Toyota Front Axle Parts - Page 3 - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > Vendor Forums > Ballistic Zone
Old 12-20-2009, 02:32 PM   #51 (permalink)
91norcalcrawler's Avatar
Member # 140406
there is already plenty of stuff out there for the mini axles we need a high steer solution for 80 axles come on somebodys gunna have to make a quality one sometime y not u
91norcalcrawler is offline
Old 12-20-2009, 05:41 PM   #52 (permalink)
Member # 14780
agreed!
04.5 cummins lb,qc,white, 4x4,,bddl, outlook,, exhaust 315 bfg's
02 WRX caged etc
new buggy
http://www.pirate4x4.com/forum/showt...43#post5890143
save tellico post #830
35xj is offline
Old 12-20-2009, 08:58 PM   #53 (permalink)
Member # 86771
Lets do it yea really don't want chevy or ford stuff
tomjordanphoto is offline
Old 12-29-2009, 05:28 AM   #54 (permalink)
LC Hamma's Avatar
Member # 137
I know I'll never see this in my lifetime, but a HIGH PINION 9.25 LAND CRUISER DIFF that fits *most of the Cruzahs from early 70's to late 90's.
Fully welded open knuckle design to capture a HD high steer arm in DOUBLE SHEAR, OTHER THAN USING STUDS & could also work w/ a smaller Longfield style CV, sim. to the D60's.
'72 FJ55
http://forum.ih8mud.com/showthread.php?t=76835
'73 FJ40
http://s132.photobucket.com/albums/q...&addtype=local
'78 FJ40
'91 Ram W250 5 spd. CTD
'93 Ram W350 5 spd. CTD
'99 Ram 3500 4X4 5 spd. CTD
Welding is like sex, it's all about the penetration!
LC Hamma is offline
Old 01-02-2010, 08:51 PM   #55 (permalink)
Member # 23011
I'd like to see a steel fabricated knuckle. It would make repairs and modifications much easier, not to mention it could be made stronger than stock.
vikingsven is offline
Old 01-02-2010, 09:53 PM   #56 (permalink)
Tracker
yoder man's Avatar
Member # 123895
Cool HD Brake Conversion
How about a way or adapter to bolt Chevy calipers and rotors on the front end. Then it would at least match most of our rear disk conversions. Mine lock up the rear way before the front. This would at least give them equal size and diameter. Also how about a weld on ring and cover (that bolt together) to make a toyota diff cover removeable. Then a guy could inspect and clean / adjust necessary things. This would help during ring and pinion set up and break in, with out tearing the knuckles down to inspect the diff gears. If you make these you'd better hook a brother up good!
yoder man is offline
Old 01-02-2010, 10:02 PM   #57 (permalink)
Tracker
yoder man's Avatar
Member # 123895
Cool long slip yoke kit
How about a long slip yoke kit for toyota front drive line. Just make it to do it yourself with spline and long travel yoke to stock toyota yoke like Daves. I bought a TG and had to cut their yoke and machine it to accept a stock toyota yoke in the end. I'll never buy their's again for any build, mine or a customer's. This would be a nice thing to see on the market from Ballistic.
Old 01-03-2010, 08:55 PM   #58 (permalink)
Member # 111714
I'll add another vote for affordable high steer for the 80 axle.
Tyler C is offline
Old 01-03-2010, 09:50 PM   #59 (permalink)
Super Willie
Tech Tim's Avatar
Member # 19067
HD duty balls for the 80 w/ matching knuckles.
It's time to go bigger than mini-truck balls!
Tim Lund
Yeah, I wear a Kilt... what you're not man enough?!
Want beadlocks? Allied Beadlocks.... Best designed and best priced aluminum beadlock on the market!
Got 40 SPLINE? Time for you to get 40 spline too! 40 spline hubs, spindles, outer stub shafts, 40 spline 14 bolt & Dana 60 Air Lockers
http://www.wildwestfab.com.... WILD WEST OFF ROAD 360-264-5363
Tech Tim is offline
Old 01-08-2010, 06:15 PM   #60 (permalink)
"Assault Clip"
spork2367's Avatar
Member # 66259
e-locker actuator guards. something less than 75.00.
spork2367 is online now
Old 01-08-2010, 06:24 PM   #61 (permalink)
yoda0395's Avatar
Member # 21771
x2 million
Looks hard, you should quit.
yoda0395 is offline
Old 01-28-2010, 11:10 PM   #62 (permalink)
Member # 15032
not axle but---- How 'bout a Toy EFI sending unit and internal fuel pump flange or a module that would allow us to use a new sending units or our sending units with an aftermarket fuel cell (gm sender/pump)? Or just a sender and pump that are Toy and fuel cell compatible.
