Here is a list I've compiled for lifting my truck 4", it will eventually be 6"-7". 88 V10 Suburban on 10 bolts, that will change immediately after the lift. It's a DD and I was going to do 52's up front but everything I've read says that it increases body roll, I dont know if it's true. I want to be able to wheel it, but the damn thing has no clearance.
FRONT:
(2) Bilstein F4-BE5-6249-H5 = 29.7" Extended = 11.9" Travel = 17.9" Compressed
(2) 99-04 Ford F250/F350 Front Shock Towers
(2) BDS Suspesion 001401 4" Lift Glide Rite Leaf Springs
(2) ORD 5" Extended Brake Lines
(1) ORD 10 Bolt Crossover Steering Kit
(1) Weld-In Frame Reinforcement Kit
(1) GM 80's 2WD Rebuilt Steering Box (12:1??)
(2) DIY4X Knuckle Shock Tabs
(2) Replacement Shackles
(2) ORD U-Bolt Plates
(4) DIY4X U-Bolts
What About Driveshaft?
REAR:
(1) DIY4X Shackle Flip N' Switch w/ 4.5" Shackle
(1) DIY4X Shock Inboarding Kit
(2) DIY4X EZ Inch
(4) DIY4X U-Bolts
What About E-Brake Cables?
OPTIONAL:
(1) DIY4X Competition Motor Mounts
(1) ORD High Clearance HD Engine Crossmember For SBC
Anything I dont need on here? Anything I do need? Anything I could change?
FRONT:
(4) DIY4X U-Bolts
REAR:
(2) DIY4X EZ Inch
(4) DIY4X U-Bolts
OPTIONAL:
