Member # 36746
Reducer Sleeve
7/8 to 3/4 rod end bolt reducer. You make anything that is just a simple sleeve, no shoulder at all? Just need an insert that will reduce the bolt hole to 3/4 so I can use my custom cut high mis spacers for mounting and reducing to 5/8 bolt. Thanks
I need a reducer spacer with a 1/4 deep sleeve because it is going through 1/4" material. Could yall offer these in 1/4" sleeve and then people could grind them to 3/16 if they wanted?
For info on outdoor adventures in and around South Carolina check out OffroadSC.com Last edited by Skerb; 03-15-2011 at 09:17 AM. |
