K.O.R.E. Jeep TJ Cage Builder Kits - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > Vendor's Marketplace > Body/Armor
Old 10-17-2007, 04:23 PM   #1 (permalink)
Member # 8563
After quite a bit of request for these, we've put together a kit to allow for easy fabrication of a cage for your Jeep TJs. This is an easy alternative to building a through-the-dash cage.
These brackets are made to simply bolt to the dash and through the floor effectively creating the front A pillar for the rest of the roll cage to be built off of.
The kits come with the two front 'A Pillar' plates that are CNC cut from 3/16" thick steel and then formed on a press brake for ultimate strength. Also included with the kits are two 3/16" thick gussets for added support.
[URL="www.kore4x4customs.com"][SIZE="3"]KORE4x4Customs.com[/SIZE][/URL]
[SIZE="3"][COLOR="DarkRed"]
[email]Kenneth@KORE4x4Customs.com[/email][/COLOR][/SIZE]
[CENTER][SIZE="5"][COLOR="Yellow"][URL="http://www.pirate4x4.com/forum/showthread.php?t=988162"]KORE Defender Chassis...Designed for Speed![/URL][/COLOR][/SIZE][/CENTER]
TJ Ken is offline   Reply With Quote
Old 10-17-2007, 09:11 PM   #2 (permalink)
Member # 37077
Any pic's of these in a Jeep?
Looks real good!
Johno33772 is offline   Reply With Quote
Old 11-06-2007, 08:20 PM   #3 (permalink)
Member # 8563
Thanks for the props!! and I apologize for the delayed response.
Here's some pics we have from when we first bolted them in.....these pics don't have the 90* gusset on them yet....
At least it gives you an idea of how it goes together.
All of the torx bolts line up perfectly...You just bolt these up with the supplied 90 degree guesset welded in (I'd suggest removing cage before doing this) and then build off of these brackets for a simple yet functional sport cage for your TJ's.
This hole shows were it will bolt through the factory drain hole location. It also shows where some of that body filler needs to be removed in order for the brackets to sit down perfectly.
We also offer the TJ B Pillar footplates for those of you that are planning on completely getting rid of your factory TJ rollcage. We CNC cut these in-house and bend them on our press brake to allow for a perfect fit just like the factory B pillar foot plates.
In fact we just used a set for my new cage in my TJ.....
Old 03-22-2008, 09:51 PM   #4 (permalink)
The Devils Trailboss
UCTJ's Avatar
Member # 51571
Shipping on the A pillar to 78148. Also how much are the pads for the B pillar?
UCTJ is offline   Reply With Quote
Old 03-27-2008, 02:53 PM   #5 (permalink)
Member # 8563
Sent you a PM
Thanks
-K.
Old 10-14-2008, 03:21 PM   #6 (permalink)
Checkbook Fabricator
CJ5_JEFF's Avatar
Member # 114426
Are you guys still making the A Pillars? PM me if you are.
CJ5_JEFF is offline   Reply With Quote
Old 10-14-2008, 03:43 PM   #7 (permalink)
Member # 25325
Send a message via AIM to redranger4.0
A pillar setup to 02120
Bent Fabrications EVO4
Steering Rocks
47" LTB's
Magnacharged LM7
redranger4.0 is online now   Reply With Quote
Old 11-21-2008, 04:17 PM   #8 (permalink)
Member # 123962
Do you still make these???
If so can you PM me about shipping to Canada please and thank you
FrankieRubicane is offline   Reply With Quote
Old 11-24-2008, 02:52 PM   #9 (permalink)
littleblackyj's Avatar
Member # 42312
Send a message via AIM to littleblackyj
dang them are cool
05 jeep rubicon... pretty stock
littleblackyj is offline   Reply With Quote
Old 11-24-2008, 03:32 PM   #10 (permalink)
Member # 8563
$210
Yes we still produce these.....$210
If you need a shipping quote still please post up or PM me... I'll have some time over the next couple days to get quotes out to everyone.
