RockstarFab Jeep Tub Sliders - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > Vendor's Marketplace > Body/Armor
Old 11-30-2005, 10:28 AM   #1 (permalink)
ARSENAL LED
MUCHADO's Avatar
Member # 21752
Send a message via AIM to MUCHADO
I am starting to sell products from RockstarFab, a small fabrication shop in Great Bend, KS. Big Jim is the owner/operator and does some awesome work. These tub sliders are a compilation of ideas Big Jim and I had... We took these out to Cathouse Ranch and Jim flopped his YJ on it's side in a ravine and drove out with only a scuff mark on the paint of the tub slider--same spot that another Jeep caved the side of his tub in. These mount just infront of the corner seam at the rear and toward the top of the tub. They will save your tub from getting pinched. I actually have used them as a step to hop into the back of the Jeep. They are very sturdy. Tubsliders for your Jeep CJ-7/YJ and can make them in any size you want. We even did a set for a scrambler! They are made from 1.75 HREW round tubing. The tubing is welded to 3/16 flat steel plate which measures 30 1/2 inches long. There is also a 3/16 flat steel plate that goes inside of your tub to make the tub slider strong and durable. The bolts are welded so you only need one hand to instal them once the holes are drilled. These could even be tied into a cage if you wanted to. PM for price
EDIT: here's a pic installed on a customer's rig.
LED LIGHTS - INEXPENSIVE - DURABLE - SERVICEABLE
ARSENAL-LED.COM
Use Promo Code "pirate4x4" for 10% off your order
PBB Vendor Thread HERE
"Like" us on Facebook
@Arsenal_LED on Instagram
MUCHADO is offline   Reply With Quote
Old 12-02-2005, 04:33 PM   #2 (permalink)
Member # 3310
PM me price on a set for a YJ, thanks.
JohnC is offline   Reply With Quote
Old 12-03-2005, 01:48 AM   #3 (permalink)
Member # 56925
1 set for a TJ
They come powdercoat or raw?
98 TJ w/ Stuff : [url]http://photobucket.com/albums/c85/Synpainter/[/url]
Custom Rustic & Log Furniture Maker
[I]Building my junk via the barter system
[/I]
Synpainter is offline   Reply With Quote
Old 12-03-2005, 08:32 AM   #4 (permalink)
zachv's Avatar
Member # 8108
That is a pretty sweet and fresh idea. You should see if they can make some that wrap around the flare about 3/4 of the way.
AtoZ Fabrication, Inc.
570-385-3931--shop
570-385-3932--fax
MADE IN AMERICA---and proud of it!!!
We also offer the best service and prices available on:
Advance Adapters
Clayton Offroad Suspension
Raceline beadlocks wheels
Amsteel Winchline and accessories
ORI struts and Radflo shocks
Read my story about Todd at F&S Racing in the Bad Sellers forum
zachv is offline   Reply With Quote
Old 12-03-2005, 11:07 AM   #5 (permalink)
ARSENAL LED
MUCHADO's Avatar
Member # 21752
PM's sent guys
Big Jim is workin on some new designs as we speak. The problem with it wrapping around is the plate that sandwiches the sheetmetal behind the slider spreads the load evenly and that's where you gain your strength.. if you have it go around the edge without a tie-in then you get leverage(think torque wrench) against the tub which may cause damage with a hard impact.. SOOO Jim said he's been trying to come up with a mount/brace for something that wraps around the corner that will maintain strength.
Originally Posted by Synpainter
1 set for a TJ
They come in raw to keep costs down and because everyone wants something different for finish (rattle can, bedliner, powder coat, automotive paint)...
ARSENAL-LED.COM
Old 12-06-2005, 04:55 PM   #6 (permalink)
B.O.H.I.C.A.
Toonces75's Avatar
Member # 55214
Hi, price on sliders for a CJ-7 sent to 72936. thanks
Toonces75 is offline   Reply With Quote
Old 12-07-2005, 02:50 PM   #7 (permalink)
ARSENAL LED
MUCHADO's Avatar
Member # 21752
PM's sent
ARSENAL-LED.COM
Old 12-13-2005, 01:13 PM   #8 (permalink)
ARSENAL LED
MUCHADO's Avatar
Member # 21752
Toonces75 you've got a package on the way!
