'63 GMC Build - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-22-2012, 10:49 AM   #1 (permalink)
63GMCKid's Avatar
Member # 121634
Send a message via AIM to 63GMCKid Send a message via MSN to 63GMCKid Send a message via Yahoo to 63GMCKid
'63 GMC Build
Building up a '63 GMC as a trail rig/dd/work truck/remote welding job truck. Just after something that will be reliable, simple to work on, and capable offroad. Doing a lot of things to it that are probably more hardcore than needed, but why not?
First a little introduction, I'm Chris and this will be a slow build as I am full time in school (for welding) so don't expect too much too fast. Being built on a starving student with access to awesome machines kind of budget. I'm 19, have 5 welding certs (4 TIG in the 6G position for chromoly, stainless, titanium, and aluminum, and 1 structural MIG cert) and working on more, I think I'm a pretty decent fabrimakator but I get to use all of the fancy machines at school like a PlasmaCAM, lathe, bridgeport mill, etc.
So here's the plan for it.... I want a truck that is reliable, very easy to work on with emphasis being put on easily accessing anything on the drivetrain, a very strong drivetrain, a major PITA for any car theif to steal, heavy metal body protection wherever possible to increase crash safety and obviously to protect the body, good towing capacity, capable offroad as this may be used to get to remote welding jobs from time to time, and most importantly, what all of this really adds up to, the peace of mind that I won't break it, as I have magazine/Pirate syndrome... I've been working on it for a couple years now and progress has been slow but hoping to speed things up a bit.
Here's what gear it'll have -
-SBC350, nothing special other than an aluminum edelbroke performer intake
-TH400 with a TransGo 400-1-2 shift kit, acts similar to a manual VB only much more daily driver friendly, will hold 1st and 2nd to any RPM and it does have pretty good compression braking from what I've read, put it in 3rd and it'll run through the gears like normal "Drive" selection with "shift like you mean it" shifts. Trans will be getting a full rebuild with all new clutches, steels, bushings, orings, gaskets, torque converter, Transgo kit, etc.
-NP205, divorced ford drivers drop. Going this route because I'm building an HO72 front axle and drivers drop puts the pinion much further from the engine oil pan and drivers drop also avoids that large lump on the passenger side of GM transmissions. Nothing too special here other than 1350 joints for input and both outputs. 32 spline shafts all around, input and front output will interchange, rear will be a flange and flange yoke setup. Also getting a custom built driveline disc e-brake setup with cable and hydro operation on the e-brake caliper. Will be twin stick'd, and that combined with the e-brake, I can do that cool parallel parking maneuver like all the ricers do. Also will be getting a custom mounting system in the form of a plate for the front and rear of the case with fancy poly-bushings and all. The case will be getting a full rebuild with new gaskets and new input shaft (I have ford mated case internals and a divorced case housing, so I have to buy the input shaft).
-HO72 rear, already finished. Has a factory Eaton No-Spin locker, 4.56 gears, taper roller bearing pinion and load bolt. Did disc brakes too with 3/4 ton front D44/10b rotors, DIY4x caliper brackets (bolt on), and new 9/16-18 wheel studs (same thread that the 14b uses) from Dorman. New spring perches from WFO also welded onto the housing with 73-87 SRW spring mounting span width (wider than the older trucks). Also, I was an idiot and re-used the ring gear bolts when I put it back together, and read online that I wasn't supposed to after the fact. I have magazine syndrome (Or maybe Pirate4x4 syndrome?) which means the chunk is getting rebuilt again, re-setup with new ring gear bolts, and probably safety wired for cool points. Housing painted flat black, chunk and cover painted Chevy Orange with black bolt heads. I am a bit OCD with the whole black/orange thing but I think it looks cool.
-HO72 front, work in progress. After seeing another guy on Pirate4x4 start on an HO72/D60 hybrid, I knew that it only made perfect sense for my GMC since I have one in the rear. Using the HO72 housing and center chunk, extending the long side, cutting the short side, and everything from the inner C's outwards will be Dana 60 hardware. Already have the inner C's and the dimensions to get my housing built to the correct width, currently working on that. Inner shafts will be kept on the down low for now, I've got a cool but cheap trick up my sleeve on that to avoid paying $400 for custom inners. All outer hardware will be chevy 60, including stubs, knuckles, hubs, brakes, etc. Will have crossover steering of course with a panhard bar for extra stability. Axle seals will be of the Seals-It brand variety. Center chunk will be a ball bearing chunk with 4.56 cogs, open diff.
