Barnes 4WD Battery Boxes - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > Vendor Forums > Barnes 4WD
Old 03-28-2012, 09:19 AM   #1 (permalink)
sales@barnes4wd.com
Barnes 4wd's Avatar
Member # 87333
Talking Barnes 4WD Battery Boxes
Name:  Barnes 4WD 3478 Optima Battery Box.JPG
The Barnes 4WD Optima Battery Box is cut from 1/8" steel and formed for a very snug fit around your common 34/78 Optima battery size to prevent any movement. This battery box was designed to give you the most mounting options possible. Each Battery box kit comes with the coated 5/16" hardware as well as lock nuts to prevent your fasteners from coming loose or corroding.
$36.16
Barnes 4WD 34/78 Optima Battery Box
Barnes 4WD 34/78 Optima Dual Battery Box
Name:  optima 3478 dual battery box.JPG
The Barnes 4WD Dual Optima Dual Battery Box is cut from 1/8" steel and formed for a very snug fit around your common 34/78 Optima battery size to prevent any movement. This battery box was designed to give you the most mounting options possible. This is why we use two separate tops for our battery dual battery box. What good is it too have batteries that you can mount in any orientation if it takes three people to try to hold both batteries in place will you try to install a one piece top. The two piece top also this design gives you the most flexibility of how you want the batteries facing. Each Battery box kit comes with the coated 5/16" hardware as well as lock nuts to prevent your fasteners from coming loose or corroding.
$65.53
Name:  Odyssey Diehard Battery Box.JPG
he Barnes 4WD Odyssey Diehard Battery Box is cut from 1/8" steel and formed for a very snug fit around your common 34/78 Odyssey, Diehard size to prevent any movement. This battery box was designed to give you the most mounting options possible. Each Battery box kit comes with coated 5/16" hardware as well as lock nuts to prevent your fasteners from coming loose or corroding.
$35.51
Barnes 4WD
Email: sales@barnes4wd.com
Shop # 828-551-7616
www.Barnes4wd.com
FaceBook
https://www.facebook.com/pages/Barne...15253988524951
Subscribe to our Newsletter for Discount Codes and New Product Releases!
Be Sure and check our website daily for the deal of the day!
Barnes 4wd is online now   Reply With Quote Quick reply to this message
Old 09-10-2012, 06:49 AM   #2 (permalink)
sales@barnes4wd.com
Barnes 4wd's Avatar
Member # 87333
Talking
Mount your battery any way you want!
Barnes 4WD
Shop # 828-551-7616
www.Barnes4wd.com
FaceBook
Old 04-25-2013, 08:06 AM   #3 (permalink)
sales@barnes4wd.com
Barnes 4wd's Avatar
Member # 87333
Talking
Check out our new Optima Dual Battery Box!
Barnes 4WD
Shop # 828-551-7616
www.Barnes4wd.com
FaceBook
Old 12-11-2013, 08:12 AM   #4 (permalink)
sales@barnes4wd.com
Barnes 4wd's Avatar
Member # 87333
Talking
We now have Odyssey Diehard Battery Boxes
Thanks
Brad
Barnes 4WD
Shop # 828-551-7616
www.Barnes4wd.com
FaceBook
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
