Broncosix bad seller!!! - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > Classifieds > Bad Sellers, Disputes, etc...
Old 04-12-2007, 03:45 PM   #1 (permalink)
Yukon Gear and Axle
waynehartwig's Avatar
Member # 35700
Exclamation Broncosix bad seller!!!
I recently purchase a rear FF D60 from Brian that he claimed to be from a 78-79 Scottsdale PU and ready to run. That thread is here.
When it arrived, it was not ready to run. The pinion seal had been leaking for some time and the pinion was very loose. There were missing wheel studs. There were only 3 mismatched bolts in the diff cover. There were divots in the housing from cutting brackets off and what was left of a truss that was welded to the tubes and pumpkin as well as link and spring pads. Now, after looking at pics of his CJ, I bet this axle was in it prior to the 14 bolt he has now. It looks to have the same truss and 4 link setup.
At that time, I was like oh well... I'm putting 5.13's, ARB, 35 spline axles and Cadi calipers - I made that decision between the time it shipped and arrived, originally my only complaint about this axle was 30 spline, as I was going to run a Detroit and 4.88's. I guess I just have more work in cleaning up than I had anticipated.
So I ordered up the parts, the parts arrived and I started stripping the axle. First thing I noticed was the wheel bearings I recieved would not work in the hubs of this thing. No prob, Randy's must have sent me the wrong ones, so I emailed my salesman with the Timken part numbers (could not find a seal number).
Then I set off to bore the spindles. That's when I realized I was fucked. First I noticed the outer area of the hubs neck down, they aren't straight like a GM would be. The OD of the spindle is 1.75" - HUH!?!?! I go over and measure another D60 I have sitting here, and it's 2"!!! Ok, I think, WTF!?!?!
Then I get an email back from Randy's stating that the only two D60's that they can find that use those bearings are 53-69 F250 or 56-64 Studebaker PU!! After knowing that, it made sense on the axle lengths - as that was what was in a 69 F250!!! But only 16 spline...Making sense on spindle size now, too....
In the past, I was kind of curious about the wierd axle lengths it had (33.75") and the last year they put a D60 in the rear of a GM (not van) was in 72 (according to my Dana BOM book).
So anyway, I got fucked!! I did not receive a ready to run axle, and it definately was not out of a 78-79 Scottsdale!! I want my $950 back and the $315 I paid for shipping. After finally talking to Brian today (been emailing, pming and no response from him or his friend, Jim Clark (Jim Clark Enterprises) that sent me the axle and the one that took my money).
EDIT: I will be satisfied if you send me a (good, unmolested) empty FF D60 housing and hubs to replace this one.
EDIT: If I don't receive my money back soon, I will contact my credit card company and let them deal with this. My wife is also a federal law enforcement officer, so I'll talk it over with her and see what our options are. Since this is an intrastate transfer, it is a federal issue, not local.
Here are quotes of the information proving what I am stating:
Originally Posted by Broncosix View Post
I have a Dana 60 rear axle with 4:88 gears, Detroit Locker, and Disc Brake conversion. Axle is complete and ready to run. It is full width and 30 spline axles. Can ship forward air, $100-150 you pay shipping. Asking $1000.00 Located in Indianapolis, IN
Call 317 385-3277 or 317 753-8889
Thanks
It is leaf spring. And it is 8 lug, Chevy front calipers and the bracket is welded to the housing. As far as the set up goes you can make it anything you want.
[I am not agreeing to ship to your door. The only way I will ship this is Forward Air. You will have to pick up at one of the two Forward Air terminal that I mentioned. I dont know which one is closest to your location. I do not know what the axle came out of. I took it out of a Scottsdale truck 78 or 79. I will have to measure the wheel mounting surface and get back with you. I should get to the shop today sometime.
The $1050.00 get the axle crated and shipped to the nearest Forward Air terminal of your choice.
This axle was pulled from a running and driving truck, in which I sold the engine, trans, t-case and front dana 60.
Let me know,
Brian
OK, we have a deal at $950 and you are responsible for the shipping. I will get a crate built and get it ready to drop at Estes. My buddy can take credit cards at his shop. I did not know how you would like to pay for the axle? If you want to pay via credit card just call Jim Clark at 317 753-8889 he builds transmissions and ships them all over the world. Let me know.
