.030 454 bbc - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > Classifieds > Canadian Classifieds
Old 03-19-2010, 10:50 AM   #1 (permalink)
Member # 156628
.030 454 bbc
This motor is fresh not even fired. its externally balanced good to 6500rpm.
It a 73 two bolt main block has eagle main caps studs
Its a 30 over block so a 4.280 bore
Trw 43.00cc dome pistons makes for 12.5 comp ratio with moly zero gap rings.
The rods are LS6 rods with arp 2000 bolts ... See More
Crank is 10/20 just been t...urned fresh clevlite bearings.
Has new crower roller lifters
New Lunati Cam 680/680 lift
New double roller timing chain
New 8 inch balencer with timing marker.
New ARP head bolts
Merlin oval port head iron some port work done.
They have crane gold springs good for 750 lift, 1.8 crane gold rockers 2.30/ 1.88 valves.
New moroso pan and pump with ARP drive
New BandM flex plate with arp bolts
also and holley strip dominator intake
Please Msg me if interested thanks
$5500 for the long block above
$3000 for short block
$3700 with cam and lifters.
1978oldskool is offline   Reply With Quote
