Clicking rod ends, MXM-6 - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > Vendor Forums > Ballistic Zone
Old 08-31-2010, 09:05 PM   #1 (permalink)
asonico's Avatar
Member # 98299
I made a pair of vertical swaybar links using the MIDWEST MXM-6 rod-ends and after one trip to Baja (1200 miles) they now have a slop. Tapping the links upward (ends of swaybar at the bottom) with my palm makes a loud click.
What's wrong?
77 Dodge Xplorer 307 Frank Ind 25-ft Class A Motorhome 1st Gen '93 Cummins swapped in, stock '95 47RH/NP241, stock turbo, PS intercooler, Dana 60 front, Dana 70 rear, 4.10:1 gears, ARB lockers front and rear, 19.5 Rickson wheels, 33-inch tires, High-Angle driveline.
asonico is offline   Quick reply to this message
Old 08-31-2010, 09:53 PM   #2 (permalink)
Banned
DrVic723's Avatar
Member # 46226
Were they bound up in any way? MXM rod ends are good, but QA1 are better.
DrVic723 is offline   Quick reply to this message
Old 09-01-2010, 07:00 PM   #3 (permalink)
asonico's Avatar
Member # 98299
Thanks for the response. They're not bound up, they move and turn, albeit loosely. It's just that they have a slop and click when I wiggle the sway bar up and down.
Old 09-01-2010, 09:54 PM   #4 (permalink)
Banned
DrVic723's Avatar
Member # 46226
You probably need a larger rod end from MWC, or try the QA1 joints.
Jeff
Old 09-02-2010, 06:50 AM   #5 (permalink)
asonico's Avatar
Member # 98299
Thanks.
Actually, I measured it and have the 1/2" MXM-8. I'll try the QA1 and see if they last, otherwise it'll be too expensive to be changing them every thousand miles.
