Banned
Member # 124890
Custom Component Design and Manufacturing
-From mild to wild
-From Cardboard Templates, Cad files, or just ideas Chances are we can help you with that one component you can't find anywhere else or just don't want to build yourself ![]() to ![]() ![]() to ![]() Custom Panhard Solutions are a very common order ![]() Even been known to help with your school work U of Arizona Baja Car ![]() ![]() Beadlocks are a Common item as well ![]()
#2 (permalink) | |
Member # 67110
I don't need anything built today, but when I do, I know who to call. D |
I've used Ballistic Fabrication's custom manufacturing services for three projects now and all I can say is; WOW, THESE GUYS REALLY HAVE THEIR ACT TOGETHER!
Fast turn around, perfect fit the first time, very affordable. I'll be a return customer for sure.
Baja Bomber, Mega Titan, Teal Brute You can do anything you dare to dream. |
could BF design a 22.5* angles LCA bracket for a 14BFF ... that wraps completely around the axle tube? it would have to be axle tube diameter + 2" (1" larger on either side of the tube) and would obviously have to be 2 piece design ...
im debating on whether or not i want the bracket cut with an elipse or cut straight and then bent ... thought BF crew? |
Cool. I have been kicking around an idea for plating a TJ factory half door with 3/16" plate. I wanted it to be a weld on part that is laser cut to fit around the bolt on hinges, door lock, and door handle. It would be a cool product for you guys to sell also. Is that something you guys could do?
#7 (permalink) | ||
Banned
Member # 124890
#9 (permalink) | |
Member # 135736
SlickRock GOD!
Do you have any plans to make some high quality Hi-Steer arms for the Rockwells? I am sure you could corner the market if you did so! Especially if you make them like you have your Dana 60 arms! That would be a sweet addition to your lineup of steering components and definitely be something I would be looking to get from you!! (maybe even your first set
) I have been bugging you for about a year now for this one ![]() I am not a metallurgist, but would the hi-steer arms be strong enough for Rockwells and 44"+ tire sizes if they were made like the Dana 60 arms pictured above?? Thanks for the consideration and I look forward to your info! Matt
"Team MEGA-REX 6x6x6" ![]() Owner/Designer/Fabricator TWF Double Beadlock wheels, Pitbull Tires Vendor, Raceline Wheels, Marsh Racing Wheels, Custom Splice Winch Rope 37" Tires for $85ea http://pirate4x4.com/forum/showthread.php?t=779576 |
Cool. I had planned on making a template and using the plasma to cut it out but it would never be as sharp as a laser cut. I thought I would throw the idea to you guys in case you thought it would be a good product for you to sell. I am just OK at CAD but I'll see if I can draw it up.
#12 (permalink) | |
Member # 42423
I have actually been modeling up a design for a hy-steer arm for my rockwell, i will pm you(ballistic eng) later with the rough model and maybe we can work something out to get one made for my set up.
1982 K5, with some minor mods. |
#13 (permalink) | |
Banned
Member # 124890
We don't currently have a Rockwell in the shop, but I'm working on getting one back in here. We try to keep all of our inventory moving and that includes our junkyard as well. We can certainly make the part you sent earlier (via Pm), but whether or not it is economical will have to be determined. I'll see what we can come up with in the next few days. |
#16 (permalink) |
Banned
Member # 124890
We've had several requests for AL rock rings and bead locks. We used to sell these for between 100$ - 175$ per wheel from 3/8" AL, and that is on a standard production part. Due to lack of interest we have temporarily discontinued sales on them, however we would be willing to do a large batch, if all the parties interested wanted to make a large group buy in. I know this makes it difficult because you all have different wheels and sizes, but it's the best way to keep your individual costs down if you can work something out. If we see enough interest in AL beadlocks in general we will begin production on 15-17" wheels again possibly. Thanks for the interest.
#17 (permalink) | |
Member # 42423
#19 (permalink) | |
Member # 113944
#20 (permalink) |
Member # 137
Have you guys fitted the D60 rear truss on a D70? Would it be possible to trim the top to fit over the larger pumpkin? Have y'all thought about making a full hydro truss, or a kit, for the front of D60's?
'72 FJ55 http://forum.ih8mud.com/showthread.php?t=76835 '73 FJ40 http://s132.photobucket.com/albums/q...&addtype=local '78 FJ40 '91 Ram W250 5 spd. CTD '93 Ram W350 5 spd. CTD '99 Ram 3500 4X4 5 spd. CTD Welding is like sex, it's all about the penetration! |
#21 (permalink) |
Member # 47337
How about an affordable 8 lug conversion kit for us rockwell guys. Something that will put the WMS to WMS in the 74" or narrower range. Randy O's stuff is perfect but not cheap, and going to the 14b wheel hub does nothing to narrow the width. A wheel hub kit that got the width as narrow as possible, used an alum rotor hat and 14" x 1.10" wilwood rotor for use with a set of H2 wheels would be
![]() I would gladly offer up a stock knuckle/spindle/wheel hub for the prototyping |
#22 (permalink) | |
Member # 42423
#24 (permalink) |
"Assault Clip"
Member # 66259
What kind of accuracy and repeatability can your laser maintain in .750 CrMo? I have some parts designed and drawn up in Inventor and I'm looking at manufacturing options. The profile is beyond the capability of my CNC mill tooling.