Thanks,
My cell is 317 385-3277 Brian
#4502 "The Rental", Team Yukon Gear and Axle
Good Seller/Buyer List!
www.150Tunes.com
www.DiffsOnly.com
www.Jeeperman.com
10% PIRATE COUPON CODE: pirate4x4
Special thanks to: Yukon Gear and Axle, Pace Oil Field Hauling, AllTech Motorsports, A1 Performance Transmissions and Converters, Randy's Racing Transmissions, Fountain Tire/Goodyear, Warn, Reid Racing, RuffStuff Specialties, BearTrax 4x4 OutFitters, Skinny Pedal Products, DiffsOnly.com, and 150Tunes.com
waynehartwig is offline   Reply With Quote
Old 04-12-2007, 04:30 PM   #2 (permalink)
ih4x4's Avatar
Member # 11362
Send a message via AIM to ih4x4 Send a message via Yahoo to ih4x4
if you are planning on disputing the credit card you may want to get started in that as you have a limited amount of time to dispute the charges 30-45 days,also you will be stuck with the return shipping when you dispute the charge,
82 landcruiser with tbi sbc
ih4x4 is offline   Reply With Quote
Old 04-12-2007, 04:31 PM   #3 (permalink)
Member # 16719
so the next logical thing to have happen here is for broncosix to post that he bought it from kyle greek and was told it was a gm d60 rear. but i give him credit for a skillfully crafted statement "I do not know what the axle came out of. I took it out of a Scottsdale truck 78 or 79." now that his whole deal fell apart, we can recognise the deceit in that statement. so another scammer unveiled-time to pay up.
jdrocks is offline   Reply With Quote
Old 04-12-2007, 04:44 PM   #4 (permalink)
Member # 67907
You paid $950 for a D60 rear? Holy shit!
The Beepster
[url]http://www.pirate4x4.com/forum/showthread.php?t=727456[/url]
Jeepermat is offline   Reply With Quote
Old 04-12-2007, 04:50 PM   #5 (permalink)
payton's Avatar
Member # 11067
Send a message via AIM to payton Send a message via Yahoo to payton
if need be ill swing by and give him a message for ya if need be.
payton
this space for sale
payton is offline   Reply With Quote
Old 04-12-2007, 05:23 PM   #6 (permalink)
Member # 64457
Send a message via Yahoo to crownhilldigger
Cool
payton
He's a little closer than Kyle.
Crownhilldigger
crownhilldigger is offline   Reply With Quote
Old 04-12-2007, 05:42 PM   #7 (permalink)
Yukon Gear and Axle
Member # 35700
Yes, but in all fairness, it was supposed to be ready to run with a Detroit, 4.88's, GM disc conversion, etc. One could easily spend $950 to build a wrecking yard axle with just those items.
I've also looked around here, and I can't find a D60 for sale for less than $400, making this a pretty good deal for me. In fact, I just bought a replacement (for this) from Utah because of that fact.
www.150Tunes.com
www.DiffsOnly.com
www.Jeeperman.com
Old 04-12-2007, 05:43 PM   #8 (permalink)
Yukon Gear and Axle
Member # 35700
True.. But then I'd only be out about $600 instead of $1,200+....
www.150Tunes.com
www.DiffsOnly.com
www.Jeeperman.com
Old 04-12-2007, 05:44 PM   #9 (permalink)
Yukon Gear and Axle
Member # 35700
payton
Sure, tell him and of course to pay up
www.150Tunes.com
www.DiffsOnly.com
www.Jeeperman.com
Old 04-12-2007, 06:47 PM   #10 (permalink)
payton's Avatar
Member # 11067
ready to go for a ride?
do i get a finders fee? haha
this space for sale
Old 04-12-2007, 06:52 PM   #11 (permalink)
Yukon Gear and Axle
Member # 35700
You get my $1200+ back, and I'll give you $200!
www.150Tunes.com
www.DiffsOnly.com
www.Jeeperman.com
Old 04-12-2007, 08:57 PM   #12 (permalink)
Yukon Gear and Axle
Member # 35700
Got to thinking...
I'd be satisfied if he was to send me a useable housing. Of course it has to be FF, with hubs and carrier bearing caps, but it could be empty otherwise (no axles, gears, diff, cover)...
www.150Tunes.com
www.DiffsOnly.com
www.Jeeperman.com
Old 04-13-2007, 01:31 AM   #13 (permalink)
odin544's Avatar
Member # 29622
yeah you could spend 950 building a junkyard axle. but at least you would know what you had in the end. 950 was way too much in my opinion. but back to the issue. where is this fucker at?
odin544 is offline   Reply With Quote
Old 04-13-2007, 07:07 AM   #14 (permalink)
Yukon Gear and Axle
Member # 35700
Not really, as I said in a post just before, the cheapest I could find was about $400 locally. Because of that, I just bought another D60 in Utah that is being shipped up as we speak. This one is from a friend and only cost me an Optima battery (and shipping), so $300?