ARSENAL-LED.COM
Old 12-13-2005, 01:54 PM   #9 (permalink)
MendoXJ's Avatar
Member # 26795
Send a message via AIM to MendoXJ
These things are pretty sweet. I havent had a chance to lay my jeep on its side yet to test em out but im sure they will hold up well. Buy em
-87 4runner, 7 Seater,Marlin Dual Ultimates,E-Lockers, 37's, Exo'd
-93 Bronco, Caged, Locked, 35's
MendoXJ is offline   Reply With Quote
Old 12-26-2005, 11:21 AM   #10 (permalink)
B.O.H.I.C.A.
Toonces75's Avatar
Member # 55214
I have mine on my Jeep now. They are really nice...........I am proud of them......thanks............
"Why did I build my Jeep that way you ask?" "Because of the infinte knowledge you Pirate Gods told me too!
Old 12-29-2005, 09:47 PM   #11 (permalink)
ARSENAL LED
MUCHADO's Avatar
Member # 21752
I'm glad you're happy with them! Send me some pics if you get a chance!
ARSENAL-LED.COM
Old 01-09-2006, 10:55 AM   #12 (permalink)
RedLJ's Avatar
Member # 64117
Have Ya'll done any for the L J bodies? Between the upper right corner of the flair and top body rail seems to be a sweet spot for impacts. Thanks
[FONT="Times New Roman"][COLOR="Red"][/COLOR][/FONT]It's an LJ and I'm working on it.
Everything I say is fully substantiated by my own opinion.
RedLJ is offline   Reply With Quote
Old 01-09-2006, 11:30 AM   #13 (permalink)
ARSENAL LED
MUCHADO's Avatar
Member # 21752
Have not done any for them, and the only thing I would be worried about is the gas tank filler neck on the driver's side. That's the problem we have with TJ's also. We can make one that would go in front of that filler no problem, but I don't know that there is room to mount the slider above the plastic for the filler. If there's over 2 inches between the gas filler and the body crease we can do it for the full length. If not, the driver's side would need to be smaller than the passenger side. Give me a PM, I can have you send me some measurements and see what we can do.
ARSENAL-LED.COM
Old 01-09-2006, 05:18 PM   #14 (permalink)
RedLJ's Avatar
Member # 64117
Hmmm, not gonna get 2 inches on the drivers side. Gonna have to rethink my plan.
Old 01-10-2006, 12:52 AM   #15 (permalink)
ARSENAL LED
MUCHADO's Avatar
Member # 21752
I'll keep an eye out for an LJ. I'm wondering if there is maybe a way to cut the plastic a bit and keep it looking clean? OR.. maybe we could leave a section of the supporting strap out on the driver's side slider.. then just have a kicker in between and still have that sandwich piece on the other side so it'll all have even support. I'll give Big Jim a call to see if it's feasable, he's the fab-man. I'm up for new ideas...
ARSENAL-LED.COM
Old 02-07-2006, 11:18 AM   #16 (permalink)
Member # 22836
Price on a set for a YJ. Thanks.
nosduj is offline   Reply With Quote
Old 02-21-2006, 12:36 PM   #17 (permalink)
JonsYJjeep's Avatar
Member # 47464
Price for a YJ shipped to 98310 , thanks
My 7/8 ton YJ build
JonsYJjeep is offline   Reply With Quote
Old 03-12-2006, 06:31 PM   #18 (permalink)
483fitter's Avatar
Member # 44072
price for a yj shipped to 95125, thanks
483fitter is offline   Reply With Quote
Old 03-23-2006, 04:43 PM   #19 (permalink)
Member # 26542
price for a YJ set shipped to 35213. thanks
89 YJ
Hard Rock Holley is online now   Reply With Quote
Old 03-25-2006, 12:36 AM   #20 (permalink)
ARSENAL LED
MUCHADO's Avatar
Member # 21752
PM sent
ARSENAL-LED.COM
Old 03-27-2006, 07:42 PM   #21 (permalink)
rkik's Avatar
Member # 34591
Check these out
No idea who makes them ... maybe custom.
rkik is offline   Reply With Quote
