Member # 85486
Sniper Fab Cage Kits - YJ & TJ
Soon to be released.... Target price $995....... Pre-cut, bent and notched tube along with all required mounting plates and custom gussets!
Sniper Fabworks LLC www.sniperfab.com Check out our chassis threads. 2 seater 4 seater What can we build for you?? Like Us on Facebook and follow along with our current projects.. http://www.facebook.com/sniperfabworks We don't do PM...so please use email sales@sniperfab.com if you have questions. Thanks |
Member # 85486
We will be offering our TJ cage in 2 different options. You will have the option of a tube A-Pillar or our TJ A-Pillar Brackets to tie into. The tube A-Pillar will require modifying the dash for the tube to go donw through. Otherwise, the TJ A-Pillar brackets require no cutting/modifying the dash.....
The price for both YJ and TJ cages are targeted to be the same price - $995. The TJ cage is completed already and going into production. We will try and get pictures up as soon as we get one the model out of powder coat and re-installed.... TJ and YJ models are almost identical in looks. The only real differences between the YJ & TJ cages are the obvious B-Pillar mounts, TJ factory seat belt options and TJ A-Pillar options.
Member # 85486
The cage can be modified very easly to be a fast back for 2 seaters. It was designed to be convertable!!
Member # 8540
Would pricing remain the same if equivalent changes were to be made to the kit?
For example: change the double hoop in the middle of the B-pilar to a more traditional setup where all four cross braces intersect near the middle of the B-pilar. There are also a couple things in the back I would like to slightly modify but could be handled by shipping the tubing a little long then I could modify it. I have the tools just not the bender. I am excited to see a full cage for YJs. I have always liked the one Poly makes for the TJ but felt left out as a YJ owner.
92YJ/2.5L/HD4:1D300/F&R D44/5:38/36 SX/99"WB Nothing is stronger than stupid... |
Member # 85486
Yes... Both soft and hard tops will fit fine!
#15 (permalink) | |
Member # 85486
#16 (permalink) |
Member # 85486
Here:
We will be looking at offering this cage we did a few months ago!!!
#17 (permalink) |
Member # 85486
Don't count it out! We will see............
#19 (permalink) |
Member # 20092
how about CJ-7s? Since the yj and cj are some darn close, it seems to me it should be a direct swap.
Don, nice work. I really like that design. Makes me want to rip out the PSC cage I have and go to this
'94 Toyota Land Cruiser FJZ80 - Vortec L33 5.3l, 4L60e, elocked, 3" OME lift, 315 KM2s, Warn 8074. |
#20 (permalink) |
Member # 85486
Yes, without any problem.
See post #9 in this thread...
#21 (permalink) |
Don are you going to add the tabs for a soft top if requested to do so, and looking at the YJ cage, when you release the TJ cage are you going to have the crossbar with the seatbelt tabs as an option? Thanks Don, looks great I will send you pics of all your body armor on my rig. Unfortunately I have been at a bit of a stand still with the build.
#22 (permalink) | |
Member # 85486
#24 (permalink) |
vayacondios
Member # 87698
I'm guessing 1.75 tubing
---- 80 cjunk7, with stuff--SOLD new build... 90 yjunk, longer, wider, more stuff, fasten your seat belt, it makes it harder for the aliens to suck you out of your rig ---- NRA LIFE MEMBER ---- |