Here is what he had to say about his location....
sorry, i am in indy, in. i will have to measure wms.
www.150Tunes.com
www.DiffsOnly.com
www.Jeeperman.com
Old 04-13-2007, 02:15 PM   #15 (permalink)
odin544's Avatar
Member # 29622
where is mead? im in SE washington. i know the junkyard here has several 60 rears for 100-150 each. anyways i hope you get your money back.
Old 04-13-2007, 02:19 PM   #16 (permalink)
Yukon Gear and Axle
Member # 35700
Between Spokane and Canada (WAY north/east WA), but not the point.
He fucked me, he knows it, and I never got a kiss, reach around or anything. ...The least he could have done was not mix sand with the KY!
www.150Tunes.com
www.DiffsOnly.com
www.Jeeperman.com
Old 04-13-2007, 06:48 PM   #17 (permalink)
Likes green stuff
DMGunn's Avatar
Member # 77104
Good luck with this. Hope you have an easier time than we are with Kyle Greek, who is a thief, BTW.
Sand in the KY.............ouch.
I agree that $400 is WAY too much for a rear 60. You should have looked harder. I've had a thread here since July '06 selling axles....unmolested rear 60s for $125.
DMGunn is offline   Reply With Quote
Old 04-13-2007, 08:05 PM   #18 (permalink)
Yukon Gear and Axle
Member # 35700
Had I known...
www.150Tunes.com
www.DiffsOnly.com
www.Jeeperman.com
Old 04-14-2007, 05:35 AM   #19 (permalink)
Hanr3's Avatar
Member # 33482
Regardless what he paid for the axle, he was ripped off.
blah blah blah......
Hanr3 is offline   Reply With Quote
Old 04-14-2007, 09:09 AM   #20 (permalink)
Yukon Gear and Axle
Member # 35700
Exactly my point and thought...
www.150Tunes.com
www.DiffsOnly.com
www.Jeeperman.com
Old 04-15-2007, 12:33 AM   #21 (permalink)
Member # 74154
I hate fuck sticks like this guy. I ship axles all over and had one guy pay me and then take his money back (paypal) and not respond to any emails or phone calls so I had it shipped back and had to pay shipping twice (which was double cause I didnt get a discount commin back) very bad people out there. If you need another 60 after this let me know I have about 10 for $125 Thanks Jason Ratcliff
JRATOFFROAD "TheRat" is offline   Reply With Quote
Old 04-15-2007, 08:47 AM   #22 (permalink)
Yukon Gear and Axle
Member # 35700
I agree.. People like this make it difficult to trust anyone.
I think I'm good on the rear 60 now... A friend in Utah sent me one for the cost of a Optima Red.
www.150Tunes.com
www.DiffsOnly.com
www.Jeeperman.com
Old 04-17-2007, 08:40 AM   #23 (permalink)
Yukon Gear and Axle
Member # 35700
Keepin' on top!
www.150Tunes.com
www.DiffsOnly.com
www.Jeeperman.com
Old 04-18-2007, 08:20 AM   #24 (permalink)
Yukon Gear and Axle
Member # 35700
This is obviously not going anywhere, so I'm going to file a fraud alert and open a case with my credit card company.
www.150Tunes.com
www.DiffsOnly.com
www.Jeeperman.com
Old 04-18-2007, 10:26 AM   #25 (permalink)
Yukon Gear and Axle
Member # 35700
Apparently this Jim Clark Enterprises is quite the piece of work... I found this over here.
Originally Posted by caionneach
I found out about Jr Jeep Parts at www.jeep-classifieds.net, and he had a few transmissions for sale. So I researched him. Over all, he turned out OK. A few complained that he was slow in getting a transmission to them, but it wasn't many, and ultimately they received what they paid for. Not me.
So if anyone is in or near Greenwood, Indiana maybe you can help. The owner is Jim Clark, and the business is Jim Clark Enterprises in Greenwood. He has also sold transmissions on eBay, as well as Jeep Classifieds.
I paid for a New Venture 4500 through three PayPal payments, and I have the PayPal transaction numbers. I have corresponded with him through telephone and email, and he usually answered the phone and said he would be getting me the transmission till he quit answering the phone when I called in October of 2006. He had agreed to hold thre transmission for me after I paid for it until I was ready to receive it. I began working on tearing down the 401 last July, so since I had a place to store it, I notified him that I was ready to receive it. I gave him an address to ship the transmission. He has only occasionally answered the phone since then. Paypal won't do anything because of the time duration from the last transaction (must be less than 45 days), and their advice was to contact local law enforcement.
Just for grins I just tried to call him, and he answered the phone!!! So his number is still good. While I was looking up the PayPal transaction numbers he hung up the phone! Not sure what to do at this point other than go to the police.
Kenneth Smith
www.150Tunes.com
www.DiffsOnly.com
www.Jeeperman.com
