Old 03-17-2010, 06:45 PM   #5 (permalink)
Member # 156145
I still have some left from the first batch.
Old 04-07-2010, 12:35 PM   #6 (permalink)
Member # 21704
Price shipped to 67010 for 5. Thanks PM is fine
legend in my own mind
"bigger on the internet"
pendy is offline   Reply With Quote Quick reply to this message
Old 04-07-2010, 08:42 PM   #7 (permalink)
Member # 156145
PM sent.
Old 04-27-2010, 08:12 PM   #8 (permalink)
Member # 156145
Still have some plates available.
Old 04-27-2010, 10:03 PM   #9 (permalink)
Toploader's Avatar
Member # 16737
Hey Mike, whats the backspacing with your plate? Thanks in advance.
All my shits heavy.
Sierra Rock Crawlers
Toploader is offline   Reply With Quote Quick reply to this message
Old 04-28-2010, 11:58 AM   #10 (permalink)
Member # 156145
The spacing is 8.375 with the plate mounted to the inside of rim. 9.125 when mounted to the outside.
Old 04-30-2010, 08:58 PM   #11 (permalink)
Member # 159387
adapter plates
Will be ordering some in the future , thanks for making them . Would you consider also making something comparable for the M-715 Kaiser Jeep ,6 on 7.25 , with 5.5 center hole . Nothing out there but hack jobs at the present time . If you would e-mail me contact info , thanks .
huevos is offline   Reply With Quote Quick reply to this message
Old 05-01-2010, 05:59 PM   #12 (permalink)
Member # 156145
Sure, i can make what you need Will pm you contact info, thanks.
Old 05-18-2010, 06:26 PM   #13 (permalink)
cumminchevy's Avatar
Member # 112607
price on 4 to 76307
79 chevy k20 on tons cummins 12v nv4500 NP205 4.10gears
cumminchevy is offline   Reply With Quote Quick reply to this message
Old 05-19-2010, 10:57 AM   #14 (permalink)
Member # 156216
I'm running into issues finding some stout wheels to run my 20" military tires on my 1 ton axles. Are these available in 8x6.5, and if they were, what would the backspacing be? I have a leaf spring front suspension so I'm looking for something in the 4.5" range and it doesn't seem like that would be possible here.
hasteranger is offline   Reply With Quote Quick reply to this message
Old 05-26-2010, 06:28 AM   #15 (permalink)
2005grayduramax's Avatar
Member # 142876
im looking for the same thing as hasteranger
2005grayduramax is offline   Reply With Quote Quick reply to this message
Old 05-26-2010, 08:37 AM   #16 (permalink)
Member # 156145
Backspacing would remain the same. You would have to run a wheel spacer.
As far as a different lug pattern, no problem. I just need EXACTLY what you want, lug pattern, hub clearance, size of lug hole. The more i have to make the cheaper it will be.
Mike
Old 05-26-2010, 11:30 AM   #17 (permalink)
Member # 130484
Price on 4 shipped to 98596. Thanks
52 Willy's Wagon
TBI 350, NP 435, Jed's 203-205 doubler,NWF Cable Shifter, HP Dana 60 Front/spooled, FF 14 Bolt Rear/Detriot, 5.13 gears, Full Hydro, One Link Front and Rear w/ 2.5 x 18" SAW's 39.5 Boggers on DIY Beadlocks
wikedwillys is offline   Reply With Quote Quick reply to this message
Old 05-27-2010, 12:33 PM   #18 (permalink)
Member # 7976
Price please
4 X 98391
imjustdave is offline   Reply With Quote Quick reply to this message
Old 06-02-2010, 09:06 PM   #19 (permalink)
jackstand hero
bigjeep85's Avatar
Member # 65233
price on 2 shipped to 41747 thanks
2006 Jeep LJ
bigjeep85 is offline   Reply With Quote Quick reply to this message
Old 06-18-2010, 02:05 PM   #20 (permalink)
Member # 135987
I just got a set from Mike. High quality stuff. Quick to respond and great to deal with.
andersgc is offline   Reply With Quote Quick reply to this message
Old 07-13-2010, 06:34 PM   #21 (permalink)
Member # 156145
Friendly bump.
Old 11-12-2010, 06:02 PM   #22 (permalink)
Member # 61284
Mike could you make me a set of center plates for the hemmt wheel in a 8 on 225mm lug patern
Thanks Chris
McMahan is offline   Reply With Quote Quick reply to this message
Old 11-12-2010, 06:43 PM   #23 (permalink)
Member # 156145
Will be out of the shop for a week or two. I'll PM you my number when i get back.
Old 11-13-2010, 12:36 PM   #24 (permalink)
Member # 7976
Thanks Chris
What axle are you using McMahan?
Old 11-29-2010, 09:07 AM   #25 (permalink)
Member # 171824
price for 4 plates to 78613 ? thanks
05cummins is offline   Reply With Quote Quick reply to this message
