i have a 98 4.3 vortec, the number one injector is spraying like a super soaker instead of a fine mist. I have a 98 harness with a 97 computer. jims performance walked me through changing the pin outs to make the two work...after redoing the pinouts the rig ran liek a champ for a couple runs. went over the rubicon and all the sudden my overspraying issue returned...but how, the pinouts are all secure in their locations so one is not getting a faulty signal. i also have a brand new spider injection system (the upgraded one, not the poppet style) and the fuel system hold pressure so its not a stuck open injector...something is triggering it to open too much...anyone have a clue?
ok so after ripping the top end apart i've come to the conclusion that for some reason my motor doesn't have a coolant temp sensor. all the injectors were overspraying. when the temp sensor is not present it tells the computer the temp is -40 and will run extremely rich. so i got a temp sensor but now i need to figure out how to wire into my computer. the jims performance harness i got has a wire labeled engine temp which is grey. there are two wires coming out of the sensor one is light green or yellow and hte other i believe is black (i'm pretty color blind which REALLY helps while wiring). i think the grey wire goes to my guage but i'm not sure. anyone know how to find the correct wires. I sent an emai lto jim at jims performance but we are goign wheeling this weekend and i might not be able to get an answer from him by then...
Your 98 harness ECTS wires are yellow and black. Yellow is the power side and black is the ground side.
On your 97 computer
The yellow ECTS wire should connect to pin 23 of connector 2 on your computer. Says it a red plug
The black ECTS wire should connect to pin 4 of connector 3 on your computer. Says its white. (also says this is the ground for the TPS too)
Temperature VS Resistance
177 ohms at 100 deg C
241 ohms at 90 deg C
332 ohms at 80 deg C
467 ohms at 70 deg C
667 ohms at 60 deg C
973 ohms at 50 deg C
1188 ohms at 45 deg C
1459 ohms at 40 deg C
1802 ohms at 35 deg C
2238 ohms at 30 deg C
2796 ohms at 25 deg C
3520 ohms at 20 deg C
4450 ohms at 15 deg C
5670 ohms at 10 deg C
7280 ohms at 5 deg C
9420 ohms at 0 deg C
12300 ohms at -5 deg C
16180 ohms at -10 deg C
21450 ohms at -15 deg C
28680 ohms at -20 deg C
52700 ohms at -30 deg C
100700 ohms at -40 deg C
