Member # 120418
TJ Drop Down Tail Gate Conversion Kit
Convert your current swing out YJ, TJ, LJ tailgate to a fold down tailgate.
Now able to support over 400 lbs . Converts your existing tail gate from a swing out to a fold down design. Will not interfere with your factory hard top or soft top. Tailgate will remain lockable, and rattle free. Kit is 100% complete with hinges, cables, brackets, fastener's, & instructions. All brackets are laser cut out of 3/16" or 3/8" steel and formed on a press break. All exterior bolts are stainless steel with powder coated hinges. Installs with minimal shop tools, and no welding required. This is the only kit of its kind , other people have used Jeep CJ tailgates to perform a similar function, they however...are not compatible with your hard top, not lockable, and the color will not match. http://www.swagoffroad.com/YJ-TJ-Dro...-Kit_p_25.html Click link below to see tailgate demo on YouTube. SWAG Off Road Jeep Wrangler 97-06 TJ & LJ Fold Down Tailgate Conversion Kit - YouTube ![]() ![]() ![]() [/URL]Hot off the laser cutter......."Flat Back" Drop Down Tailgate Conversion Kit For Your YJ-TJ-LJ Because I can't leave well enough alone, I made a few optional additions to the drop down tailgate kit. Two panels made out strong yet light weight 3/16" aluminum. This will compliment the aluminum corners that my Jeep will soon be wearing. I am calling this kit the "Flat Back" drop down tailgate kit. I incorporated the hinge hole locations and toggle latch that were previously on three separate plates. It cleaned up the look of the drop down tailgate kit, hence the name "Flat Back". As an option, I am selling just the aluminum plates by themselves for those of you who have purchased a kit from me previously. The only change to installing these two aluminum panels is the addition of a new hole next to the factory latch. All other holes will line up with previously drilled holes in your tailgate. ![]() http://www.swagoffroad.com/Flat_Back_Tail_Gate.html
Swagoffroad.com Innovative fabrication tools, & Drop down tailgate kits for YJ's, TJ's and JK's. Visit us on Facebook Last edited by Swag Off Road; 10-13-2008 at 09:27 PM. Reason: Added YJ and LJ to the mix |
Member # 22646
It looks like a nice/stout setup....but it seems like $190 is kind of expensive for some hinges,cables and a couple of plates. Not bashing you or your product, but I think people would be more apt to buy this kit if the price was a bit lower. Just my .02.
" Never underestimate the power of idiots in large groups" |
GM at TWF
1.) How did you figure out the 260lb weight rating?
2.) Can you show a better picture of how it hooks up to the tub? It doesn't look like you are able to retain your back seat from the picture you posted. 3.) Black doesn't match the blue jeep I want to put it on. The black hinges you posted don't match the white jeep you put them on. What do you mean by, "it will match"??
ANDY<--- ME! TrailWorthyFab.com<--- THE BEST DOUBLE BEAD LOCKS! Project: Dookey's revenge<--- My Junk! OFF ROAD GEAR<--COOL SWAG! |
#4 (permalink) | |
Member # 120418
Rugger, I updated the website last night and dropped the price down. I forgot that I mentioned the price on this post. There are 9 laser cut brackets, some 30 fasteners, hinges, cables, toggle clamp, and 5 bent brackets in this kit. It seems like a bit of coin but it adds up quick on my end. On a plus side shipping is not a killer as it fits in a flat rate box.
Swagoffroad.com Innovative fabrication tools, & Drop down tailgate kits for YJ's, TJ's and JK's. Visit us on Facebook |
#5 (permalink) | |
Member # 120418
at 70lbs it will safely hold 260lbs. At some point the hinges will bend.2) I have a steel storage box in the rear. It is an off the shelf item that is designed to fit behind the rear seat about 10" deep. This kit will work with your rear seat. 3) All steel brackets come unpainted. I originally had them painted to match the Jeep but I was trying to show off the hinges and white on white did a poor job of that.
Member # 28155
Will this kit work with a '03 to '06 Wrangler?
This is what we build and have been thinking about a truck style tailgate. http://www.rubitrux.com/gallery.htm |
#7 (permalink) | |
Member # 120418
Yes, this kit will work on all TJ's & LJ's 97-06. Let me know if I can help you guys in any way. Thanks Troy
Member # 120418
I will be releasing a YJ kit towards the end of this month. I will post when this kit is available.
Member # 120418
Since your CJ tailgate already has the mounting locations for the top of the hinge, you would use the entire kit that I sell, minus the two web brackets that fit in the lower outside edges of the tail gate.
#12 (permalink) |
Member # 120418
I just finished creating the Jeep YJ fold down tailgate conversion kits, I have parts in hand, ready to ship.
![]() Take a look http://www.youtube.com/watch?v=1zfVf0WL7LI
#14 (permalink) |
Moderator
Member # 5861
prettyu cool product and woudl definitely have saved me some time. How do the lower hinges bolt to the tub, do you need to cut the tub from underneath to mount the nuts inside? I had to on my Yj, so if this kit doe snot require that it will savbe a lot of hassle.
Very cool idea to set it up very clean. Are you able to sell with the spider web look? One idea woudl be to have a bottle opener on that area, real tailgate party, hehe! |
#15 (permalink) | |
Member # 120418
The webs are hit and miss, some love them some don't, If you have a grinder they can be removed in seconds.
#16 (permalink) |
I gotta agree.
Will the tailgate flex enough to notice if you don't install the pin? I understand if you tried keeping a spare mounted on the gate, but if there is no weight on it will it whistle or not seal to the top without the pin? I like it otherwise
[URL=http://www.pirate4x4.com/forum/showthread.php?t=302597]01 Stretch TJ project here[/URL] [URL="http://s41.photobucket.com/albums/e279/Kevin071572/"]My photobucket albums[/URL] [url]www.4x4support.com[/url] |
#17 (permalink) | |
Member # 120418
I could use an electric solinoid with a 12 volt momentary push button to do the work but then It will cost too much.....
#19 (permalink) | |
Member # 120418
#20 (permalink) |
Member # 93421
totaly missed that.. but now that i look at the YJ kit, i think the TJ kit will work better for my set up..
or can you make me a TJ style latch for a YJ.. or would it be better to just go with the TJ and modify it if needed???? Last edited by XratedGixxer; 10-15-2008 at 09:38 PM. |
#21 (permalink) |
Member # 120418
I can take a hint; I do appreciate the constructive criticism, as I am still putting my finger on the pulse of what the Pirate 4x4 crowd wants. I will call the YJ back in the shop to create the two additional plates to replicate the look of the TJ kit. It will be ~2-3 weeks until I get these parts back from the laser shop.
However, the only difference between the TJ kit and the YJ kit are the two passenger side plates on the tub.
#22 (permalink) |
Member # 110184
I'm ready to order them when you get them. Can you PM?? Sooner the better! Thanks!!!
Life is tough, it's even tougher when you're stupid.- John Wayne 91 YJ, 5.3, TH400, Atlas 3.8, 35 spl 60's f&r Pick up your trash you nancy little bastards or sell that shit and go buy a fawkin low rider so you can be around more of your own kind! :flipoff: |
#24 (permalink) | |
#25 (permalink) |
Member # 120418
Gents,
I have redesigned the brackets on the YJ tailgate kit simular to the TJ kit. I currently have all parts in stock and I'm ready to ship. ![]() Take look http://www.swagoffroad.com/YJ_Tail_Gate.html
