Ruffstuff 14b disc brackets, wtf? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 09-23-2011, 02:20 PM   #1 (permalink)
Member # 191251
Early 80's c&c axle
Calipers and rotors from 82 k20
rotors measure about 12.5"
do they all fit this bad, or did I get a bad set of brackets?
RCP Fab is offline   Reply With Quote
Old 09-23-2011, 03:45 PM   #2 (permalink)
Devout Newbie Hater
Grumpy_old_fart's Avatar
Member # 20147
looks kinda like you need a bigger rotor.
sympathy, empathy and apathy... i dont know which one is which....
But i know you can find sympathy between shit and syphilis in the dictionary.
Win this car for a whole BUCK!
Grumpy_old_fart is offline   Reply With Quote
Old 09-23-2011, 03:46 PM   #3 (permalink)
Member # 191251
I agree.... or the holes in the right place
Old 09-23-2011, 03:48 PM   #4 (permalink)
Devout Newbie Hater
Member # 20147
can you get a pic from a LITTLE further away?
Old 09-23-2011, 03:55 PM   #5 (permalink)
Member # 191251
How are these?
Old 09-23-2011, 04:08 PM   #6 (permalink)
Member # 133078
Did you get the right rotor?
Ubluzin is offline   Reply With Quote
Old 09-23-2011, 04:11 PM   #7 (permalink)
Member # 191251
Rotors are off 82 K20. The rotors are from advance, and physically measure the same as the specs listed on napa's site.
Old 09-23-2011, 04:26 PM   #8 (permalink)
Member # 141906
Send a message via MSN to Flatdeck6.2
PM gravelmaker (Dan) show him these pictures. I just went outside and looked at my truck with the exact same setup and the pads have full contact with the rotors.
Living vicariously through you
Flatdeck6.2 is offline   Reply With Quote
Old 09-23-2011, 04:31 PM   #9 (permalink)
Member # 191251
Done. Thank you.
Old 09-23-2011, 04:37 PM   #10 (permalink)
skullfuckery
trkklr77's Avatar
Member # 29016
its happend before, he'll get you fixed.
Old 09-23-2011, 04:39 PM   #11 (permalink)
Member # 191251
Glad to hear it.
Old 09-23-2011, 04:45 PM   #12 (permalink)
Gravel Maker's Avatar
Member # 51387
Send a message via Yahoo to Gravel Maker
Give me a call, looks like they were drilled incorrectly...They don't all fit badly...
Dan Fredrickson www.ruffstuffspecialties.com
......"The NEW Industry Standard"
Tech/Sales 916.600.1945
You can SAY anything, its what you DO that matters!
The Official Repair Station of KOH!
Gravel Maker is offline   Reply With Quote
Old 09-23-2011, 05:06 PM   #13 (permalink)
Member # 182666
mine fit just fine
1979 k20 suburban under the knife...
79k30burb is offline   Reply With Quote
Old 09-23-2011, 05:24 PM   #14 (permalink)
Member # 173415
Mine are almost as bad as yours.
dan63 is offline   Reply With Quote
Old 09-23-2011, 05:29 PM   #15 (permalink)
Member # 191251
Just got off the phone with Dan, apparently some were drilled wrong. I would call Dan if your's are like this.
He is sending me out a new set, I will report back when I get them.
Old 09-23-2011, 05:48 PM   #16 (permalink)
jsawduste's Avatar
Member # 77571
And we all know the report will be 100% positive. After all, you are dealing with Dan.
jsawduste is offline   Reply With Quote
Old 09-23-2011, 05:49 PM   #17 (permalink)
GMCTruxrule's Avatar
Member # 51243
Fawk that. Im trying to inspect the porosity of his rotor...thankyouverymuch!
[COLOR="Lime"][B]1999 Chevy K3500, 5.7/4L80E/14FF/stock/stock/stock[/B][/COLOR]
GMCTruxrule is offline   Reply With Quote
Old 09-24-2011, 05:07 PM   #18 (permalink)
Bad Doctor
Odin K30's Avatar
Member # 86878
Thought I was the only one...
I couldnt stop staring at that pic. WTF did you put the camera in a microscope?
-Vinny
-from Elizabeth
Nobody cares about your rigs specs...
"Me too" short Crew build
/forum/chevy/994394-odins-me-too-short-crew-build.html
Odin K30 is offline   Reply With Quote
Old 09-29-2011, 07:40 PM   #19 (permalink)
Member # 191251
Wednesday, the 2nd set of brackets showed. Fit exactly the same. Called ruff stuff, he did some measuring. The decided fix was to have one of the guys weld up the holes in another set, re drill and tap in the right spot. I ended up doing this myself, and the guys at ruff stuff sent me out some other parts that I was planning on ordering.
All in all, great customer service.
Old 09-29-2011, 07:58 PM   #20 (permalink)
Member # 51387
It appears we have a whole stack that were made for the Chevy 12.5" rotor and drilled for the Sterling 12 7/8" rotor...Which sucks just a bit but at least it isn't the most popular one.
Old 09-29-2011, 08:06 PM   #21 (permalink)
Member # 191251
Dan, don't take this the wrong way, but that is an impossibility.
A 12 7/8 rotor would offset the caliper by 3/16" (.1875). To fix these brackets I needed to bring the holes down .335"
Like I said, not trying to start shit, just trying to help. You guys went above and beyond in my eyes.
Old 09-29-2011, 09:09 PM   #22 (permalink)
fuck off
randy92782's Avatar
Member # 102123
I think if he zoomed in any further we'd see the other side of the rotor
Nice to see this is geting fixed. I know who i'm ordering these from
Originally Posted by monkeyevil View Post
Tranny's are the gateway drug to gay.
72 Chevy 454/465/205 33's
89 Chevy Suburban 454TBI/400/205 6" Procomp lift on 37's
94 Chevy ext. cab 350/4L60e/241 6"BDS lift,35" MTZ's
randy92782 is offline   Reply With Quote
Old 10-01-2011, 06:49 PM   #23 (permalink)
Member # 194429
just got mine in yesterday. hope they wasnt part of that stack.
88V30 is offline   Reply With Quote
Old 10-01-2011, 06:52 PM   #24 (permalink)
Member # 191251
Measuring from the line of the press break to the caliper bolt hole should be about 1.040 on the correct ones, assuming its a DRW axle bracket.
Old 10-01-2011, 08:06 PM   #25 (permalink)
Member # 173415
Mine are on A srw housing with drw hubs. The first set the offset was wrong won't fix on the rotors. He send me A free pair. The pads sit out about .185 to far been running them this way for about 1 year.
