Member # 160071
tbi rough idle when warm
OK so Iv'e had this problem and have been searching all over the net for the last three days for an answer to no avail.
here's what I have sbc comp cam off road cam zz4 intake stock tbi 18 psi fuel pump Iv'e been working on this retro fit for the last two months and have never had much of an idle problem, at least not after i got all my blm's in line after a few weeks of timing. I finally got everything running great. blm, pe, spark.....everything was great! I could hit the gas and go with no problems. I finally decided to take it out for a long drive. before that it was all just around my neighborhood. well after about 20 min of driving it started to stumble and stall while idling. I finally got it home by two footing at every stop light. I have since changed the rotor, spark plugs, tps, and iac. I have also done a iac re learn about ten times. still nothing. I watched the temp sensor with tuner pro and it stayed right in line with my mechanical autometer temp gauge. the only thing I havent changeD or checked voltage on is my map but have looked at it with tuner pro and it doesnt really look like the readings are off but I def need to do a little more in depth looking at it. Here is the strange thing.......while idling at around 700rmp its really rough and eventually will die but when I disconnect the cts it will smooth out and idle great, a little high around 600-650rpm but none the less it runs smooth and wont stall. I plug it back in and it will stumble and die. I'm at a loss. does anybody have any ideas for me? Ihanks
1989 jeep yj 6 point cage mildly built SBC built TH 350NP 208 Dana 44 f/r 4.56:1 |
Member # 160071
Ahh I forgot to mention....I don't have an egr. I also have it shut off in the ecm. No emissions what so ever.
Member # 160071
Iv'e also checked for vaccume leaks but I kinda ruled that out by it idling well when I disconnected the cts.
Member # 197664
id start with the simple stuff before just replacing everything, take ur filter off and just make sure u have a good spray pattern, if u do then id check for vacume leaks. Ive had this kind of problem a few times over the years one time it was the mix of leaks with clogged injectors. The other time it was low fuel pressure form the fuel pump.
#6 (permalink) | |
Member # 160071
Member # 140536
Which comp cam did you put in it, number?
Did you reflash the prom for that cam? Depending on lobe separation you maybe running rich or lean while it still looks good on the O2. I'm guessing lean since it runs better with the cts unplugged. Verifying the inlet and outlet fuel pressure would help too.
Josh #4502 "The Rental", Team Yukon Gear and Axle Driver - One of 'em Skinny Pedal |
#8 (permalink) | |
Member # 160071
I appreciate the help but please read what i have wrote before you write a response.
#9 (permalink) | |
Member # 83920
More fuel going to a lean mixture(caused by a vacuum leak) will cause the idle to smooth out, and rpm to increase. Since it has a few miles on it now, re-torque the throttle body, intake, and anything else that may have changed once you spent some time up to temp. I know some intake gaskets don't technically require re-torquing, but I find it to be a good practice. Seriously, sounds like a vacuum leak to me..... Finally, a TBI question posted by someone who has actually done some checks and can help with the diagnosis, rather than the typical "My truck does this, What do you think?" sort of bullshit that always gets posted. Hope you get it figured out soon. Sounds like it might be stumping you right now, but you at least have a handle on things.
This isn't meant to be a flame job, but Jesus, do you guys ever read or search? Do you suppose your question has already been answered somewhere? Look it up for your fuckin self. |
#10 (permalink) | |
Member # 160071
would it be possible that there is something wrong with the map? it almost seems like timing could be changing via the ecm but I'm not sure. I have a pretty good grasp on tbi but I'm definitely still learning. how about the pcv? is it pretty much supposed to be open or should it be somewhat restrictive? I sucked through that too and it was really easy to pull air through. Yea i didn't want to post a thread where the only answer i got was "do a damn search" lol. I made sure to cover that first! haha
1989 jeep yj 6 point cage mildly built SBC built TH 350NP 208 Dana 44 f/r 4.56:1 Last edited by dem3500; 09-01-2011 at 11:21 AM. |
#11 (permalink) | |
Member # 83920
#13 (permalink) | |
Member # 83920
another thing to check would be battery voltage at idle.
This isn't meant to be a flame job, but Jesus, do you guys ever read or search? Do you suppose your question has already been answered somewhere? Look it up for your fuckin self. Last edited by dahoyle; 09-01-2011 at 12:02 PM. |
#14 (permalink) | |
Member # 160071
The batt voltage at idle is about 13-13.5vdc with a brand new optima deep cycle.
#15 (permalink) |
mega hack!!
Member # 139150
dahoyle may be on to something. i think you have one problem masking another. your fuel pressure is very high, 18psi is way out. according to howell it should be about 13-15 psi (yes i just spent hours tuning in my own tbi setup with thier help). with the fuel pressure that high the injectors will spray more fuel than normal, and the computer would normally be leaning things out to compensate, but if you had a small vacuume leak it would do the same thing. what are your IAC counts at idle. they should be about 30. if they are way low look for a vacuume leak.
74 chev tbi 350 sm465/203/205 d60 ARB/14b detroit 56's/64's on 40's! ![]() /forum/chevy/933618-new-old-black-getting-1-ton-makeover.html |
#16 (permalink) |
Member # 160071
Well I finally figured it out last night and to be completly honest i feel like a retard lol. after going over everything with the DVM and checking for air leaks I figured it must be a mechanical problem with the engine. Well for whatever reason a lightbulb went off in my head telling me to check the voltage to the ECM. 9.5volts! Ah ha! I traced it to a loose connection and started it up. Fixed! so after everything I went through it turned out to be something that took me two seconds to fix. Oh well, you live and learn. Now every time there is a strange problem like that the first thing I'm going to check is the voltage to the ECM lol.
Thanks for all the help you guys gave me! I'm back in action!
#17 (permalink) | |
Member # 83920
![]() Nothing quite like having a clue, a little common sense, and the desire to do for yourself rather than showing up with your head up your ass, and wanting everyone to solve your problems for you. Props to you.
