Gears, axles, lockers, carriers, spider gears, lsd units, yokes, overhaul kits, 3rd's - Page 6 - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > Vendor's Marketplace > Axles/Tires/Wheels
Old 06-11-2012, 11:10 PM   #126 (permalink)
Newbie
drawls's Avatar
Member # 101124
I need 4.56 thick cut gear set for a 14bolt. Shipped to 97471
drawls is offline   Reply With Quote
Old 06-12-2012, 05:11 AM   #127 (permalink)
684FRO's Avatar
Member # 63393
looking for a ARB RD-21 "cylinder cap" P/N ARB-030503. It is the side of the differential housing that holds the thin carrier bearing and the air inlet seal housing.
let me know if you have anything. thanks
-Just another Jeep- 40" mtrs, 60's, 5.38's, 3/4 link, F.O.A.'s, AtlasII , 105"wb .
684FRO is offline   Reply With Quote
Old 06-12-2012, 09:28 AM   #128 (permalink)
75PPE's Avatar
Member # 63318
Looking for a price on an Eaton limited slip for a 72 Chevy truck 12 bolt. I'll need a master install kit as well. Shipped to 45385
75PPE is online now   Reply With Quote
Old 06-29-2012, 03:27 PM   #129 (permalink)
Member # 154464
New shipment of finned aluminum diff covers!! Aam11.5, f10.25/f10.5!
New Nitro Aluminum Finned Differential Covers.
-Made in USA
-Powder Coated high strength aluminum
-Finned for heat dissipation
-Added capacity
-Drain and fill holes for easy service
-Many popular applications including all late model Ford, Chevy, Dodge ¾ & 1 ton pickups.
-Increases rear end life in heavy towing applications.
JTS DIFFS is offline   Reply With Quote
Old 07-02-2012, 03:48 PM   #130 (permalink)
Member # 127899
Locker Compare for Dana 60, 35 spline, 5.38s (chevy, front)
shipped to 95628
Yukon Zip Competition, & ARB
Do you have the Yukon 5.38 Ring & Pinion in stock too?
Thanks!
-SuperSmurf
75 cj5 118": 14 bolt detr, d60 RCV ARB, 5.38s, sm420, Dana 300 4:1, 350 tbi, 40s
supersmurf is offline   Reply With Quote
Old 07-03-2012, 03:33 AM   #131 (permalink)
ewalls's Avatar
Member # 86873
Ford 8.8 5.13 gears to 95237 thanks!
94 yj, front hp44 with detroit and 4:88 gears, klune 2:7.1 mated to a NV241OR rock trac 4.1 t-case, Rear ford 8.8 arb locked with 4:88's, soa stretched with xj leafs in the rear and wagoneers up front. 103 wheelbase. Sitting on 38 geolandar m/t's
ewalls is offline   Reply With Quote
Old 07-13-2012, 10:16 PM   #132 (permalink)
bbc
Member # 150283
truetrac 913A586
to 55364
bbc is offline   Reply With Quote
Old 07-23-2012, 06:28 PM   #133 (permalink)
Member # 28449
Looking for price on an ARB for a Toyota 8" V6 shipped to 66053. Thanks.
92 Runner..... 37's, geared, locked, yada
Lifted94XLT is offline   Reply With Quote
Old 08-07-2012, 09:03 PM   #134 (permalink)
Member # 204778
Quote for dana 60 5.38 gears front and rear, 35 spline rear spool, front carrier with spider gears, 2 master install kits. BOM for front axle is 603643, rear BOM 605224. Shipped to 99567.
bax89 is offline   Reply With Quote
Old 08-09-2012, 05:57 AM   #135 (permalink)
Member # 123855
Send a message via AIM to ChemicalToilet
Looking for prices on a set of chromemoly axles for a Dana 44.
77 wagoneer pass side (short) 30 spline
77 ford f150 pass side (long) 30 spline
19 spline outers
Priceswith spicer joints and whatever aftermarket joint (alloy usa super joint, etc...)
Shipped to 07032
Sent from my ADR6400L using Tapatalk 2
You stink and I don't like you.
