#176 (permalink) | ||
we can go that way
Member # 85972
thanks for finding this, and thanks for the interest!Quote:
i understand there may be some minor issues with tollerances in these, but over time i can make adjustments/improvements with help from your feedback. thanks for all your support, i really appreciate it! ![]() and yes, the ruffstuff housings are sexy and strong, i have one going under my rig soon, just trying to find the time! lol.
FJ80 HIGH STEER KITS /forum/axles-tires-wheels/997804-fj80-high-steer-way-you-need.html Authorized ruffstuff dealer- pm me for pirate discount and free shipping! pm me for affordable built toyota 3rd members or parts! ADS racing shocks- i can save you money on those too! |
#177 (permalink) | |
Interesting, I've never seen anyone run dual calipers. Have you done this before? The reason there are caliper mounts on both sides of the 6-shooters is to make them universal, no right or left side knuckles, the same casting fits both sides. I think that I even mentioned this to Billy early in his process. |
#178 (permalink) | ||
Member # 13584
Reduce manufacturing costs, with only needing to make one casting Reduce the number of spares I have to carry, so a single spare knuckle can repair either side. I can run twin calipers for super duper braking power. I have exactly three 6 shooters on my shelf that I will gladly put out in the next garage sale in favour of these. The extra ears would make them perfect for me, so I can order three knuckles and four calipers! |
#179 (permalink) | ||
Member # 63534
Dallas
85 toy, locked, duals, 38's and running on pane tow rig: 93 W250 cummins 5 speed Quote:
#180 (permalink) |
Member # 136778
How was koh? These knuckles and ruff stuff housings are going to be very popular in the ultra 4 world I think.
Billybob is the ruff stuff axle your using a 8 inch ring gear or 9.5?
facebook.com/pages/Zukijames/152521404841727 toyotav8.com hellfirefabworks.com |
#181 (permalink) | |
This is my first time setting up links too, and while it is seemingly daunting its not as bad as you think. Definitely takes more time for a newb, but I'm being slow and methodical and did a ton of reading and such to get ready. There are a couple threads on Pirate that are worth looking at that are all linked in the Toyota Bible thread and if you search. I would say the only two things I can recommend is that its worth taking your time and doing it right, and to use brackets that allow for adjustment wherever you can. I'm taking my own advice and I have a feeling I will be happy to have the ability to make changes without having to cut brackets off and such. Billy can get you a decent deal on anything Ruffstuff, and so far the Ruffstuff brackets and heims are doing a great job for me. I do wish they made a FJ80 specific Truss, as I had to spend a few hours modifying the FJ40/60 one to fit (most specifically that it didn't provide a wide enough platform to mount the links wide enough). Otherwise, no complaints and seems to be top notch, well designed and thought out stuff. I have my axle all painted up and the upper link mount tacked on. Once I have the frame cleaned up a bit I'll have the lower link mounts tacked on and will do some bind testing and will have some more interesting pictures to look at. Should be there by the end of the week, but we'll see.
Come check out www.ColoradoTrailRats.org ...Colorado's Newest 4x4 forum |
#182 (permalink) | |
That was the main issue I had with tolerances. I do know that it would be slightly easier if it was a tight slip fit like the Toyota caps are, since you could drop it in from the top before bolt the the arms on, but its not that bad. The only other spot I had to clearance a bit was one of the holes from the preload need a tiny bit of work with a carbide burr because one of the threaded holes was restricting the preload slug. Nothing big and nothing I wouldn't expect from a custom casting but if you are QCing its something to check maybe. Like I said above....I'll be posting pictures as things progress. The more I work with these the more I think I made the right choice. More importantly, your thought process shines through in the design and I have zero worries about these lasting a lifetime and providing a very strong basis to build my rig off of.
Come check out www.ColoradoTrailRats.org ...Colorado's Newest 4x4 forum Last edited by Electric-Mayhem; 02-15-2012 at 12:48 AM. |
#184 (permalink) |
plasma dust huffer
did anyone run a set of these knuckles on a rig in KOH? im wondering how well an axles with these would hold up to that kind of abuse vs. a d-60 with aftermarket knuckles or something of the likes.
