4x Innovations
Toyota Tube Bumpers from 4x Innovations
4x Innovations has a wide selection of winch mount bumpers and non-winch mount bumpers for Toyota trucks. These bumpers are being used and abused by many on the trails. Made from DOM where it counts for strength and HREW for supports these bumpers are made to be cost effective, strong but lighter weight, and have a great look, style and feel that can be customized to suit your liking. With our bolt on bracket and options like winch mounts, multiple stinger types, and even free body lift customization (up to 3") you can get what you want for a price you can afford.
Heres how the options lay out. Start out by selecting the proper bumper base model for your truck, then select if you want it to be a winch mount bumper or a non winch mount bumper. All base bumpers are shipped fully welded ready to bolt and/or weld to your truck. Next select your stinger type if you want one. . We also have a new weld on front frame support to reinforce or replace your weaker stock bumper mounting points. Updated 5/15/09 All bumper are now bolt on including our bolt on bracket! The bracket is a laser cut, CNC formed bracket that comes welded to the bumper so you can bolt the bumper to your stock mounts. It is still listed below for the fabricator who'd like to buy just the bracket. The options lay out like this: Pick Ups and 4 Runners * Fit....................................... Item...... . Price * 84-85 Pick up and 4 Runner.......Base w/o Winch Mnt $285.00 * 84-85 Pick up and 4 runner.......Base w/ Winch Mnt ..$340.00 * 86-88 Pick up.........................Base w/o Winch Mnt...$285.00 * 86-88 Pick up.........................Base w/ Winch Mnt ..$340.00 * 86-89 4 Runner.......................Base w/o Winch Mnt...$285.00 * 86-89 4 runner........................Base w/ Winch Mnt ..$340.00 * 90-95 4 Runner.......................Base w/o Winch Mnt...$305.00 * 90-95 4 runner........................Base w/ Winch Mnt ..$360.00 * ............................................Single Bend Stinger ..$10.00 * ............................................Double Bend Stinger. $15.00 * ............ .....Frame Support Kit.. ..$30.00 Pictures are posted below.
4x Innovations - Adam Hardcore Toyota Rock Crawling Armor 1-608-348-4880
Member # 64675
price with shipping for an 87 w/winch mount and single bend stinger and bolt on bracket shipped to 97056. thank you
Member # 94253
Im interested in your pickup bumper, could you build it to fit a 94 SAS pickup?
by the way, i've got your sliders on my rig right now, great work!
-Jordan Trickett- 1994 Toyota pile of crap one ton tube thing :D [URL="http://pirate4x4.com/forum/showthread.php?t=870408"]my build[/URL] |
4x Innovations
I do have bumpers in a weld on version for the 94 pick up. I am working on getting the bolt on bracket fit up to the 3rd gen trucks. I hope to have that figured out by the end of this week.
Glad to see another happy slider customer! Hopefully we can get you set up in a bumper too.
Member # 94253
I would be happy with a weld on version.
what exactly is the frame support kit?
#8 (permalink) | |
4x Innovations
This plate would be a good idea if you are running a weld on bumper. It will give you a thicker, stronger surface to support the bumper from. It's a good idea on the bolt on bumpers to add support to the weak stock frame horns that tend to bend when pulling hard, or if you hit the stinger. Our bolt on brackets are designed to combat this, and add additional support, but it is still recommended to reinforce the front of the frame.
Member # 94253
oh ok, the frame support sounds like a good idea.
Well then i suppose i'd need to get a quote for a winch bumper with a single bend stinger and the frame support for my 94 SAS P/U. The winch im running is a warn XD9000i in case you need to know that. shipping to 98026
#10 (permalink) | |
4x Innovations
FYI in case anyone else is wondering, these bumpers will fit all winches with the standard mounting pattern (4.5x10 with a 3/8" bolt). Be ware that some winches (the Warn Powerpack for example) may require slight grill modifications. Give me a call if you plan to run a winch like that and don't want to cut the grill, we can always make a bumper to fit!
Member # 20195
will the 95.5 bumpers for tacos fit the same year runners?
83 toy, 5.29's 36" IRoks, Detroit rear, Auburn limited slip front...now with dual tcases & TDD spacers front and rear [QUOTE=Dr.Van Falk]Seriously, once you start dying your hair you're only a boob job away from being able to do porn in Brazil.[/QUOTE] |
#12 (permalink) |
4x Innovations
That I do not know, sorry. I'll have pictures up of the 95.5 bumper soon so maybe you can compare the mounting to see if they are close. From there I can modify pretty much anything else about the bumper.
#18 (permalink) |
4x Innovations
2nd Gen 4 Runner Bumpers are here!
We now have 2nd Gen 4 Runner front bumpers available!
Check out our bumpers page or the first post of this thread for pricing. Thanks!
#19 (permalink) |
4x Innovations
Going wheeling this summer? Don't forget to protect the front of your truck and give yourself a great winch mount with out weighing down your front end! These bumpers range from 45 to 55 lbs with out winch!
#20 (permalink) |
Member # 20195
hey, you making those tube doors for tacoma quad cabs?
#22 (permalink) | |
Member # 20195
#23 (permalink) |
4x Innovations
If you are talking about an 05+ we do not have tube doors that will fit.
All bumper are now bolt on including our bolt on bracket! The bracket is a laser cut, CNC formed bracket that comes welded to the bumper so you can bolt the bumper to your stock mounts. It is still listed for the fabricator who'd like to buy just the bracket.
