14 Bolt truss and "shave" kit thread - Page 21 - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > Vendor Forums > Ballistic Zone
Old 02-21-2011, 05:30 PM   #501 (permalink)
Newbie
Member # 143904
Order placed today! Now I'm looking forward to the rest of the week. Minus the "job" part....
-Eric-
08 JKU- Rock Krawler lift, PSC Evap Skid, 35" Nitto's, SE9500. Nice to have something to build again.
AWOL is offline
Old 02-21-2011, 08:04 PM   #502 (permalink)
Member # 18650
Send a message via AIM to chadjans
Originally Posted by shawnxj View Post
are 14 bolts cast iron or cast steel? i know some people who swear they're cast steel and don't need nickel rods and heating up and slow cooling processes but everywhere else i read they're cast iron.
Relevant discussion:
http://weldingweb.com/showthread.php?t=44642
chadjans is offline
Old 02-21-2011, 09:29 PM   #503 (permalink)
Tracker
yoder man's Avatar
Member # 123895
5.13T gears for 4.10 carrier
So before I weld up my rear end, do I need to clearence the bottom plate for a 5.13 thick gear set? These are for the 4.10 carrier. I read somewhere they were needing a lil more for 5.38's but wanted to know if mine was ok. Thanks for your time.
yoder man is offline
Old 02-22-2011, 06:30 AM   #504 (permalink)
Banned
DrVic723's Avatar
Member # 46226
We have since corrected the issue, only the very first batch of 30 kits were affected. If your bottom plate has a machined pocket with one side straight and the other side curved then you are set. Ill see if I can get allen to post some drawings of the differences between the two revisions.
Jeff
DrVic723 is offline
Old 05-27-2011, 03:34 PM   #505 (permalink)
abrogate's Avatar
Member # 31552
Send a message via AIM to abrogate Send a message via MSN to abrogate
Don't really have time to re-read the whole thread, but has anyone had any luck abrasive grinding their ring gear for the clearance? This would be for a dedicated trail truck.
[B][CENTER][SIZE="6"][FONT="Impact"][COLOR="DarkRed"]Temet Nosce[/COLOR][/FONT][/SIZE][/CENTER][/B]
[QUOTE=ashmanjeepXJ;7641445]All you will probably ever have in common with this forum is a steering wheel. [/QUOTE]
abrogate is offline
Old 05-27-2011, 03:47 PM   #506 (permalink)
Banned
Member # 124890
I can't recall the customer who did it, but there have been a couple. As long as you are careful to be as consistent as possible, I don't think it will be a huge issue unless you do a really poor job.
Ballistic Eng is offline
Old 05-30-2011, 04:42 AM   #507 (permalink)
Member # 154330
What kind of turn around do you have on gear sets sent to you for machining? And maybe this is a stupid question, but can you give a better explanation to the needle scaler process? I have used them, but only for clean up and paint/rust removal. How does this process help and is it absolutely necessary?
Wondering this as well.
OrangCJ is offline
Old 05-30-2011, 07:58 AM   #508 (permalink)
Resident Beekeeper
CJesse7's Avatar
Member # 36707
Send a message via AIM to CJesse7 Send a message via Yahoo to CJesse7
the needle scaler is used to relieve stress from welding on the cast. i didnt have a needle scaler so i just beat the piss out of it with the sharp end of a chippin hammer, and wrapped it with welding blankets.
A government big enough to give you everything you want, is a government big enough to take everything you have.
My Reverse Flow BBQ Pit Build
http://www.pirate4x4.com/forum/gener...pic-heavy.html
CJesse7 is offline
Old 05-30-2011, 08:56 AM   #509 (permalink)
flatblack51's Avatar
Member # 121033
After wAtching the 14 bolt 101 episode on extreme4x4 I mig welded mine. cleaned the surface with acetone and went to town welded inside and out pretty sure I won't have any issues. and there are 2 solid passes on the outside
89 YJ but not really back halved!?!350 5.7L 4L60E D60 14B(shaved)5.13 39" BFG Baja projects atlas 4spV2 ADS coilovers and fox bumps at the corners!
BOMTEC Racing 4476 jimmy's 4x4 support team
Torchmate2x4 cutting your stuff for dirt cheap!PM for quotes!
flatblack51 is offline
Old 05-30-2011, 09:12 AM   #510 (permalink)
Newbie
Member # 143904
Glad to see this was put back up! I was looking for it as well. Just got my shave finished. Now I need to get it under the rig.
-Eric-
AWOL is offline
Old 06-02-2011, 09:07 AM   #511 (permalink)
Banned
DrVic723's Avatar
Member # 46226
Great job guys!
DrVic723 is offline
Old 06-02-2011, 09:57 AM   #512 (permalink)
7Jake's Avatar
Member # 42993
Mig or Ni
Flatblack51......... what made you decide to go mig instead or Ni stick. I have 2 lbs or Ni rod and was planning to shave and weld mine this weekend, but after talking to the guys at my local welding supply shop,(& scraching my head while Ian on extreme mig'd his) they stated the following:
"if it's Cast steel", weld it with mig or whatever you would regular mild steel
"if it's Cast Iron", preheat, weld with Ni rod, impinge, post heat, etc...
Use a chisel and hammer to differentiate between the two:
"if it Curls off", it's Cast Steel,........ mig it
"if it chips off", it's Cast Iron,.......... preheat, Ni rod, post heat
Checked mine this morning and it Curls off. I'm thinking I'll do a little preheat, weld with wire feed mig, and wrap to cool.
If they're right with their advice, my shave just got easier.........Anyone have any objections or experience to lend??
P.S. Dr Vic..... The clearance diagram would be great as I was one of the original 30 kits and I'll be running 5.38 with ARB. (It's about time I get it installed, I've been looking at it for a year now)
7Jake is offline
Old 06-02-2011, 01:38 PM   #513 (permalink)
Banned
Member # 124890
Some guys never had any issues, so you may not either.
Old 06-03-2011, 02:11 PM   #514 (permalink)
7Jake's Avatar
Member # 42993
Thanks for the diagram. If all goes well I'll be installing my kit this weekend. I'll post up some pics next week.
7Jake is offline
Old 06-03-2011, 07:21 PM   #515 (permalink)
trupster415's Avatar
Member # 107105
How well will the center section hold up after doing this in a ultra 4 type buggy getting pounded in the desert and being jumped? I want to do this kit but want to make sure it can take a beating with out cracking open. My 14 is already trusses on top very well
trupster415 is offline
Old 06-06-2011, 01:38 PM   #516 (permalink)
Banned
Member # 143863
/forum/ballistic-zone/984460-14-bolt-tech-thread.html
The customer who started this thread no longer wishes it to be posted, so he has deleted it numerous times. Please go to the thread started by Ballistic Eng that is listed above.
Thanks, Dave
BallisticDave is offline
