Something Simple, Weld Washers! - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > Vendor's Marketplace > Body/Armor
Old 09-18-2009, 10:15 PM   #1 (permalink)
Gravel Maker's Avatar
Member # 51387
Send a message via Yahoo to Gravel Maker
Arrow Something Simple, Weld Washers!
These are some of the simple things that really come in handy when tying it all together. They will really add strength where you need it without adding unneccessary weight. Many will use them with the "V" edge down when using a MIG for easy penetration, I like them flat when I TIG for a clean, tight presentation thats just as strong.
These are 1020 steel but 7/32" thick so no need for Chromoly and if its not going to be heat treated why bother anyway....They are available with a 3/4", 5/8", 9/16", or 1/2" holes and are 6 for $10....
And for after the hole has already gone oblong here are our Fixit Weld Washers
http://www.ruffstuffspecialties.com/...forplates.html
Dan Fredrickson
......"The NEW Industry Standard"
Tech/Sales 916.600.1945
You can SAY anything, its what you DO that matters!
Gravel Maker is offline   Reply With Quote Quick reply to this message
Old 09-19-2009, 12:34 AM   #2 (permalink)
pro web-wheeler
RedBullJeep's Avatar
Member # 12217
Great...now you tell us! We just placed a rod end order a few days ago and now will have to pay for an additional shipment!
On another note, the 5/8"...what is the diameter of the outer portion of the bevel? We will be picking up hardened washers for our F911 hardware and want to know if the diameters are remotely close.
RedBullJeep is offline   Reply With Quote Quick reply to this message
Old 09-19-2009, 09:08 PM   #3 (permalink)
Member # 51387
Sorry Dustin....
I didn't see this til now, I am working tommorrow and I will measure that portion when I get in. On another note, sold 4 sets of these today so I guess someone wanted them at a fair price! I have seen a couple of online shops sell them for about $3 each and thats just a bit carried away
Dan Fredrickson
Old 09-19-2009, 10:23 PM   #4 (permalink)
Member # 62686
Whats the OD on these? Im assuming they are at least wide enough that a std bolt head will not hang over, but we all know what happens when you assume.
FrkyMnky1487 is offline   Reply With Quote Quick reply to this message
Old 09-19-2009, 10:36 PM   #5 (permalink)
Member # 51387
Good question....
It turns out I had 2 in my pocket so you and Dustin won't have to wait til tommorrow....
The overall diameter is 1 1/4" and the apex of the bevel is 15/16"....The 2 in the pics are 5/8" & 3/4" so they may appear smaller...
Dan Fredrickson
Old 10-12-2009, 10:58 AM   #6 (permalink)
Member # 51387
Thanks for thinking ahead!
Using these will usually fix the problem before it becomes a problem
Dan Fredrickson
Old 10-18-2009, 12:44 PM   #7 (permalink)
Member # 51387
Sometimes its the little things....
That can make a difference as to whether or not something breaks....
Dan Fredrickson
Old 10-19-2009, 09:39 AM   #8 (permalink)
Member # 51387
Thats right...
These are thr stuff
Dan Fredrickson
Old 10-28-2009, 12:25 AM   #9 (permalink)
Member # 51387
What good does armor do....
If the bolts mounting it tear out? Thing before it happens, preventative maintenance!
Dan Fredrickson
Old 11-14-2009, 07:18 PM   #10 (permalink)
Member # 51387
Sometimes its not armor you need....
Just a little more strength...
Dan Fredrickson
Old 11-26-2009, 01:21 PM   #11 (permalink)
Member # 51387
Keeping them in mind!
Make these the first thing you install....
Dan Fredrickson
Old 12-21-2009, 10:15 AM   #12 (permalink)
Member # 51387
These are a HOT commodity!
It helps when the problem never occurs because you thought ahead....
Dan Fredrickson
Old 12-24-2009, 09:14 AM   #13 (permalink)
Member # 51387
If you have any thoughts about....
the strength of the hole you are going to use, use these first! They can save you a major trail repair
Dan Fredrickson
Old 01-03-2010, 11:06 AM   #14 (permalink)
Member # 51387
Strength is where you create it...
And sometimes its only a little spot that needs reinforcement, these can do the job and keep the weight down....
Dan Fredrickson
Old 01-10-2010, 02:38 PM   #15 (permalink)
Member # 51387
This is definately something....
You should do first rather than after you have the problem!
Dan Fredrickson
Old 01-24-2010, 12:38 PM   #16 (permalink)
Member # 51387
Its the little things that save your butt on the trail....
Dan Fredrickson
Old 02-05-2010, 08:52 PM   #17 (permalink)
Member # 51387
And its building season so take a look...
Take a look at something that can save your butt on the trail by having used them before....not after....
Dan Fredrickson
Old 04-11-2010, 05:32 PM   #18 (permalink)
Member # 51387
These are available in 4 sizes, 1/2", 9/16", 5/8" & 3/4"....Build it strong enough the first time!
Dan Fredrickson
Old 06-23-2010, 10:55 AM   #19 (permalink)
Member # 51387
Thanks for thinking ahead and using these BEFORE it fails!
Dan Fredrickson
Old 07-16-2010, 06:20 PM   #20 (permalink)
Member # 51387
The finest kind of armor, lite, simple, & durable!
Dan Fredrickson
Old 07-28-2010, 07:22 PM   #21 (permalink)
Member # 51387
And the simple things now are way better than the complex things later, after its too late...
Dan Fredrickson
Old 08-02-2010, 01:22 PM   #22 (permalink)
Member # 51387
I see it everyday, holes torn or egged out, fix them BEFORE it happens!
Dan Fredrickson
Old 08-03-2010, 02:32 PM   #23 (permalink)
Member # 163388
Throw some pics up of them in action!!
SomeGuyFromOlympia is offline   Reply With Quote Quick reply to this message
Old 08-07-2010, 11:32 AM   #24 (permalink)
Member # 51387
I'll get some Monday but it's a kind of simple thing to imagine...
Dan Fredrickson
Old 11-03-2010, 10:53 PM   #25 (permalink)
Member # 51387
Missed Monday and my camera is missig too, if we don't find the camera I will buy another tommorrow...That one was only 3 months old...
Dan Fredrickson
