#26 (permalink) |
Banned
Member # 124890
Thanks for all of the above input. I do understand that many of these products are on the market, however they are not on the market from Ballistic and we're doing our best to be a one stop shop so that you don't have to order from 5 different vendors to put together one axle if you don't like. We're not reinventing anything new with some of these products I know, but if I can incorporate a few new ideas that you guys would like to see then that would be great. This is a 1st gen pickup axle that I am working on now, the FJ80 stuff will be down the road, so don't pick up the phone to order some FJ80 high steer arms just yet. Thanks
#27 (permalink) |
"Assault Clip"
Member # 66259
i made this a year or so ago. it since has had splines milled in the stud holes for ss inserts that are clamped by the studs. it would be cool to see a hub similar to the 7075 ones you made for a toy axle that uses standard toy bearings with your style drive flange to eliminate hub studs. this has helicoiled stud holes, and 3/8 6-4 titanium dowel pins (not installed).
#28 (permalink) |
Evil Twin
The custom toy specific housing brackets would be nice. I just order a few items from you (via Carolina Truggy) as well as a competitor to see what I could mix/match and put together for my toy axled buggy.
* Brackets w/ 22 deg offset w/built in shock mounts for Hiems or small joint. * Adjustable upper mounts 5",6",7" easily cut down, offered in 2 sets - 1 set for mounting out near the knuckles ( I need these!) - 1 set for standard center mounting
Mike Yager - Jeep TJ Build Up - Ecotec, Toy axles etc.. Ecotec - Technical Info E450 Ambulance VRAY (YAger RV) VRAY 2006 E450 - Ambulance Cummins Diesel Swap |
#30 (permalink) |
Member # 71495
how about some billet 6 stud arms
[URL="http://yotamasters.com/"]http://yotamasters.com/[/URL] :flipoff2:The only jeep in my family is pink and my 4 year old drives it:flipoff2: |
#31 (permalink) |
Member # 102526
Agreed ^^
There was a guy on the yota forum that had some left hand drive ones (he was from new zealand i think). They were sick.
1994 Reg Cab Pickup, 22re, 5 speed, SAS, 4.88s, dual t-case with twins, ARBs, 33s, Viair OBA |
#32 (permalink) |
Member # 47670
That would be Jafa's "Hilux build in New Zealand"
http://pirate4x4.com/forum/showthrea...611264&page=11 He added a keyway to his six stud arms too, something like this would be pimp
"Whoso Speaketh Of What Concerneth Him Not Shall Hear What Pleaseth Him Not." Sir Richard Francis Burton |
#33 (permalink) | |
Member # 71495
#35 (permalink) |
Bootyfab Technician
Member # 35163
I would love to see a modular axle system for toy's similar to what spidertrax does with the 9" axles.
-Housing without ends built with either left, center or right pumpkins that can be cut to whatever width is desired -Heavy duty ball & knuckle assemblies, or fabricated C & Knuckle assemblies that use toyota spindle & Hub assemblies - sizes for mini truck birfs & for FJ80 birfs -Weld on ends for rear housings that allow a front spindle to bolt up to make a full floater -Made for 8", 8.4" & 9.5" Diffs (maybe eventually the 10.5" tundra diffs) Other ideas: a knuckle ball gusset kit that is stronger/ cooler than the flat plate gussets that most places sell solid steering stops 1/4" plate felt retainers to replace the stamped sheetmetal ones - these would be awesome run with the new UHMW seals that longfield just released
1979 FJ40 Last edited by Toyoland66; 12-06-2009 at 01:45 PM. Reason: spelling |
#36 (permalink) |
Reinvent the knuckle ball and make it beef.
Good high steer set up that wont shear off. 6 studs, keys, ect not some cast POS. A new wheel hub as mentioned before, with integrated spline to run a drive slug and eliminate the little hub bolts. A simple and effective full floater kit for the rear to use stock front spindles and your new pimp hubs. I might consider going back to toyota axles then.
Hammers #847 Tellico #452 |
#37 (permalink) |
Id like to see an affordable front housing with beefy tubes no more need for gussets
Id also like to see a option of a fj third for the 9.5 ring I can garantee if you can up with something like this you'd be selling em like hot cakes as long as the price was reasonable.
86 yota/toy junk again /exo/ stackers with 4.7/ 40 iroks /turbo pane |
#38 (permalink) |
Member # 78331
I know it's a rear axle part but it's been mentioned before. How about an adapter to bolt a front axle spindle to the rear housing for full float. You could offer two versions, one with ears for GM calipers and one with ears for Toyota calipers. I'd be in for some Toyota adapters.
#40 (permalink) |
Banned
Member # 135790
NEW Toyota '79-'85 front axle truss ![]() ![]() Toyota '79-'85 front axle truss NEW CNC LASER CUT AND CNC PRESS FORMED This truss system is designed to increase the strength of a stock Toyota front axle from '79-'85 trucks. The boxed 3/16" plate provides maximum strength when compared to competitors' 1/8" thick trusses. Can also used to mount link mounts. The profile contours the shape of the axle for a tight fit. Part # TOY-1330-1. ONLY $24.99 CHECK IT OUT HERE |
#43 (permalink) |
what about some truss for the short side that integrates the spring perch and knuckle ball gusset and possibly shock tabs? Also maybe some way to get rid of the spring perch underneath and still be able to use U-bolts... maybe some sort of weld in lower gusset?
DIY centersection that ppl could build their own axle. Just add tube and ends.
[QUOTE=BellyDoc;8268286] It may not have been rape, but it was a vigorous copulation.[/QUOTE] |
#44 (permalink) |
Member # 16789
Outboarded shock mounts for the guys who are linking a toy front end. some pics in here:
http://pirate4x4.com/forum/showthrea...316&highlight= Also, a double sheer steering set-up. No one offers either one of these products openly.
The Parts Pimp. Wanted! Solid axle steering boxes from 1979-1985 toyota pick-ups and four runners. PM me for details. Wanted! Power assist Rams and Valves from 75-77 Ford F-250's. PM me for details. $78 for Toyota front knuckle rebuild kits DELIVERED!! PM me for details. Last edited by montezuma; 12-11-2009 at 06:27 PM. |
#45 (permalink) |
Member # 85581
i would love to see a 3link mount kit for front axles, maybe even simple enough that it bases on the old spring perches with the lower link mounts at axle centerline.similar to this
lockers gears and beers, friends dont let friends wheel without 'em |
#46 (permalink) |
Member # 46175
Does anyone make a rear truss? Not that I have ever bent a rear housing outside of a rollover.
![]() I know many people, including myself, have wrote off the FJ80 front axle immediately because of the steering issue. The second reason being cost. Now that these things are 12+ years old, they are getting easier to score at a reasonable rate. Either a new arm, or a knuckle/arm combo could be a unique product that would really stand out in the marketplace.
USED and NEW 4x4 PARTS - (716) 984-8715 8-5pm EST Specializing in Axles and Transfercases |
#49 (permalink) |
How about u-joint pinion flanges? There are several ways out there to throw something together, but it would be cool to see an affordable Toyota companion flange set up for say 1350 u-joints.
[QUOTE=abig84;9192789]i swear id be gay if it wasn't for all the gay sex that's involved[/QUOTE] [QUOTE=TexasBlake;10305687]She's not that hot. I was just looking for a quick lay and she all wanted to like go on dates and shit. [/QUOTE] |
