4x Innovations Toyota Tacoma Tube doors - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > Vendor's Marketplace > Body/Armor
Old 09-18-2006, 08:15 PM   #1 (permalink)
4x Innovations
traxman25's Avatar
Member # 35227
Send a message via Yahoo to traxman25
I now have some 95.5-04 Tacoma tube doors in stock! I have both the Tacoma doors with a 1.75 inch bump out at the top and flat doors. They feature laser cut mounting plates, and simple laser cut latches that fit like a glove. No more rattling against the striker.
These doors are easy to install too.
1. Roll down the windows.
2. Remove the kick panels (the little plastic trim piece on the wall inside of the truck near your feat). Unplug the wiring harness, push out the rubber grommet and harness.
3. Remove the door swing limiter cover by lifting slightly, and pulling back on the plastic cover. Un bolt the bracket from the body using a 10 MM wrench of your choice (socket works easily with a 2 inch extension).
4. You are now ready to unbolt the door. These doors weight a lot, so a friend to help is handy, but not needed. If working by yourself, remove one bolt from the top hinge, on the door side of the hinge. Then remove both bolts from the bottom hinge, while supporting the door from the window frame (remember we opened the windows ). Next remove the final bolt from the top hinge. Remember, these things are hefty, so be careful to not loose control and end up damaging something. These bolts are a 12 mm head, a ratcheting box wrench works the best here, but a socket works as well.
5. Using the stock bolts, bolt up the tube door in the reverse order. The tube door only weighs in at 16.5 lbs, easy to handle by ones self.
Tacoma tube doors are $199 +shipping for a set of two doors (driver/passenger sides), bolt up, latch and latch hardware included. They come bare steel, ready to paint and bolt on. Be sure to check out 4xInnovations.com for more sweet parts too!
Thanks!
Also a side note for those who ordered doors in the past (June, July and early early August) if you have the ground latches, send me a PM with your name, invoice # (if you have it) and I'll send you a set of the new laser cut latches.
4x Innovations - Adam
Hardcore Toyota Rock Crawling Armor
1-608-348-4880
traxman25 is offline   Reply With Quote
Old 09-18-2006, 08:37 PM   #2 (permalink)
Renaud33's Avatar
Member # 23389
Send a message via AIM to Renaud33
I have a set on my 85' Runner and have seen them on a Tacoma close up. Doors are easy to install with the threaded plates. Received a free latch upgrade after 4xinnovations improved the latch design. Great product!! Price.
85' 4Runner - AP extreme lift, 37" PB Rockers, duals
TLCA Member# 16265
Renaud33 is offline   Reply With Quote
Old 09-19-2006, 07:26 AM   #3 (permalink)
4x Innovations
traxman25's Avatar
Member # 35227
I also have doors with and without the kick out for 84-88 pick ups, and 83-88 4 runners ready to ship. They are $189+ shipping ready to paint and bolt up.
Thanks!
1-608-348-4880
Old 09-22-2006, 04:13 PM   #4 (permalink)
4x Innovations
traxman25's Avatar
Member # 35227
tt for the weekend. I'll be here working all weekend. Feel free to shoot me an email or PM, I do call too.
1-608-348-4880
Old 09-26-2006, 08:40 PM   #5 (permalink)
4x Innovations
traxman25's Avatar
Member # 35227
I've got these sick doors in stock ready to ship! Also, check out our website for our new phone number, give us a call.
Thanks for the orders! Remember, killer parts don't have to empty the wallet.
1-608-348-4880
Old 10-16-2006, 03:22 PM   #6 (permalink)
4x Innovations
traxman25's Avatar
Member # 35227
Thanks for all the orders guys! I have more of these doors in stock and ready to go, they will ship right away. Unmatched quality and service.
We also have online ordering to make your life simpler!
Thanks again,
Adam
1-608-348-4880
Old 10-18-2006, 07:07 PM   #7 (permalink)
4x Innovations
traxman25's Avatar
Member # 35227
tt, thanks!
1-608-348-4880
Old 12-17-2006, 06:51 AM   #8 (permalink)
4x Innovations
traxman25's Avatar
Member # 35227
These are in stock and ready to ship. Thanks for all the orders!
1-608-348-4880
Old 03-15-2011, 05:35 PM   #9 (permalink)
Member # 171797
old thread, but are these still the same design?
Trailkingzj is offline   Reply With Quote
Old 03-15-2011, 07:20 PM   #10 (permalink)
4x Innovations
traxman25's Avatar
Member # 35227
Same Door, GREAT new latch system. Check them out on our web site here: http://4xinnovations.com/p-TD03.html
1-608-348-4880
Old 04-20-2011, 08:01 PM   #11 (permalink)
4x Innovations
traxman25's Avatar
Member # 35227
Btt!
1-608-348-4880
Old 05-09-2011, 03:45 PM   #12 (permalink)
4x Innovations
traxman25's Avatar
Member # 35227
Toyota Tacoma Tube doors available at 4x Innovations!
1-608-348-4880
Old 06-24-2011, 05:04 AM   #13 (permalink)
Member # 189903
Check out these Tacoma Tube Doors from 4x Innovations!
4xinnovations is offline   Reply With Quote
Old 07-11-2011, 07:30 AM   #14 (permalink)
Member # 189903
Bump to the top!
Old 08-08-2011, 06:10 AM   #15 (permalink)
Member # 189903
Check out these Tube Doors available at 4x Innovations!
Old 09-02-2011, 05:09 AM   #16 (permalink)
Member # 189903
Check out these tube doors from 4x Innovations!
