Member # 163028
Will a dodge nv4500 work with a chevy 6.2?
Do I need a custom bellhousing and input shaft?
maybe one of you guys knows the answer...I don't know who else to ask... For background...I am planning on running a 6.2 diesel in a Range Rover classic. It is a common enough swap, however people overwhelmingly mate it up to the stock zf 4hp22...I've figured (with the help of a guy from advanced adapters) a way to divorce my transfer case...which means I can run a 2wd transmission behind the 6.2. So here I am trying to source a 2wd nv4500. I found a dodge one...I need to see what it would take to mate it to the chevy... Anyway, help is appreciated. |
Member # 130292
I think the Chevy bell housing/input shaft would make it a bolt in deal
-Colton- 1989 Toyota Pickup with some stuff 2002 Dodge Ram 2500 4wd Diesel (Daily Driver/Tow Pig) |
Member # 96153
A stock 96'+ bellhousing from a Chevy will bolt up. So will the input. Don't waist your money with the idiots over at AA.
If they had it there way you would have to spend $1000 to bolt a Chevy 4500 to a Chevy motor. ![]() Edit: I'm not entirely sure that the bellhousing is the same shape for the 6.2/6.5 Diesels, but I think they are.
DD:09' V8 Colorado Toy:The Blazer Build Ultra4 #818 Old tow:92' Dodge Build Sold ![]() New tow:05' Dodge Crew 4x4 CTD (stock for now) 18th at Glen Helen 13' ![]() Complete 465/203/205 For Sale Last edited by K5runner@hotmail.com; 08-19-2011 at 12:06 AM. |
Member # 183454
i will give you a chevy nv 4500 for that dodge nv ... if your not a mill miles away
i got two.. early and late ..they will both bolt right up to a 6.2 in 95 they changed shaft size and something with gear ratio .. you cant run the pto off the pre 95 to the 95 and up thats how i found that out the hard way .. |
#7 (permalink) | |
Member # 163028
Plus its a 2wd nv4500. You running a divorced t case? |
#9 (permalink) | |
Member # 37184
And a Chevy clutch, and a Chevy NV4500 input shaft installed in the Dodge NV4500. The Dodge's input shaft stick-out is ~1" longer than a Chevy's. The Chevy bearing retainer/front "snout" must be turned down to fit a Chevy throw-out bearing (presumes you want an external slave cylinder). With the Chevy input shaft, the Dodge tranny becomes a "Chevy", as far as the Chevy Bell housing is concerned. Also, when it comes to NV4500's, there are two different bolt patterns. So you need to insure your tranny will fit what ever bell-housing you're going to use. Look at the Advanced Adapter's catalog; they sell NV4500's, bell-housings, clutches, slave cylinders, etc, and have guidance as to what fits what.
88XJ, Chevy 5.7L, Edelbrock MPFI, NV4500, Atlas, D44's, high steer, ARB's, 7" custom semi long-arm 3 or 4-link lift, BFG 33x12.5-15's. |
#11 (permalink) | |
Member # 83920
This isn't meant to be a flame job, but Jesus, do you guys ever read or search? Do you suppose your question has already been answered somewhere? Look it up for your fuckin self. |