Duramax and LS based motor tuning Offering in House Custom CNC Plasma cutting services, we can take your idea from design to your doorstep. have a sketch you want to become parts for your project? pm me, i can help. parts are shipping out daily "it makes the mach5 look like a vagina" - ARCHER |
#185 (permalink) | ||
Member # 63534
#186 (permalink) | |
Member # 136778
if things go good i would like to make it to the lcq and see how my little zuk does
#187 (permalink) | |
we can go that way
Member # 85972
not yet. but the big dogs with 400hp+ and 5,000lb cars probably aren't interested in toyota axles. some of the strongest parts available get destroyed in that race, i would think the best yota axle ever built could suffer some damage if under one of those fast heavy cars.
FJ80 HIGH STEER KITS http://www.pirate4x4.com/forum/showthread.php?t=997804 Authorized ruffstuff dealer- pm me for pirate discount and free shipping! pm me for affordable built toyota 3rd members or parts! ADS racing shocks- i can save you money on those too! |
#188 (permalink) |
Member # 136778
i think a 400 horse light rig could benifit from toyota axles..
those big heavy rigs are spending thousands trying to get strong light parts.. front and rear ruff stuff fj80 axles weigh the same as a front dana 60! if you run a stock 80 series you save even more weight.. the thing is 400 horse is lowend for koh.. i have 300 maybe just a hair over.. and will be running a 35 hp shot of nitrous.. or 70 not sure yet.. i will let everyone know how things are holding up once i get everything put together
#189 (permalink) | |
we can go that way
Member # 85972
![]() but the nitrous, that may not be beneficial in a race like KOH. on a 10 second hillclimb, sure. or if you just need to pass. looking forward to seeing you in action with the new set-up.
#190 (permalink) |
Member # 136778
i think it could be quite beneficial for a pass or to keep in the power and not have to down shift half way up a hill ... and probably a little shot here and there out of the corners to help my little 4.0 get up to speed..
but i can see how if you got to happy with it it could ruin a day fast im pretty excited about the new set up too.. the old one i was always worried something was going to blow up . this set up will be alot more reliable and hopefully hold up to some serious abuse!
#191 (permalink) |
Member # 189940
I dont suppose anyone has a set of these knuckles they would be willing to onsell?
i need a set for a comp in 4 weeks and seeing what backup plan may be out there.
FJ40 - V8, Coils, Dual cases, 42" TSLs |
#192 (permalink) |
we can go that way
Member # 85972
if grant doesn't hand over the set that was coming back to me, i'll be willing to send you my personal set next week. this means my rig will be down longer, but you'll hopefully be able to get yours ready for your comp.
#193 (permalink) | |
Member # 136778
anyword on when the batch will be done?
#194 (permalink) |
Member # 189940
billy that is the best customer service i have heard of.
thanks champion thats unreal and puts my mind at rest. EDIT- From last feedback i will need your personal knuckles mate. Billy if you can sort this out in time i will mention you in my memoires!
FJ40 - V8, Coils, Dual cases, 42" TSLs Last edited by Dirty Rock Star; 02-19-2012 at 03:01 PM. |
#196 (permalink) |
we can go that way
Member # 85972
pm's replied, thanks guys.
#198 (permalink) | |
we can go that way
Member # 85972
for everyone else, these should be ready to ship in a week.
#199 (permalink) |
Member # 189940
The 3rd party still won't hand them over. how annoying.
EDIT: billy still no joy if i cant get access to them by midday wed aussie time can i get a refund as i need to make a move one way or the other?? cheers Twon
FJ40 - V8, Coils, Dual cases, 42" TSLs Last edited by Dirty Rock Star; 03-06-2012 at 01:38 AM. |
#200 (permalink) |
Member # 189940
billy i cannot get a response from the 3rd party which is uncool i wanted to run these at tuff truck next week.
Grant still says he hasnt heard from youto confirm payment??? Ive gotta get my fab guy to make something now. Can you sort me out a refund please if grant wont let me have the knuckles ive paid for. Tony.