Mo Chi Chu
'87runner
zidaro is offline
Old 02-13-2010, 04:09 PM   #63 (permalink)
Member # 8257
I like the idea of a clean, simple front housing with longer than necessary axle tubes that can be cut to any desired length, then fitted with some burly knuckle balls. Be a nice kit to order. Be nice to see a reasonable price as well, but whatcha gonna do, can't work for free, right!?
And the people who don't want to trim a link mount to fit the pass side of a toyota housing...? That's just friggin lazy. Might as well sell a housing with the mounts welded on for those guys as well then.
And I don't know if anything's changed, but a backorder courtesy call/email of some sort would be great!
[url]www.sixfeetdeepclothing.com[/url] [url]www.sixsixone.com[/url] [url]www.oneal.com[/url]
twistedmetal is offline
Old 02-14-2010, 02:55 PM   #64 (permalink)
Member # 78778
I second this, it shure sucked to wait for half my order to show only to have to call and find ya didn't know when i would get the remainder. Its the one reason I havent and may not buy from ya agin.
gittinit is offline
Old 02-15-2010, 08:57 PM   #65 (permalink)
Member # 27987
How about a housing with a 9.5" Land Cruiser 3rd, rather than the minitruck one.
76' FJ40 - Rusty Mustard
CrAwLoRado.com - Proud Graphics Sponsor of JT Taylor & Matt Petterson
isotel is offline
Old 02-16-2010, 07:33 AM   #66 (permalink)
phi564's Avatar
Member # 31550
diamond axle already has this but another option would be cool
buggy, 6.0L, th350, atlas 3.0, 60&14, 5.13's, locked, psc steering, 39" bfg krawlers, bilstein coilovers, etc.
Double Trouble Motorsports Highclearance Offroad
thanks to my sponsors:
TS Performance NitroPlate No Limit Tuning and Design
phi564 is offline
Old 02-20-2010, 02:37 AM   #67 (permalink)
Member # 64230
Anything for the FJ80. I've got a set of axles now and the only thing holding me back from using them is the steering. Knuckle balls with different lengths so you can vary the width of your axle too.
Evilwhitey is offline
Old 02-22-2010, 09:58 PM   #68 (permalink)
Member # 135242
how about torque arm starter kits that work either front or rear, and offer shackle mount or the good ol' slip-n-twist and pivot parches.
KingofChilli82 is offline
Old 03-31-2010, 06:18 PM   #69 (permalink)
rokcrawlintoy's Avatar
Member # 27447
Any chance of 1/4" wheel spacers?
rokcrawlintoy is offline
Old 03-31-2010, 06:46 PM   #70 (permalink)
Member # 7624
Send a message via AIM to offroadman83
How about beefy housings for a super cheap price...............
1 ton wrangler yj in the process.....................
offroadman83 is offline
Old 03-31-2010, 07:05 PM   #71 (permalink)
lenross1's Avatar
Member # 105385
Anything for an 80 series axle, especially steering, housing, shave kit, and knuckles. Who ever comes up with an adapter to swap out an 80 tcase is going to make a fortune. I see so many 80s on the trail and they do great, but a tcase option IS the way to go.
Www.CottonlandCruisers.com
87 samurai 3sp auto/1.8 kick tcase/4:1 dana300, yota axles, 4 link rear, 39" krawlers.. reds
97 FZJ80 supersets,chromoly rear axles,4.88s , 345 KM2s
lenross1 is offline
Old 04-02-2010, 09:03 PM   #72 (permalink)
SMASHurai
toykilla5150's Avatar
Member # 65463
Send a message via AIM to toykilla5150
X100,000,000,000
I dont want to buy and build huge 60s for my Zuk. I would build FJ80s though.
you cant fix stupid people
87 zuk- modded/wheeler/DD
86 zuk- tub/registered propane
88 zuk- firewall/last rig
87 zuk- invisable w/title
toykilla5150 is offline
Old 04-06-2010, 04:43 PM   #73 (permalink)
Member # 111797
motor mounts that work and maybe a crossmember, and t-case mounts as well.
Rotten Destruction
ToxicToy is offline
Old 04-06-2010, 04:52 PM   #74 (permalink)
Banned
Member # 124890
This one is installed in one truck that I know of. It's in the testing stages. Needs a bit of cleanup but it will be something we'll release in the future or some variation of.
Ballistic Eng is offline
Old 04-06-2010, 11:19 PM   #75 (permalink)
Member # 111797
oh very kool
Rotten Destruction
ToxicToy is offline