-Frame is a mint '63 GMC 4x4 K20 frame, and it'd already gone under the knife. Did my 52'' leaf swap up front, notched the frame for the leaf mount crossmember, has 2 leaf bolt holes for 2'' and 3'' forward. Crossmember made of heavy square tube and plate. It's all welded in and final. Engine motor mount crossmember is too. Previous owner had some funky mounts in it, so I drew up a fancy crossmember in CAD, cut it out on the PlasmaCAM and TIG'd it up, its plate welded in a box formation with some cool guy holes (you know, the holes with tube running through them... unfortunately no dimple dies). Crossmember uses poly-bushings, and the bushings are in the crossmember. Once they wear out, support the front of the engine, remove 10 bolts (4 per side from the crossmember and 1 for each poly-bushing) and it drops right out from the bottom and they can be replaced. Much easier than factory motor mounts. Rear suspension is currently being worked on, trying to match the front with anticipated height after weight as best I can. 56'' leafs for the rear.
Other basic stuff... removed the in-cab gas tank, going with something much bigger. Going to run a flat bed on this truck also. Interior floor from the firewall to the back of the cab has been truckbed lined. Will probably get some insulation mat and a rubber mat over that. Has a mint factory dash gauge panel, with an inaccurate boat compass that I put in it that changes direction when the door closes, but it looks cool. Truck still has the clutch pedal, but since I am going with an auto, that clutch pedal will get a small master cyl hooked up to it and it will work the driveline/e-brake caliper on hydro, and the factory e-brake lever will work the cable part of it. Will have a dash to back of cab center console that will have cup holders, trans shifter, tcase shifters CB, gauges, etc.
Body protection will be in the form of 2''x5''x.25'' rectangular tube where the rockers currently are. It will be a shame to cut out nearly perfect rockers out of the cab to replace with hefty steel, but only the trained eye should be able to see the end result, and it will keep the cab from getting tweaked should it be rubbing the rockers offroad. Also have a 4''x.25'' wall tube bumper for the front, that will get some more plate and such, with feet first mounted winch on it tucked up under the grill/in front of the core support if possible.
Anyway, I've probably gone on too long and lost some interest because this is pirate and everyone wants pictures, but this is my first vehicle build thread so I'm still learning. Hope you've enjoyed the read so far, any comments, questions, suggestions, and criticisms are welcomed!
(Pictures will be in the next post)
Originally Posted by bronkho31 View Post
well fuck my face that is a big ass heim......
Originally Posted by buchanan454 View Post
Oh dear is right. Grumpy do you ever shut the fuck up. Go turn the propane on in your trailer and smoke. PLEASE
63GMCKid is offline   Reply With Quote
Old 01-22-2012, 10:52 AM   #2 (permalink)
63GMCKid's Avatar
Member # 121634
Well I found some old pictures on my photobucket so I'll start with those....
Here it is right after I got it, with the frightening 6 1/2'' tall rear lift blocks, clean engine, and a filthy trans/tcase. Had a 10b/14bff C&C, and a cracked and popped out windshield (thats what the tarp is for) in it when I got it.
Again this is an older picture, it still had the SM465/205 in it at the time, but this was right after I did the spray in truck bed liner and painted the dash. Note the cool guy liquid filled boat compass and perfect dash insert (not cracked or anything, just painted flat black)
And of course, the all mighty orb of traction, Eaton No-Spin/Detroit locker. For being in a truck bed trailer axle for 20+ years with a toasted R&P, this No-Spin is in mint condition.
Now these aren't actually my pictures, but this guy from another forum that goes buy Gouky gave me the drawings for this e-brake setup, great guy with lots of information, and these are pics of his e-brake setup, I cut out the same caliper bracket and my own rotor but this gets the point across. Uses an '89 Pontiac Grand Prix rear brake caliper, only $60 from RockAuto for a Kelsey Hayes reman.
Old 01-22-2012, 10:55 AM   #3 (permalink)
63GMCKid's Avatar
Member # 121634
Alright no real particular order here, just some pics to hold your interest!
First up, frame with front leaf spring crossmember. 2.5''x.25'' square tube with 3/8'' plate tabs for the leafs. 2'' and 3'' forward holes. Options are important, I like things to be tunable. Also in the picture is the engine mount crossmember. Excuse the mess of leafs, the cottonwoods in the yard are huge and next to impossible to clean up after.
Motor mount crossmember, excuse the rust, I finished this part a while back and it's been outside installed for mock up. Uses poly bushings, simple to install (it's self aligning with the bolt holes really, since the plates welded to the frame are angled away from each other at the bottom and towards each other at the front), rather than have individual nuts going through, there is another plate behind the ones welded to the frame with nuts welded on, so no trying to hold a wrench back in there, no fiddling with individual nuts, etc.
Of course, gotta have the weld porn...
Here is the rear Eaton HO72, not much to say here, has disc brakes, its painted to look cool (Flat black and Chevy orange), has a factory No-Spin locker and 4.56 cogs inside.
