customizable rock sliders - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > Vendor's Marketplace > Body/Armor
Old 02-08-2009, 04:14 PM   #1 (permalink)
DIY4X's Avatar
Member # 63837
$245 for the base unit you see here (25* up rotation). There are lots of options to customize these to your liking! Our fixtures are set up to allow 25* of rotation in the "rash" tube either up or down or any 5* increment in between. 25* of up rotation is as close to the door as I'd like to get. Maximum Clearance to the obstacles. 25* down of course is a loss of clearance. This may be an option for some who need a leg up into their rig, think step. 0* or flat out is going to keep your rockers the furthest away from the obstacles.
Base unit as pictured comes with a standard center stantion tube. Optionally you can have it with 2 stantion tubes equally spaced. We can also do fill plates with 7 ga. steel and burn them out to look however you like, Screen names, Club names, logos.... whatever floats the boat! This is a valuable option. Keeps feet from getting caught in between the main tube and the rash tube! I can't imagine how much it'd hurt if your ankle got caught in there and you fell! OUCH!
Some of our features, ends of the main tube are cut at a 45* and capped to ease transitions. Mounting hardware is included but not shown in the photos. 6 - 3/8" grade 8 bolts and nuts per side along with a backing plate for the rocker support. This helps spread the load of the bolts over the greatest area possible. Gusseted mounting brackets.
Degree changes are no extra charge. Extra stantion tube is minimal and fill plates are case by case.
On to the pics!
SUPPORT THE BLUE RIBBON COALITION!!!!
Specialty off road shop. In house fabrication for just about anything you might need.
SAS Kit coming soon!
712-472-0200 Order line
712-479-2252 Tech support
www.diy4x.com
DIY4X is offline   Reply With Quote
Old 02-13-2009, 07:01 PM   #2 (permalink)
DIY4X's Avatar
Member # 63837
www.diy4x.com
Old 02-20-2009, 05:43 PM   #3 (permalink)
DIY4X's Avatar
Member # 63837
bump
www.diy4x.com
Old 02-24-2009, 06:33 PM   #4 (permalink)
DIY4X's Avatar
Member # 63837
Thanks for the orders!!
www.diy4x.com
Old 02-27-2009, 10:01 AM   #5 (permalink)
DIY4X's Avatar
Member # 63837
www.diy4x.com
Old 03-12-2009, 06:59 AM   #6 (permalink)
DIY4X's Avatar
Member # 63837
btt
www.diy4x.com
Old 03-17-2009, 05:57 AM   #7 (permalink)
DIY4X's Avatar
Member # 63837
up
www.diy4x.com
Old 03-23-2009, 06:53 PM   #8 (permalink)
DIY4X's Avatar
Member # 63837
btt
www.diy4x.com
Old 03-29-2009, 10:29 AM   #9 (permalink)
DIY4X's Avatar
Member # 63837
up
www.diy4x.com
Old 04-08-2009, 05:13 PM   #10 (permalink)
DIY4X's Avatar
Member # 63837
www.diy4x.com
Old 04-14-2009, 02:52 PM   #11 (permalink)
DIY4X's Avatar
Member # 63837
www.diy4x.com
Old 04-27-2009, 06:48 PM   #12 (permalink)
DIY4X's Avatar
Member # 63837
www.diy4x.com
Old 05-05-2009, 04:46 PM   #13 (permalink)
DIY4X's Avatar
Member # 63837
bump
www.diy4x.com
Old 05-13-2009, 01:12 PM   #14 (permalink)
DIY4X's Avatar
Member # 63837
ttt
www.diy4x.com
Old 05-19-2009, 07:53 PM   #15 (permalink)
DIY4X's Avatar
Member # 63837
www.diy4x.com
Old 05-26-2009, 07:07 PM   #16 (permalink)
DIY4X's Avatar
Member # 63837
www.diy4x.com
Old 07-01-2009, 06:59 PM   #17 (permalink)
DIY4X's Avatar
Member # 63837
www.diy4x.com
Old 07-12-2009, 05:59 PM   #18 (permalink)
DIY4X's Avatar
Member # 63837
Up
www.diy4x.com
Old 07-19-2009, 12:03 PM   #19 (permalink)
DIY4X's Avatar
Member # 63837
Bump
www.diy4x.com
Old 07-20-2009, 08:15 PM   #20 (permalink)
Member # 123514
Send a message via AIM to frikenwoodro Send a message via Yahoo to frikenwoodro
Got any pics of them installed by chance?
I don't build it pretty I build it to function.
frikenwoodro is offline   Reply With Quote
Old 07-22-2009, 11:58 AM   #21 (permalink)
Member # 112985
Where do they bolt on?? frame??
Your truck is just an image of you, so mine is bad and nasty!!!
orbot is offline   Reply With Quote
Old 07-23-2009, 11:41 PM   #22 (permalink)
DIY4X's Avatar
Member # 63837
They bolt to the body mount cross brace.
www.diy4x.com
Old 08-06-2009, 05:38 AM   #23 (permalink)
DIY4X's Avatar
Member # 63837
top
www.diy4x.com
Old 08-17-2009, 05:46 PM   #24 (permalink)
DIY4X's Avatar
Member # 63837
Thanks for all the orders!
Don't forget, We can do custom work also!!
www.diy4x.com
Old 08-17-2009, 08:52 PM   #25 (permalink)
dfl701's Avatar
Member # 126764
+1! great lookin sliders Kert! yet again awesome work
83 k5 with typical rust
dfl701 is offline   Reply With Quote
