Balljoint 60 Build - Page 4 - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > Vendor Forums > Ballistic Zone
Old 03-24-2010, 05:25 AM   #76 (permalink)
Member # 82644
I'm going to be doning the same thing here shortly. How tall is you passenger side upper link? So I can order everything all at once.
[QUOTE=xjdoug;9487015]this is like watching a kid stick his finger in a light socket.... sooner or later he's gonna figure out why the rest of us arent doin it...[/QUOTE]
hadfield4wd is offline
Old 04-09-2010, 11:31 AM   #77 (permalink)
Mr. DJ
DJ404564X4's Avatar
Member # 85595
Originally Posted by primate60 View Post
i was lookin to get those same knuckles for my '94 hp60 I read your other thread and noticed you werent using your hi steer arms... did I miss something in there why your not using them?
i need to make more room, and push the front end out two or three more inches. tired of buildin...
wanna drive it.
sorry, i forgot about this thread, i'll measure it for ya.
DJ404564X4 is offline
Old 05-21-2010, 01:02 PM   #78 (permalink)
Member # 103451
damn, very nice welds. Do you have any pics of your trackbar mount on the axle?
69 Bronco on tons plus some other stuff too.
danwheeler is offline
Old 05-23-2010, 09:12 AM   #79 (permalink)
Mr. DJ
DJ404564X4's Avatar
Member # 85595
it's Polys'.
Old 06-01-2010, 04:34 PM   #80 (permalink)
Member # 34813
I stole and modified your idea!
with a little modification!
The Ballistic brackets fit like a glove!
FAUX X 4 is offline
Old 06-01-2010, 05:10 PM   #81 (permalink)
BOVADS
IRUNROCKS's Avatar
Member # 6363
Keep in mind you can always flip the bracket inside out and do it like this
IRUNROCKS is offline
Old 06-01-2010, 07:17 PM   #82 (permalink)
Member # 34813
Yeah, but mines welded!
FAUX X 4 is offline
Old 06-01-2010, 08:21 PM   #83 (permalink)
AZ Undertaker
theydontstop's Avatar
Member # 51580
That's cause you have a frame. I read somewhere that when you don't have a frame, you don't need to weld them
MILLER RACING #26
2012 Dirt Riot Modified Trail Class Champion
ADS SHOCKS * ARTEC INDUSTRIES * SOUTHWEST FASTENER * HOWE PERFORMANCE * RUGGED RADIOS * SDHQ * BLACK N BLUE RACING * RIGID INDUSTRIES * CAMPBELL ENTERPRISES * LETZROLL OFFROAD
theydontstop is offline
Old 06-01-2010, 08:36 PM   #84 (permalink)
Member # 34813
That explains a lot!
FAUX X 4 is offline
Old 06-01-2010, 08:56 PM   #85 (permalink)
AZ Undertaker
Member # 51580
The uni-frame should break before the unwelded bracket. And in your case, the jackstands shouldn't create enough force to break them either, so you'll be find not welding too
MILLER RACING #26
Old 06-02-2010, 05:48 PM   #86 (permalink)
BOVADS
IRUNROCKS's Avatar
Member # 6363
your supposed to weld these things on?
Old 07-21-2010, 02:24 PM   #87 (permalink)
Gravy's Avatar
Member # 105716
I realize this is probably already under the rig, but why not tie the coil buckets into the inner "C"s? They are pretty close already.
00TJ 35sp60s 106wb
Fabing & Wheeling is about having fun. If not: You're doing it wrong
Gravy is offline
Old 12-09-2010, 08:36 AM   #88 (permalink)
Member # 131296
nice welds and nice build, question for ya, did u have to turn ur inner C`s? and what did u use to get rid of the unit bearings on the 02 d60 diff?
nick
86 cj-5 frame, 76 cj-5 body, put together on 35" krawlers, 360v8,np435,d300 twin sticked
whitetrashxj is offline
Old 12-09-2010, 08:39 AM   #89 (permalink)
Mr. DJ
DJ404564X4's Avatar
Member # 85595
nick
no on the Cs and Solid hubs.
Old 12-10-2010, 10:41 AM   #90 (permalink)
Member # 131296
Your drivers side upper link mount, where did you get that from? Or did u make it? I've been looking all over ballistics site and can't find anything like that,
Old 12-12-2010, 12:05 PM   #91 (permalink)
Mr. DJ
DJ404564X4's Avatar
Member # 85595
i think it started life as a Ballistic mount, and then was cut down to what you see now.
Old 12-17-2010, 09:32 PM   #92 (permalink)
HOFF's Avatar
Member # 130079
I made it to fit the truss and the housing. Custom to DJ's Dana 60
Makin Dimes by layin Dimes
www.cutnotchweld.com
info@cutnotchweld.com
HOFF is offline
Old 05-21-2011, 07:41 PM   #93 (permalink)
Big_Ugly_1982's Avatar
Member # 190987
Can this be done for a WJ? What are the spring perch differences? Did you shorten the passenger side? What suspension are you running in front? What type of steering are you running?
Thanks
If it ain't broke it WILL be Don't follow me I'm lost too
Jason
Big_Ugly_1982 is online now
Old 05-24-2011, 04:21 PM   #94 (permalink)
Mr. DJ
DJ404564X4's Avatar
Member # 85595
Originally Posted by Big_Ugly_1982 View Post
Can this be done for a WJ? maybe
What are the spring perch differences? close to stock
Did you shorten the passenger side? no
What suspension are you running in front? Poly Performance, see my build in my sig
What type of steering are you running? Chromoly one ton TREs, for now
Thanks
There ya go..
