Member # 188642
i need 4l80 help
my truck is a 98 chevy crew cab, i bought a crate 454 for it to replace the worn out motor, trans was rebuilt and was working great until we go everything back in order and now it wont move at all..i checked fluid and there all fine, torque converter is hooked up right. any ideas on what might be wrong?????
Member # 128462
Assuming you hooked up the driveshaft, have you checked the shift linkage? Did the TC have any fluid in it when it was installed? When you try to put it in gear what does it do? Need more info
My Build Page: [url]http://pirate4x4.com/forum/showthread.php?t=912671[/url] |
Member # 147848
Did you make sure the torque converter was pushed into the trans properly or did you just shove it in there and pull the trans to the motor with the bolts and push the torque into the pump.
'Merica. Fuck Yeah!
Member # 25703
^^^ This. It probably slipped out of the pump when you pulled the original engine, and then you broke the pump when you bolted the engine back to it.
The facelift:/forum/chevy/1083762-old-busted-new-busted.html |
#5 (permalink) | |
Member # 188642
can the neutral safety switch fail just like that? other than the flywheel bolts and bell housing bolts nothing else tranny wise was removed. |
'Merica. Fuck Yeah!
Member # 25703
One quick and easy way to tell, albeit messy. Pull the cooler lines at the radiator and fire it up. 2 to 1 shes not pumping.
The facelift:http://www.pirate4x4.com/forum/showthread.php?t=1083762 |
