Brad@Barnes4wd.com
Member # 87333
I know, I know, I know…. Everybody wants a linked rig, but the truth of the matter is a good leaf spring setup will outperform a linked rig with poor suspension geometry ever time. Leaf springs are simple, strong, somewhat tunable and just plain work. Another great thing is that there are so many OME leaf springs to choose from you have the 63” super flex Chevy springs to the Dodge Dakota Springs that give you killer departure angles and so many more that have great characteristics. And did I mention that you can set up a great leaf spring suspension for about half the cost of a 4 Link.
So here is a breakdown of some of the most durable leaf spring components that the industry has to offer. First let’s talk about U-Bolts. The biggest misconception with U-bolts is that they are all the same; this could not be farther from the truth. We feel that U-Bolts are the most important component of a leaf spring suspension and this is why we are so meticulous about the specifications of our U-bolts. Our U-bolts are made from a cold drawn 1541 alloy that is stress relieved. This produces an alloy that is has grade 8 strength but not grade 8 hardness. The threads on our U-bolts are 5/8”-18 fine threads and are manufactured with a smooth rolled thread. The mating Hi-Nuts are hardened as well as the thick washers and are manufactured with sharp cut threads. When a U-Bolt is tightened the U-Bolt threads stretch as they mate with the Hi-Nuts. This insures proper tightness of the fastener is maintained. This stretching is not visible but a U-bolt should never be reused because removing the tall nut will cross thread the U-Bolt. Our U-bolts bolts have a torque spec of 150 foot pounds and should never be tightened with an impact gun. Our U-bolts are $13.57a piece and can be purchased here http://www.barnes4wd.com/U-Bolts-U-B...ates_c_37.html ![]() Next you have the spring perches. Spring perches need to be ridged and made to fit your application. Like all of our products they are made with US steel and are Laser cut and then bent on a CNC press brake. The leaf spring perches are made from ¼” steel and are 7 ¾” long to help with axle wrap and have three holes for the center pin of your leaf springs. I know that these are a little long for a spring under application and most customers just cut about a 1” from each end. We currently offer these in eleven different sizes so you can find a leaf spring perch that will have the right axle diameter and the correct width for your leaf spring and we are adding more all the time. Our Spring perches are sold in pairs for $26.15and can be found here http://www.barnes4wd.com/Anti-Wrap-L...ches_c_36.html ![]() Great leaf spring Perches have to have something strong to work with so when we designed our U-bolt plates we made sure that it had the BEEF. Our U-bolt plates are laser cut from 3/8” and then bent on each end to give you a supper rigid U-bolt plate. These U-bolt Plates have three leaf spring center pin locations to match our Leaf Spring Perches and come in a verity of sizes to match your axle diameter and spring width and have slots to accept our 5/8” U bolts. We even have ½” thick U-bolt plates for Dana 60 King Pin applications. Our U-Bolt plates are sold in pairs and are $37.05 for most applications and $44.18 for King Pin 60’s and can be found here http://www.barnes4wd.com/U-Bolts-U-B...ates_c_37.html ![]()
Barnes 4WD ------------------------------ Email: sales@barnes4wd.com Shop # 828-551-7616 ------------------------------ www.Barnes4wd.com ------------------------------ https://www.facebook.com/pages/Barne...15253988524951 Subscribe to our Newsletter for Discount Codes and New Product Releases! Be Sure and check our website daily for the deal of the day! All Orders to Lower 48 States Ship Ground for $15 or Less |
Brad@Barnes4wd.com
Member # 87333
Barnes 4WD All things Leaf Sprung!
We also have you covered at the ends of your leaf spring with a great selection of leaf spring hangers and shackle hangers. Our hangers are laser cut from ¼” US Steel and are then formed on a CNC Press Brake. We offer our hangers in three different sizes to accommodate 2.5” 2.75” and 3” wide leaf springs. Barnes 4wd shackle hanger come in two different configurations with a center mount and a flush mount. The center mount is great for uniformly distributing the load to the frame and our Flush Mount Hanger optimizes approach and departure angles when the shackle is at the end of the frame. Our shackle hangers have a 2” DOM sleeve with a ¼” wall thickness. You will also get poly bushing and a heavy wall inner sleeve. Leaf spring hangers sell for $25.36 a pair and the Shackle hangers sell for $34.56 a pair and can be found here.
