Brad@Barnes4wd.com
Member # 87333
All Kits ship with brackets predrilled to the correct bolt hole size and no extra cost!
![]() http://www.barnes4wd.com/3-Link-DIY-...ems_p_182.html This is the kit that has all the parts that we are always using in the shop for customers Three links suspensions. This has all the parts that are made to stand up to the abuse that Rock Crawlers and Trail Rigs see and then some. The kit includes. 1 x Axle Link Mount Pair 10 Deg 1 x Frame Link Mount 1 x Adjustable Inner Frame Link Mount Pair 0 Deg 1 x Link Tower 1 x Outside Frame Panhard / Trackbar Mounting Bracket 1 x Offset Axle Panhard Bracket 1 x Chromoly 3/4 - 16 X 3/4" Heim RH 1 x Chromoly 3/4 - 16 X 3/4" Heim LH 2 x High Misalignment Spacer - 3/4" to 5/8" Stainless Steel (pair) 1 x 3/4" - 16 Jam Nut RH 1 x 3/4" - 16 Jam Nut LH 1 x Tube Insert (3/4-16) 1" ID 1 1/4" OD Tube RH 1 x Tube Insert (3/4-16) 1" ID 1 1/4" OD Tube LH 3 x Chromoly 1 1/4"- 12 X 1" Heim RH 3 x Chromoly 1 1/4"- 12 X 1" Heim LH 6 x High Misalignment Spacer - 1" to 5/8" Stainless Steel (pair) 3 x 1-1/4" - 12 Jam Nut RH 3 x 1-1/4" - 12 Jam Nut LH 2 x Tube Insert (1-1/4-12) 1 1/2" ID 2" OD Tube RH 2 x Tube Insert (1-1/4-12) 1 1/2" ID 2" OD Tube LH 1 x Tube Insert (1-1/4-12) 1 1/2" ID 1.75" OD Tube RH 1 x Tube Insert (1-1/4-12) 1 1/2" ID 1.75" OD Tube LH This is great for the do it your self fabricators looking do their own 3 link system, and did we mention that the kit is 5% off of our regular great prices for the items individually! ![]() http://www.barnes4wd.com/3-Link-DIY-...int_p_144.html 1 x Axle Link Mount Pair 10 Deg 1 x Frame Link Mount 1 x Adjustable Inner Frame Link Mount Pair 0 Deg 1 x Link Tower 1 x Offset Axle Panhard Bracket 1 x Outside Frame Panhard / Trackbar Mounting Bracket 1 x Chromoly 3/4 - 16 X 3/4" Heim RH 1 x Chromoly 3/4 - 16 X 3/4" Heim LH 2 x High Misalignment Spacer - 3/4" to 5/8" Stainless Steel (pair) 1 x 3/4" - 16 Jam Nut RH 1 x 3/4" - 16 Jam Nut LH 1 x Tube Insert (3/4-16) 1" ID 1 1/4" OD Tube RH 1 x Tube Insert (3/4-16) 1" ID 1 1/4" OD Tube LH 3 x Currie Enterprises 2-1/2" Forged Johnny Joint - 1-1/4"-12 RH 3 x Currie Enterprises 2-1/2" Forged Johnny Joint - 1-1/4"-12 LH 3 x 1-1/4" - 12 Jam Nut RH 3 x 1-1/4" - 12 Jam Nut LH 2 x Tube Insert (1-1/4-12) 1 1/2" ID 2" OD Tube RH 2 x Tube Insert (1-1/4-12) 1 1/2" ID 2" OD Tube LH 1 x Tube Insert (1-1/4-12) 1 1/2" ID 1.75" OD Tube RH 1 x Tube Insert (1-1/4-12) 1 1/2" ID 1.75" OD Tube LH
Barnes 4WD ------------------------------ Email: sales@barnes4wd.com Shop # 828-551-7616 ------------------------------ www.Barnes4wd.com ------------------------------ https://www.facebook.com/pages/Barne...15253988524951 Subscribe to our Newsletter for Discount Codes and New Product Releases! Be Sure and check our website daily for the deal of the day! All Orders to Lower 48 States Ship Ground for $15 or Less |
Brad@Barnes4wd.com
Member # 87333
Thanks for the orders!
Brad@Barnes4wd.com
Member # 87333
Lots of rigs getting our 4 link and 3 link kit
Brad@Barnes4wd.com
Member # 87333
Good to talk to you Jim, let me know if you have any other questions.
Brad@Barnes4wd.com
Member # 87333
Be safe on the trails this weekend
Brad@Barnes4wd.com
Member # 87333
If you like Heims we can make a kit with those and save you some money
Brad@Barnes4wd.com
Member # 87333
As with any of our kits if you need to exchange any of the brackets for something else we offer we will be more than glad to make a kit that will best fit your project.
Brad@Barnes4wd.com
Member # 87333
Thanks for all the weekend orders!
Brad@Barnes4wd.com
Member # 87333
Updated kits.
Thanks
Member # 127245
The updated inner frame link mount is a great change. That is the 1 part that I had to totally cut up and re-make. Great Idea.
88 Sami 1.3 Propane, 5.14 T-Case, 4.10 FJ40 Axles on 36's |
#11 (permalink) | |
Brad@Barnes4wd.com
Member # 87333
#13 (permalink) |
Brad@Barnes4wd.com
Member # 87333
I do not have a picture that reflects all the latest changes that have been made to the kit, but I hope to shortly.
Thanks for your interest
#14 (permalink) |
Brad@Barnes4wd.com
Member # 87333
Heims or Johnny Joints you cant go wrong!
#15 (permalink) |
Brad@Barnes4wd.com
Member # 87333
All PM's returned
#16 (permalink) |
Brad@Barnes4wd.com
Member # 87333
Weekend is here lets wheel
#17 (permalink) |
Brad@Barnes4wd.com
Member # 87333
Another late day, thank you!
#18 (permalink) |
Brad@Barnes4wd.com
Member # 87333
One of our top sellers and for good reason
#19 (permalink) |
Brad@Barnes4wd.com
Member # 87333
Just add DOM and you are ready
#20 (permalink) |
Brad@Barnes4wd.com
Member # 87333
Do it right the first time.
#21 (permalink) |
Brad@Barnes4wd.com
Member # 87333
Just add DOM
#22 (permalink) |
Brad@Barnes4wd.com
Member # 87333
Works great with a 4 link behind it
#23 (permalink) |
Brad@Barnes4wd.com
Member # 87333
Weekend is here Lets Wheel
#24 (permalink) |
Brad@Barnes4wd.com
Member # 87333
Time to get ready for your winter project
#25 (permalink) |
Brad@Barnes4wd.com
Member # 87333
Kits in stock ready to ship
