Brad@Barnes4wd.com
Member # 87333
![]() This is a great kit, made from 2" DOM with a ¼" wall and a high quality poly bushing inner sleeve bore is 9/16"and has a .219 wall thickness that will not become egg shaped with hard use. This combo is great for any application that you need to isolate vibrations. These can be used for motor mounts, cage mounts, transmission and transfer case cross members and many other applications. Our DOM Sleeve with Poly Bushing comes in two lengths. Like all of our products, they are made in the USA from USA steel. $10.55 http://www.barnes4wd.com/DOM-Sleeve-...ing_p_137.html ![]() This is what you need to make that Crossmember bulletproof and still vibration dampening, it comes with everything and is made of 2.0" DOM with a .25" wall and .375 Tabs for frame mounting (we can replace with 1.75" or 2.0" Radius Tabs for tube mounting). It comes with 2 grade 8, 9/16" bolts with Lock nuts, 4 high quality Bushings, and an inner Sleeves Cadmium coated. They are 3" wide. Sold in pairs. $44.26 http://www.barnes4wd.com/Crossmember...Set_p_112.html ![]() Our single poly bushing kit comes with two bushings and one inner sleeve. The inner sleeve has a 9/16" bore and has a .219 wall thickness that will not become egg shaped with hard use. The bushings are designed to fit a 1.5" ID tube. $5.78 http://www.barnes4wd.com/Single-poly-bushing_p_161.html
Barnes 4WD ------------------------------ Email: sales@barnes4wd.com Shop # 828-551-7616 ------------------------------ www.Barnes4wd.com ------------------------------ https://www.facebook.com/pages/Barne...15253988524951 Subscribe to our Newsletter for Discount Codes and New Product Releases! Be Sure and check our website daily for the deal of the day! All Orders to Lower 48 States Ship Ground for $15 or Less |
Brad@Barnes4wd.com
Member # 87333
These have a ton of uses, and you guys are figuring that out!
Brad@Barnes4wd.com
Member # 87333
All of mine will have a 9/16" bolt hole with a extra thick wall for the sleeve.
#6 (permalink) | |
Brad@Barnes4wd.com
Member # 87333
Thanks Brad
#7 (permalink) | |
White Trash Fab
Just ordered a bunch more.
"If you are gonna live life on the edge you better have good balance" 06 Tundra DC The "Trifecta" 3 seat yota buggy ![]() http://pirate4x4.com/forum/showthread.php?t=1027210 http://www.AddictedOffroad.com/ www.ruffstuffspecialties.com http://f-o-a.com |
White Trash Fab
A motor mount built using one of these kits.
