just to confirm a gas SM467 will bolt to a 6.2? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 08-21-2011, 10:10 PM   #1 (permalink)
Member # 7646
My friend has a 85 K10 with a tired 305 and sm465 and i have a good 6.2 that i'll give him.
So just to confirm we just need to get the diesel flywheel (diesel was auto) and its a bolt together
Thx
also side question, a friend has a flywheel from a 6.5 but all 6.5s had the 5 speed so will that flywheel work with the 6.2 and 4 speed
thx
85 suzuki sj 410, 82 suzuki sj 410 pickup 68 IH pickup, 78 Scout II
76 Scoutt II turbo 345 propane
Chief yelling alot is offline   Reply With Quote
Old 08-22-2011, 04:09 AM   #2 (permalink)
Member # 613
flywheel will work, trans will work. Have to find a diesel bellhousing or grind out where the starter goes not enough room in a gas version for the nose of the diesel starter.
odee is offline   Reply With Quote
Old 08-22-2011, 06:30 AM   #3 (permalink)
Member # 159592
Both of my gas hydro bellhousings bolted up to my 6.2 without grinding anything....perhaps the older mechanical clutch ones need a little clearancing,although they look the same in the starter area to me too.I don't see why gm would make two bellhousings that are identical except for a little extra starter clearance,but the 6.2 didn't come out until 1982 so maybe the problem is only with those made from '81 back.I'll have to compare one from the 70s next time I find one to look at.
imbobbbb is offline   Reply With Quote
Old 08-22-2011, 09:45 PM   #4 (permalink)
Member # 7646
hey thanks allot guys
also i have herd that the stator is different between auto and manual with the 6.2 is that true
Old 08-23-2011, 06:49 AM   #5 (permalink)
Member # 159592
I'm using the same starter I had before
