1st Gen 4runner rear corner panel protection
Addicted Offroad is now offering our "Straight Jacket" rear corner panel protection for 1st Generation 4runners(patent pending). Other models to come shortly as well!
These panels are made from 3/16" cold roll steel and are press bent to conform to the body as tightly as possible. Each panel will be drilled and countersunk for 8-1/4" allen head bolts. Powder coating is also available at additional cost. The lower end folds under to the pinch weld to add strength and protection. For those of you who don't want to bob your 4runner, but don't want it beat to hell either, this is the product for you! Or, for those that want to Bob your rig, and want to minimize body work, just cut them down to suit and be done with it! We are offering an introductory price of $225/set for unfinished steel. Powder coating available as well. These panels will be in full production within the next 2-3 weeks. We should have these installed on a rig later this week, and I will update with better pics as soon as possible. http://www.addictedoffroad.com/cornerpanels.html
Scotty |
Unfortunately, that is a very expensive mod. It requires a stamping press, unless its welded on and would add a lot more expense to it. We will definitely consider in the future, but for now, its not in the cards. A die like that would run around $20K to have built.
Scotty |
#4 (permalink) | |
Member # 80413
89 4runner -22re,W56, 35" Boggers's, welded rear, SAS 00 4runner -OME Lift, 33" MTZ' supercharged |
Jeeps use a flat, simple 6" radius die for the bend. Its a simple, brainless setup. However, a die like this literally runs around $20k though:
That is a full wrap around panel for an Early Bronco. They only run $400/set. ![]() Chuck had 100 customers give him a $200 deposit on a set of panels to be able to afford to build said panel. Then when the panels were done, they paid another $100/ea for them. Only the first 100 got that price. Everyone else paid $400/set.
Scotty |
Member # 54522
the final product looks great. any pics of one that has been banged up and scraped? it seams like the panel would stay streight and just bend the sheet metal around it?
86 4runner 7MGE bobed, exo, SAS on 38s, 5.29, fully locked with duals/4.7 and 30spl longs |
These panels look kick ass and I would love a set. My only concern is most of the major trail carnage I've encountered has always been to the corners. Sure they would be great to slide on but once that rock gets passed the panels it takes out your corners and lights. I'd hate to drop my hard earned cash on a set, slap 'em on, and crush the hell out of my corners. You take Visa?
You'll pry my gun from my cold dead hand. You'll pry my Toyota from my other cold dead hand. |
#12 (permalink) | |
Scotty |
#13 (permalink) | |
www.12voltguy.com
Member # 40
maybe tou can have them made as a cast, should be way cheaper to do then a press (only the corners) maybe without the pesky tail lights so it's solid and new lights can be mounted in the gate ![]() when are you making 90+ 4 runners?
12voltguy info@12voltguy.com--davezoffroadperformance.com # 530.532.4529![]() TTC 2010 1989 BRONCO -Awesome web development for your business. www.mudnworks.com mud@mudnworks.comPat's W I D E TOYOTA Front Axle --07 KTM 450XC----with "stuff" |
#14 (permalink) | |
Each edge will have a slightly smoother line to it than below.
Scotty |
#15 (permalink) | |
www.12voltguy.com
Member # 40
It's gota make $$ if you are going to make them, nice product
#23 (permalink) |
Member # 25600
These would not be so great for people who have winters with snow. condensation and or salt gets in between and its the end. Rust Cancer.
85 4Runner 35" M/T no lift (fender trim), 5.29, spooled rear, Marlin Crawler dual T-cases, Smurfields, home made can back& pull pal,headers, k&n, Premier power welder, dual batteries, armor, etc. 82 custom short bed (show truck) swapped in a 22RE with W56 transmission riding on 35" BFG's, Sold... |
