Poison Spyder BFH Rear Bumpers - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > Vendor's Marketplace > Body/Armor
Old 02-24-2012, 10:53 AM   #1 (permalink)
Token Bronco Guy
Dusty's Avatar
Member # 16474
The Poison Spyder Customs BFH Rear Bumper is designed for those hardcore four-wheelers who value strength, simplicity and function. This bumper was literally "Built For the Hammers" with the best ground clearance and departure angle possible. It is no wider than the Jeep's rear body tub, with angled facets to improve its ability to slide over the rocks. The BFH is CNC laser-cut from high strength 3/16" plate steel, then precision brake-formed for an exact fit.
The basic rear BFH bumper has no provisions for a spare tire carrier. This bumper is intended for those hard-core wheelers who either wheel without a spare or strap the spare down into the bed of the Jeep. It may also be compatible with the OE tailgate-mounted spare tire carrier, depending on the size of the spare tire.
The optional Recovery Shackle Tabs are machined from 1" thick plate steel to provide a secure attachment point for 3/4" recovery shackles. These tabs are specifically engineered to match the angles of the BFH bumper to result in zero loss in departure angle.
Dusty Sharp
Marketing Director
- 951-849-5911 - Connect with us on:
Dusty is offline   Reply With Quote Quick reply to this message
Old 02-24-2012, 10:59 AM   #2 (permalink)
Token Bronco Guy
Dusty's Avatar
Member # 16474
SALE!!!!
We've dropped the price on the TJ/LJ and YJ versions of the BFH Rear Bumper to ONLY $199!
Dusty Sharp
Marketing Director
Old 03-14-2012, 03:29 PM   #3 (permalink)
Token Bronco Guy
Dusty's Avatar
Member # 16474
CJ OWNERS! We've confirmed fitment of our RockBrawler and BFH Rear Bumpers for CJ's! The universal mount design comes with captured hardware for TJ, YJ and CJ pre-installed, simply pop out the bolts you won't use for your application and bolt it on!
Dusty Sharp
Marketing Director
Old 03-27-2012, 11:02 AM   #4 (permalink)
Token Bronco Guy
Dusty's Avatar
Member # 16474
Both of Kha's rigs sporting the BFH Rear Bumper for JK
Dusty Sharp
Marketing Director
Old 11-28-2012, 02:04 PM   #5 (permalink)
Token Bronco Guy
Dusty's Avatar
Member # 16474
BFH Rear Bumpers for TJ-YJ-CJ are simple, clean and high clearance. Note that this Jeep also has a 1" body lift, in case you noticed the gap between the bumper and the body.
Dusty Sharp
Marketing Director
