12 bolt info - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 12-13-2002, 03:32 PM   #1 (permalink)
Member # 14644
12 bolt info
i have the opportunity to pick up a 12 bolt out of a mid 70's chevy half ton. will if work in my 85 gmc half ton? spring perches aren't a problem, just wondering about the width. thanks.
greg
1986.5 Nissan crawler - dual cases, one tons, 42's...
2003 SV650
1997 F350 DRW PSD
bignissan is offline   Reply With Quote
Old 12-13-2002, 05:44 PM   #2 (permalink)
El Jefe's Avatar
Member # 14072
Yep. The only difference may be the driveshaft yoke.
Thus far you have been adrift in the sheltered harbor of my patience.
El Jefe is offline   Reply With Quote
Old 12-13-2002, 06:11 PM   #3 (permalink)
Member # 13175
Send a message via AIM to fr8train
It will work.
fr8train is offline   Reply With Quote
Old 12-14-2002, 12:00 AM   #4 (permalink)
Member # 14644
is the bolt pattern the same? i think i remember that the 70's are 5x5 and i think mine is the 5x5.5"....is that correct? or is mine 5x5 as well? it's tough to measure without pulling the wheel, which i don't feel like doing...thanks
greg
2003 SV650
1997 F350 DRW PSD
Old 12-14-2002, 04:46 PM   #5 (permalink)
Member # 2095
I don't know of Chevy useing 5x5.5" on anything.
But then, I thought all Chevy 1/2 ton 4x4's were 6 lug, so what do I know.
'79CJ5,soa,d44/60,t18,d18w/Obrian 3.6low,5.13's,35x14.5SSR's
'02 Z71
CJ-Jeeper is offline   Reply With Quote
Old 12-14-2002, 10:21 PM   #6 (permalink)
Member # 14644
ok cool , you're right.....this is a 2wd though.... thanks
greg
2003 SV650
1997 F350 DRW PSD
Old 12-15-2002, 09:01 PM   #7 (permalink)
Member # 5306
Send a message via AIM to reddwarf Send a message via Yahoo to reddwarf
Your 85 has either a 3r series Saginaw joint (auto tranny) or a 1350 series joint (granny 4 speed). The 12 bolt has a 1310 series joint. There are conversion u joints from Spicer and NAPA (don't buy the NAPA ones, their needle bearings are junk).
"I'm ridin like a felon" -- Doug
reddwarf is offline   Reply With Quote
Old 12-16-2002, 08:50 AM   #8 (permalink)
Member # 14644
thanks!
greg
2003 SV650
1997 F350 DRW PSD