http://www.barnes4wd.com/Spring-Shac...gers_c_38.html ![]() ![]() ![]() To get everything working together we have a great verity of shackles. All of our single shackles are made form 3/8” plate that is laser cut. We offer them in 4”, 5” and 6” lengths (all measurements are measured from center of the bolt hole to center of the bolt hole). We also offer all three lengths in two different offsets of 1/8” and ¼”. This works great if you are changing leaf spring width but do not need to change your spring and shackle hangers. One thing to keep in mind is the amount of lift that you will get when going with a longer shackle. If you have a factory 4” shackle and you upgrade to one of our 6” shackles you will get 1” of lift not 2”. Since the shackle is only lifting one side of the leaf spring from the frame and the axle is in the center then the increase in height will be cut in half. Our shackles Start at $7.73 a piece and can be found here. http://www.barnes4wd.com/Shackles-Li...kles_c_35.html ![]()
Brad@Barnes4wd.com
Member # 87333
Looking to change out the axles in your rig and need all the parts to get your going. We have you cover no matter if you are putting Ford King Pin 60, a Gm 14 Bolt, a Dana 44 and we offer many more Axle Swap Combos. Our axle swap combo's are the best of the best, with these combo's you will be saving a 10% discount off our all ready low prices. When it comes to changing axles in a leaf sprung rig you want to get it right the first time, and forget about it. Like all of our products, they are made in the USA from USA steel. These combos include all the parts that you will need for your weekend axle swap.
• Four 10" x 5/8" U-Bolts With Tall Nuts and HD Washers • Two Spring perches • Two U-Bolt Plates • Two Bent Axle Shock Mounts Some kits do vary to fit you specific application. If you would like to exchange a item for one of a different size just let us know. Our Axle Swap Compos sell for 114.75 and can be found here. http://www.barnes4wd.com/Axle-Swap-Combo_c_39.html ![]()
Brad@Barnes4wd.com
Member # 87333
With tall tires and lockers a traction bar is just what the doctor orderd. This kit will eliminate axle wrap and save your u-joints and leaf springs
Kit includes One Pair of Three Link / Radius Arm Mount Three DOM Sleeves and Poly Bushings Two 4" long ¼" offset HD shackles One Tube Insert (7/8-14) 1 1/2" ID One 7/8-14 Jam nut High Misalignment Spacer - 3/4" to 5/8" Stainless Steel (pair) One Chromoly 7/8"- 14 X 3/4" Heim One Pair of Full Circle Bushing Mount ![]() http://www.barnes4wd.com/Anti-Wrap-T...Kit_p_195.html
Brad@Barnes4wd.com
Member # 87333
Thanks for the orders! Make sure the Stocking is hung tight before you drop this stuff in it
Brad@Barnes4wd.com
Member # 87333
To the Top
We ship same day!
Brad@Barnes4wd.com
Member # 87333
Time to get ready for the spring wheeling season
Brad@Barnes4wd.com
Member # 87333
All Pm's replied to.
Thanks for all the interest
Brad@Barnes4wd.com
Member # 87333
During the cold you might as well make some upgrades on your rig in the shop.
Brad@Barnes4wd.com
Member # 87333
Btt
Brad@Barnes4wd.com
Member # 87333
Lets get ready for EJS
![]() Shipping 6 days a week
#12 (permalink) |
Brad@Barnes4wd.com
Member # 87333
Not long till Easter Jeep Safari!
#13 (permalink) |
Member # 126796
Do you have anything for outboarding springs for full width axles?
At some point while using Jeep speak you will here a loud @#$PLOP$#@. That was your head being pulled out of your ass. Now clean the shit out of yours ears and listen. |
#14 (permalink) |
Brad@Barnes4wd.com
Member # 87333
Not at this time.
Thanks
#15 (permalink) |
Brad@Barnes4wd.com
Member # 87333
Btt:d
#16 (permalink) |
Brad@Barnes4wd.com
Member # 87333
All in stock ready to go
#17 (permalink) |
Brad@Barnes4wd.com
Member # 87333
BTT
#18 (permalink) |
Brad@Barnes4wd.com
Member # 87333
All PM's returned let me know if I missed you.
Thanks Have a great weekend
#21 (permalink) |
Brad@Barnes4wd.com
Member # 87333
Shipping to any US address would be $11.50 for the kit.
Thanks for your interest
#22 (permalink) |
Brad@Barnes4wd.com
Member # 87333
Weekend is here lets WHEEL
#23 (permalink) |
Brad@Barnes4wd.com
Member # 87333
All parts in stock and ready to ship
#24 (permalink) |
Brad@Barnes4wd.com
Member # 87333
We don’t mind if you would like to stop in to pick up some parts or see what we have.
#25 (permalink) |
Brad@Barnes4wd.com
Member # 87333
In the shop all day, let me know if I can help.
Thanks
