Brad@Barnes4wd.com
Member # 87333
For hill climbing long wheelbase rigs with 46” tires and bigger or Mega Trucks running huge Rice and Canes Rockwell’s are the go to axle. Every year what we think of a “big tire” seems to be redefined by a new even bigger tire. It also seems that instead of having an unbelievable low crawl ratio the norm is getting to be high horsepower motors. With the combination of bigger tires and more power more and more people are finding the limits of one ton axles. This is where the 2.5 Ton Rockwell comes in.
2.5 Ton Rockwell Axles are a great choice but to get the most out of them you need suspension components that are uniquely designed for their unique layout. First to keep the center of gravity low and to have clearance for the top loader driveshaft the upper control arms need to be straight. Since the upper control arms are straight then to locate the axle laterally the lowers then need to have the triangulation so they are pre-bent to 20 degrees. We took this in to consideration with the design of all of our Rockwell brackets. The entire Barnes 4wd Rockwell Bracket line up is made entirely of 3/8” American Steel and to be used the suspension joints that have a 2 5/8” mounting width. Rockwell Control Arm Brackets ![]() http://www.barnes4wd.com/Rockwell-Co...air_p_206.html Rockwell Control Arm Brackets With Coil Buckets ![]() http://www.barnes4wd.com/Rockwell-Co...air_p_205.html Rockwell Control Arm Brackets With Shock Tabs ![]() http://www.barnes4wd.com/Rockwell-Co...air_p_204.html Rockwell Link Tower ![]() http://www.barnes4wd.com/Rockwell-Link-Tower_p_207.html Rockwell Lower Control Arm Brackets With Coil Buckets ![]() http://www.barnes4wd.com/Rockwell-Lo...air_p_208.html
Barnes 4WD ------------------------------ Email: sales@barnes4wd.com Shop # 828-551-7616 ------------------------------ www.Barnes4wd.com ------------------------------ https://www.facebook.com/pages/Barne...15253988524951 Subscribe to our Newsletter for Discount Codes and New Product Releases! Be Sure and check our website daily for the deal of the day! All Orders to Lower 48 States Ship Ground for $15 or Less |
Brad@Barnes4wd.com
Member # 87333
Rockwell Lower Control Arm Brackets With Shock Tabs
![]() http://www.barnes4wd.com/Rockwell-Lo...air_p_209.html
Brad@Barnes4wd.com
Member # 87333
Rockwell 4 link kit with heims would be $699
If you would like the Rockwell brackets to have the built in Coil or shock brackets the price would be $720 Thanks Brad
Brad@Barnes4wd.com
Member # 87333
Thanks!
#5 (permalink) | |
Brad@Barnes4wd.com
Member # 87333
These brackets have 10" of vertical separation and the lowers are angled in 20 degrees
Thanks for your interest Brad
#8 (permalink) | |
Brad@Barnes4wd.com
Member # 87333
Sorry about that. If you will PM me your email I will email you a PDF that should have the info that you need. Thanks Brad
#12 (permalink) |
Brad@Barnes4wd.com
Member # 87333
Adrian,
What measurements would you like?
#13 (permalink) |
Brad@Barnes4wd.com
Member # 87333
All 3/8" and ready to Rock!
#14 (permalink) | |
Member # 157195
M & M Offroad chassis, Blown 454, TH350, Atlas II on Rockwells |
#15 (permalink) | |
Brad@Barnes4wd.com
Member # 87333
Thanks Brad
#17 (permalink) |
Brad@Barnes4wd.com
Member # 87333
Thanks for your business!