ChemicalToilet is offline   Reply With Quote
Old 08-11-2012, 11:22 AM   #136 (permalink)
ONEtonXJ's Avatar
Member # 145633
lookin to set up both of my axles with ARB's... they are out of a '86 Chevy K30 pickup, dana 60 front, 70hd rear.
i believe the numbers i need are RD166 for the front and RD53 for the rear.. i'll be setting up 6.17 gears in both as well
ALSO... if you deal with G2 shafts..... i need ONLY the short side inner shaft and 1 outer shaft for the front 60..
shipping to 81501 as well to please..
thanks, Nate
"Tater2" - '91 2 door XJ. 4.0, AW4, 231/300 doubler, GM 60/70HD, 6.17s, ARB's & 4Ds
ONEtonXJ is offline   Reply With Quote
Old 08-12-2012, 04:52 PM   #137 (permalink)
trailworthyxj's Avatar
Member # 50718
Pair of dana 60FF 30 spline 4340 shafts 37-39.5" length shipped to 29646, thanks
Old: 01 Ram 1500 locked dana 60s, 5.38 gears, 40" MTRs- SOLD :(
New: 98 TJ, 4.0, ax15, 4.10s, 33s
trailworthyxj is offline   Reply With Quote
Old 08-26-2012, 07:20 AM   #138 (permalink)
Newbie
BigChevy644's Avatar
Member # 214554
Lookin for 4.10 gears for AAM 11.5" 14 bolt and master install shipped to 57701. Thank you.
BigChevy644 is offline   Reply With Quote
Old 08-31-2012, 09:12 AM   #139 (permalink)
Member # 104429
I need a price for a D30 ox locker 3.73 & up
"ROADS? Where we're going, we don't need roads!"
YJFANATIC is offline   Reply With Quote
Old 09-02-2012, 11:37 AM   #140 (permalink)
Newbie
Member # 82652
Need master install kit and kingpin rebuild kit and ox locker for 4.88 geared Ford kingpin axle (90's).
allsjeeps is offline   Reply With Quote
Old 10-10-2012, 03:02 PM   #141 (permalink)
Member # 141845
915A550 Sterling 10.5 Truetrac shipped to 48326
emev0l is offline   Reply With Quote
Old 10-11-2012, 07:25 AM   #142 (permalink)
camarokid94's Avatar
Member # 45239
need price of 5.29 nitro gear for v6 toyota 8in to 66502
02 2500HD 6L tow rig
2010 GMC grilled 4 seat buggy 6.0LQ4 th400 203/205 60/14 42icants 114Wb
240hp kids buggy
http://www.pirate4x4.com/forum/gener...ids-buggy.html
www.KJMmotorsports.com
camarokid94 is offline   Reply With Quote
Old 10-14-2012, 11:01 AM   #143 (permalink)
ONEtonXJ's Avatar
Member # 145633
i need some individual parts for an RD167 and an RD53.... can ya help?
specifically, need an air delivery housing, o rings and the cylinder cap for the 53..
then just the air delivery housing for the 167
Old 10-18-2012, 05:58 PM   #144 (permalink)
MNorby's Avatar
Member # 11448
Send a message via Yahoo to MNorby
Price on 5.38 reverse rotation thick dana 60 gears to 82435 please.
MNorby is offline   Reply With Quote
Old 11-12-2012, 05:05 PM   #145 (permalink)
caddyman's Avatar
Member # 155423
I need a quote for;
RD167, Ford Dana 60 HP, KP- 5.13 gear set, Master Overhaul kit
RD114, 14 Bolt GM-5.13 gear set, Master Overhaul kit
shipping? 92592
Thanks
caddyman is offline   Reply With Quote
Old 11-18-2012, 02:23 PM   #146 (permalink)
caddyman's Avatar
Member # 155423
Originally Posted by caddyman View Post
I need a quote for;
shipping? 92592
Thanks
FYI
No need to get back to me at this point, I already ordered everything from someone else!
Old 11-18-2012, 02:34 PM   #147 (permalink)
yjfab's Avatar
Member # 231696
need quot for waggy 44 front thick 4.88 and locker shiped to 93555
yjfab is offline   Reply With Quote
Old 12-17-2012, 10:57 AM   #148 (permalink)
Member # 190778
Can I get a quote for 14 bolt 10.50" 5.38 gears, 14 bolt 30 spline ARB & 14 bolt ARB 30 spline detroit shipped to 80022?
Thanks!!!
jdavidson is offline   Reply With Quote
Old 01-14-2013, 09:14 AM   #149 (permalink)
Member # 197853
Need a quote for ARB RD117 shipped to 20141.
frAnken_ruBi is offline   Reply With Quote
Old 01-16-2013, 10:29 AM   #150 (permalink)
Member # 81049
Quote please
I need ring and pinion for a 1990 ford dana 60 high pinion front, and a minor install for that axle, and a ff gm 14 bolt please. include shipping to 97338 please.
Thanks. Prob usa if thats your less expensive gears.
onebadonefifty is offline   Reply With Quote
