Poison Spyder Brawler Lite Front Bumper for Jeep JK - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > Vendor's Marketplace > Body/Armor
Old 12-16-2010, 10:25 AM   #1 (permalink)
Token Bronco Guy
Dusty's Avatar
Member # 16474
The Poison Spyder Brawler Lite front bumper for JK is a "mid-width", high clearance bumper designed to combine hard core off-road performance with full features. This bumper is fabricated from 3/16" plate steel, CNC laser-cut and precision brake-formed into a low profile, high clearance design. The ends of the bumper extend far enough to protect the lower corner of the JK grille, but not far enough to hinder tire clearance or tire access to vertical obstacles.
The optional Brawler Bar is modeled after the bar found on our original RockBrawler™ front bumper. It is a low-profile stinger designed to provide protection to the winch, grille and radiator area. The Brawler Bar is made of CNC laser-notched, NC-bent 1" diameter .120" wall DOM tubing. The complex laser-cut notch allows the Brawler Bar to be welded to two different planes on the surface of the bumper, providing incredible strength. Further strengthening the Brawler Bar are a choice of two different gussets—laser-notched 1" DOM tubular gussets or CNC laser-cut brake-formed 3/16" plate steel gussets. The bumper may also be ordered without gussets.
For convenience in mounting off-road auxiliary lights, two light tabs are included along the top of the Brawler Bar. These may be optionally deleted.
Unlike the Poison Spyder BFH™ series bumpers for JK, the Brawler Lite can be mounted without cutting or altering the Jeep's frame rails. The faceted design of the Brawler Lite provides the best ground clearance and approach angle possible in a bumper that doesn't require frame modifications. The factory "Crash Bar" may be left intact or removed for a sleek appearance and high clearance. If keeping the crash bar, we recommend adding the Brawler Lite Skid Plate (shown below, sold separately), which conceals the crash bar and protects the electronic sway bar disconnect.
The Brawler Lite features recessed buckets to mount the factory fog lamps, fully protecting them in deep tubular sockets with direct-fit mounting flanges. Another thoughtful feature are the conveniently placed loom mounting holes, for reinstalling the "Christmas tree" loom hangers of the factory fog lamp harness.
Any winch with a standard 10" X 4.5" mounting pattern will bolt right on to the Brawler Lite. Beefy internal gusseting directly below the winch mount provides the strength to sustain long, heavy pulls. The center of the bumper, where the winch sits, is slightly recessed with the winch mounting on top, without compromising the structural integrity of the bumper by cutting a huge hole in the bumper structure to place the winch down inside like other manufacturer's bumpers. If mounting a winch, you'll need a Winch Fairlead Mount, sold separately.
Optional Recovery Shackle Tabs are modeled after the high clearance tabs designed for our hard core BFH series bumpers. These tabs are angle to provide maximum approach angle. They are CNC machined from 1" thick steel billet, specifically designed to accept our heavy duty 3/4" Recovery Shackles. Selecting this option will get you a pair of these tabs, expertly welded to the Brawler Lite bumper.
For pricing and ordering:
Click Here for the base Brawler Lite bumper
Click Here for the Brawler Lite with Brawler Bar
Click Here for the Brawler Lite Skid Plate
Dusty Sharp
Marketing Director
- 951-849-5911 - Connect with us on:
Dusty is offline   Reply With Quote Quick reply to this message
Old 01-06-2011, 08:21 AM   #2 (permalink)
Token Bronco Guy
Dusty's Avatar
Member # 16474
Just a reminder that for the month of January 2011, Shackle Tabs are FREE on these bumpers! That's a $49 value. Click Here for details.
Dusty Sharp
Marketing Director
Old 01-06-2011, 09:11 AM   #3 (permalink)
Token Bronco Guy
Dusty's Avatar
Member # 16474
Here's the optional DOM Tube Gusset style for the Brawler Bar:
When ordering you can specify either the Tube Gusset or the Plate style gussets as shown in the first post.
