4L80E to NP205
i've got a 94 4wd 4L80E, and a 10 spline 205 with a figure 8 adapter. i've read somewhere that i can mate the two together by swapping to a 32 spline input, and using a 400/205 adapter. my sources are not reputable ones, so i figured i'd post here and see what you guys had to say about it.
93 Chevy C2500 - 10 bolt/14FF 5.13s Detroit rear 454/80E/NP241 - SAS in progress |
Bad Doctor
Member # 86878
The 4l80E output shaft is the same as a TH400, so the same rules apply.
Youll need a 32 spline input 205 and the appropriate adapter.
-Vinny -from Elizabeth Nobody cares about your rigs specs... "Me too" short Crew build /forum/chevy/994394-odins-me-too-short-crew-build.html Last edited by Odin K30; 08-21-2011 at 07:23 PM. |
Member # 16536
Need to do some machining on the 400 adaptor to work on the '80e. I don't remember how much, but like .030" or so. There is a right up on CK5, if you search on the web or here should find it.
#4 (permalink) | |
#5 (permalink) | |
Member # 110338
http://coloradok5.com/forums/showthread.php?t=166233 The only problem is non of the pics show up and the thread was started in 2006...
1972 K5 Blazer Mall Crawler LQ9 / 4L80e / NP205 / D60 / AAM 14bff / Hydroboost / Fox 2.0 |
Member # 110338
Here is a picture of an original 1991 adapter in the posession of Northwest Fab as of 3/13/2006 ....
#7 (permalink) | |
Member # 40695
The Part Number is 50-0410 If you want a quote on the kit send me a pm with you zip code. Kris |
