D44 Bombproof Balljoints - Page 22 - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > Vendor Forums > Ballistic Zone
Old 08-09-2011, 06:30 PM   #526 (permalink)
Banned
DrVic723's Avatar
Member # 46226
I don't see why not at this point.
DrVic723 is offline
Old 08-10-2011, 09:04 AM   #527 (permalink)
Dent'n Soup Cans
71BRONCO71's Avatar
Member # 43526
Send a message via AIM to 71BRONCO71
I would rather see the zerk right where it is.
If the stud portion of the ball joint has a tunnel down the center, there goes the strength. (compared to a solid stud.)
If you have a problem getting the grease gun on it when its on the bottom of the "cup" portion, then take your tires off. If you are already greasing up everything, why not open up your hubs and clean those at the same time.
BF-
Would these carry any kind of warranty? Dont need a timeline but to know that if something happens that they can be replaced would be a big deal.
Keep it up..
N-06177...N-06178... and 63 more to go.
KEEP OUR PUBLIC LANDS OPEN TO THE PUBLIC
71BRONCO71 is offline
Old 08-10-2011, 10:58 AM   #528 (permalink)
Member # 41764
You're talking a couple percent of the cross sectional area for a gun drilled grease channel.
Tow Rig: 2006 Dodge 2500 610CTD/G56/NP271/AAM9.25/AAM11.5
Trail Rig: 1997 K1500 LQ9/4l80e/NP241/D60/14FF and some stuff in between
No one is ever gone if they are always remembered.
JasonPayneMemorial
bggrnchvy is online now
Old 08-10-2011, 12:14 PM   #529 (permalink)
Banned
Member # 124890
After looking at the drawings, we've decided it would be best not to drill the studs. These joints will require routine maintenance to keep any play out of the joints and this would be an opportune time to remove the plug and install the grease zerk anyways.
Ballistic Eng is offline
Old 08-11-2011, 05:40 AM   #530 (permalink)
Skerb's Avatar
Member # 36943
Send a message via AIM to Skerb
what kind of routine maintenance? how often? and can they be maintained while on the vehicle?
For info on outdoor adventures in and around South Carolina check out OffroadSC.com
Skerb is offline
Old 08-11-2011, 08:54 AM   #531 (permalink)
Banned
Member # 124890
We'll have all that information when they're ready for release