Dusty Sharp
Marketing Director
Old 01-19-2011, 04:29 PM   #4 (permalink)
Token Bronco Guy
Dusty's Avatar
Member # 16474
Dusty Sharp
Marketing Director
Old 02-16-2011, 10:37 AM   #5 (permalink)
Token Bronco Guy
Dusty's Avatar
Member # 16474
Dusty Sharp
Marketing Director
Old 02-22-2011, 03:12 PM   #6 (permalink)
Token Bronco Guy
Dusty's Avatar
Member # 16474
Dusty Sharp
Marketing Director
Old 03-22-2011, 02:17 PM   #7 (permalink)
Token Bronco Guy
Dusty's Avatar
Member # 16474
Choose the plate style gussets or the DOM tube gussets for a bit more of a pre-runner look...
Dusty Sharp
Marketing Director
Old 05-13-2011, 04:07 PM   #8 (permalink)
Token Bronco Guy
Dusty's Avatar
Member # 16474
Dusty Sharp
Marketing Director
Old 08-24-2011, 03:38 PM   #9 (permalink)
Token Bronco Guy
Dusty's Avatar
Member # 16474
Dusty Sharp
Marketing Director
Old 09-02-2011, 10:42 AM   #10 (permalink)
Token Bronco Guy
Dusty's Avatar
Member # 16474
JK Brawler Lite Front Bumper with Brawler Bar
Dusty Sharp
Marketing Director
Old 11-30-2011, 11:17 AM   #11 (permalink)
Token Bronco Guy
Dusty's Avatar
Member # 16474
We are once again offering the optional DOM Tube Gussets on the Brawler Lite. These were an option a while back, then were only special order for a while. But now once again they are a standardized option and can be ordered this way through our website, by phone or through any of our dealers.
Note that the Warn PowerPlant winches are NOT a direct fit with the DOM Tube Gussets. The passenger side gusset is slightly in the way of the end of the winch housing. However, a PowerPlant may be mounted (as shown on the Rockett Rubicon in the photo above), with some small modifications to the bumper by the installer.
Dusty Sharp
Marketing Director
Old 12-12-2011, 09:23 AM   #12 (permalink)
Token Bronco Guy
Dusty's Avatar
Member # 16474
Special thanks to Will Ng for sending over these great photos of the Brawler Lite on his Mountain Edition:
Dusty Sharp
Marketing Director
Old 12-15-2011, 10:52 AM   #13 (permalink)
Token Bronco Guy
Dusty's Avatar
Member # 16474
Couple new shots of the Brawler Lite on Venomous...
Dusty Sharp
Marketing Director
Old 03-16-2012, 01:28 PM   #14 (permalink)
Token Bronco Guy
Dusty's Avatar
Member # 16474
Jake Kulik's rig with the Brawler Lite:
Dusty Sharp
Marketing Director
Old 04-12-2012, 12:19 PM   #15 (permalink)
Token Bronco Guy
Dusty's Avatar
Member # 16474
Here are some pre-production photos of the Trail Stinger option we will be making available for the Brawler Lite. Like the Brawler Bar we currently offer, the Trail Stinger will come with plate steel gussets (the ones shown in the photo are temporary, we're doing some small revisions to it for the Trail Stinger). We may also offer a tube gusset option, like we do with the Brawler Bar, if there is sufficient interest. These should be in production in a few weeks but we've been getting a few inquiries about it so we thought we'd post up a couple of photos.
Dusty Sharp
Marketing Director
Old 04-18-2012, 10:05 AM   #16 (permalink)
Token Bronco Guy
Dusty's Avatar
Member # 16474
Thanks to our friends over at RIPP Superchargers for this photo of their JK at Moab EJS, sporting a bunch of Poison Spyder gear including the Brawler Lite with Brawler Bar and Skid
Dusty Sharp
Marketing Director
Old 06-20-2012, 02:46 PM   #17 (permalink)
Token Bronco Guy
Dusty's Avatar
Member # 16474
The Brawler Lite with Trail Stinger is now available!
This has been a popular request, and we're glad to finally release it. Like the Brawler Bar, the Trail Stinger is made out of CNC laser notched, NC-bent 1.75" OD .120 wall DOM tubing. We considered a couple of different plate gusset designs but in the end decided it looked best--and would be strongest--with some DOM tube gussets instead (there is no plate gusset option offered). Pricing is the same as the Brawler Lite with Brawler Bar. See our website or your favorite Poison Spyder dealer to order yours!
We knew you would want to see it mounted on a Jeep before pulling the trigger on one, so we temporarily installed it on one of the project Jeeps we currently have in the shop. We'll post up some shots of powder coated, finish-installed-with-winch as soon as we can. In the meantime...
and from the driver's seat...
