Member # 152314
04 Rubicon on 35's with 4.88's
This Jeep is ready to hit the trails & get you home again or to be used as a DD. It's an 04 Black Rubicon with around 88,000km's. Pics added.
I'm asking $15,000.00 Can OBO ($13,500.00 USD) Any reasonable offers will be considered. Below are the specs: Cobra 75 WXST hand held CB with ext speaker 5 spd Factory sub A/C Factory sub 5 spd Stock 4.0L engine Stock D44 axles with factory lockers Flex-O-Lite electric fan 3.5" RE super flex lift kit (all new bushings & flex joint installed end of the year) 1 1/4" JKS body lift Poly trans mount RE adjustable upper rear control arms Rock Krawler adjustable upper front control arms Heavy duty front lower control arm brackets on the axle Heavy duty Rock Krawler front upper control arm bracket (on passenger side) Rock Krawler upper control arm flex joints on the axle 4.88 Gears 35" Maxxis Trepador tires on steelies Warn gas tank skid plate Rock rails Heavy duty diff cover front & rear 1" mount mount lift Custom long travel drive shafts front & rear (still have the factory one as spares) RE adjustable track bars front & rear ORO U turn high steer kit Bar pin eliminators front & rear M8000 Warn winch After market front bumper with tow points Custom rear bumper with tire carrier and frame tie in brackets Seat glover seat covers front & rear Hard & soft top with tinted windows Yellow top battery Frame has been sprayed with rocker guard I'm sure there is more but I can't think of anything right now. There are only a couple of minor things to note: There is a small dent in the passenger door & rear corner Minor scratches in the paint Small rip in the soft top (over the rear passenger window) Doesn't leak inside tho. Rear window is broken in the hard top Last edited by Stix&stones; 02-12-2010 at 05:28 PM. Reason: New price |