Thanks for looking, and for those of you who have been waiting for these, thanks for your patience
Dusty Sharp
Marketing Director
Old 06-21-2012, 08:47 AM   #18 (permalink)
Token Bronco Guy
Dusty's Avatar
Member # 16474
For those purchasing a Brawler Lite and wanting to run a pair of Rigid Industries Duallys or Dually D2's in the fog lamp buckets instead of the factory fog lamps, we're now offering the Rigid/BDF mounting kit designed for this purpose.
BTW these also work in the stock bumper or just about any aftermarket bumper that is designed to accept the factory fog lamps. Thanks!
Dusty Sharp
Marketing Director
Old 06-26-2012, 03:30 PM   #19 (permalink)
Token Bronco Guy
Dusty's Avatar
Member # 16474
Our first shots of a Brawler Lite with Trail Stinger finished and mounted up. This one's on the Spike's Tactical JK, which is just about finished and we'll have more photos of it soon.
Dusty Sharp
Marketing Director
Old 08-13-2012, 11:59 AM   #20 (permalink)
Token Bronco Guy
Dusty's Avatar
Member # 16474
Got a few Brawler Lite photos from customers to add to the thread. Thanks to Joey Geaghan for this cool shot:
This one's courtesy of John Sherwin:
Here's the one we put on Brian Deagan's JK:
Thanks to Lucas Tietze for this one:
Poison Spyder gear in South Africa! Thanks to Andrew Ehlers from our South Africa dealer B-D Suspension, for this pic:
Rusty Everett's nice 4-door with Spyder gear including the Brawler Lite:
Andrew Peil had some fun in the mud with his Brawler Lite!
And finally, thanks to our friends at ICON for this killer shot of getting air in their Poison Spyder equipped rig:
Dusty Sharp
Marketing Director
Old 09-12-2012, 09:52 AM   #21 (permalink)
Token Bronco Guy
Dusty's Avatar
Member # 16474
The Brawler Lite with Brawler Bar looks killer on the Arctic Spyder!
And don't forget all the other goodies shown in the photo!
Dusty Sharp
Marketing Director
Old 10-22-2012, 02:53 PM   #22 (permalink)
Token Bronco Guy
Dusty's Avatar
Member # 16474
Here's a nice illustration of why we would rather just cut the "crash bar" off and run the Brawler Lite without the lower skid. On this obstacle the skid would have cased before Timmay's tires were able to grab.
Of course, he's running the Currie Anti-Rock swaybar, which tucks up better than the stock sway bar and sway bar disconnect unit on the Rubicons. If you're still running the stock Rubicon sway bar setup, of course the lower skid pretty important for protecting the expensive electronic disconnect unit.
Here's a closer look at the Brawler Lite lower skid:
Dusty Sharp
Marketing Director
Old 11-06-2012, 11:33 AM   #23 (permalink)
Token Bronco Guy
Dusty's Avatar
Member # 16474
Thanks to Sean Ringer for sending in some pics of his JK Brawler Lite with Trail Stinger
Dusty Sharp
Marketing Director
Old 01-22-2013, 03:42 PM   #24 (permalink)
Token Bronco Guy
Dusty's Avatar
Member # 16474
Looks like the Poison Spyder Brawler Lite is the perfect JK Bumper for snow wheeling!
Thanks to Robert Perrella for this shot.
Thanks to Randall Davis for this shot of Chris Brock's rig.
Thanks to Bernie Horstkamp.
Another gem from Randall Davis. Brawler Lites on all three of these rigs.
Thanks to Clint Wilson, who keeps us in a steady supply of great shots.
Even the new Brawler Lite with Trail Stinger gets some snow action. This shot courtesy of Coralee Lack.
I may have posted this one from Sean Ringer before, but its fitting for this post.
And finally this one from Anthony Karlos.
Thanks everyone who sends in their photos!
Dusty Sharp
Marketing Director
Old 02-25-2013, 11:50 AM   #25 (permalink)
Token Bronco Guy
Dusty's Avatar
Member # 16474
Couple more recent customer-submitted photos of the Brawler Lite!
Thanks to David Ross for this shot:
Here's a nice one from Michael Delehanty:
Here's one with a Trail Stinger from Kasey Dixon:
Thanks everyone who keeps sending in their photos!
Dusty Sharp
Marketing Director