So here is why I am using Eaton HO72's..... They are considerably lighter than a 14bff and lighter still with disc brakes, higher ground clearance than a 14bff, all steel housing for welding trusses and link tabs to, ring gear load bolt, MASSIVE pinion shaft, no crush sleeve to worry about on the pinion (bearing preload on the taper roller bearing models is set with a simple spacer between the two bearings, can remove the yoke at any time and not worry about measuring the torque of the pinion yoke nut), axle shafts with no neck down - they are hoss from flange to splines, factory lockers aren't too hard to find if you go looking for these axles, still pretty abundant because alot of the street crowd sells them off due to lack of street friendly ratios. Only down side is bearings are expensive for these. The other positive things more than make up for that. They are a win win over 14bff's in my opinion.
And here is a quick pic of the housing I'm using for the Eaton/60 hybrid front axle, already have the spindles cut off of it. This housing is actually a '58 HO72 housing. The reason it got cut up for front axle use is because I learned the hard way that not all SRW HO72's are the same width. Earlier ones are about 1/2'' narrower per side than later ones, the difference can be seen in the axle shafts. I got later hubs all setup on this older housing with my discs and brackets, went to check to see if everything would fit and the calipers with pads wouldn't fit, the discs were 1/2'' too close to the caliper brackets on both sides. Then I compared an old housing to a later house and the spindles are slightly different in length, causing the problem. The reason they are like this is because the older HO72/52's used a slide on brake drum, and the later ones had a stud retained drum like the 14bff. Just something to keep in mind for you folks out there running the HO72/52 axles and wanting to do disc brakes. If your axle originally had slide on drums, later hubs will not solve the problem, you need special caliper brackets with less bend/spacing to them, or you need a later HO72/52 with stud retained drums. With the later ones though, EVERYTHING used to convert a 14bff to disc brakes bolts right up, only thing major your have to do is drill the hubs for the larger 14bff wheel studs. Anyway, here is the quick pic of just the housing for the front -
Old 01-22-2012, 10:57 AM   #4 (permalink)
63GMCKid's Avatar
Member # 121634
Alright now for some more welding porn. Made some 1'' forward offset motor mount plates for my motor mount crossmember. When I put that crossmember in, I moved the mount center line 3'' forward from where the previous owner had it, not sure if it was in the factory location as they were some hack mounts. Anyway, turns out that the engine is still 1'' behind the later model engine location, so I made these offset mounts. I also inadvertently raised the engine/trans up a few inches with this mount, which is excellent for offroad ground clearance, as a goal for this truck is to have a completely flat frame underneath with nothing hanging below it, but this scenario is bad for the floor boards. Time will tell just how much surgery I'll have to do on the cab to get it to fit. Anyway, here's the mounts with some TIG welding porn for everyone. Made of 2 pieces of 3/16'' steel, cut on the PlasmaCAM.
EDIT: These aren't finished yet either, still have to weld tabs to them and do some fancy machine work to them on the mill.
The e-brake caliper bracket, and a rough bench assembly to show how it goes together.
More TIG welding porn on the caliper bracket
Quick bench assembly showing the main component. Flange is from WFO Concepts, flange yoke is from DLSF (Driveline Service of Fresno) and I must say they have great prices on driveshaft builder parts, and a massive selection.
Check out the rotor, vented and drilled is bling trophy truck stuff for sure!
Old 01-22-2012, 11:04 AM   #5 (permalink)
63GMCKid's Avatar
Member # 121634
Now here is the part that I personally am the most proud of so far. These mounting plates took alot of hours behind the computer screen and out in the garage measuring to get the drawing perfect so when it cut on the PlasmaCAM, it turned out perfect. Both of my welding instructors at the community college own welding businesses and PlasmaCAM machines and were quite impressed by my mount plates here, as getting oddball clocked holes with uneven round bolt patterns to line up is no easy task.
First up, the divorced housing itself. Drivers drop Ford divorced NP205. Those massive chunks of iron for the factory mount locations are getting cut off in favor of the plates I made, which will get tabs and poly-bushings. Plates are made from 3/16 steel and cut on the PlasmaCAM. Got this housing from a Pirate member for the cost of shipping! I don't remember your username but thanks again!
Every single bolt hole lines up perfectly on both the back.......
and the front!
Did someone say super bling trophy truck sway bar arms? Got bored one day and drew these bad boys out and cut them from 1/4'' 6061-T6 aluminum, each arm is made of 3 pieces for a total 3/4'' thick. Why spend $300+ on a Currie Anti-Rock bar when I can machine some square ends on 1/2t truck torsion bars and make my own awesome looking arms? They aren't finished yet and kind of dirty from laying in the back of my daily driver truck for a while, but the pics should speak for themselves. As for welding them, it was all the little Miller Dynasty 200DX TIG machine could do at 200 amps to weld these beasts, once they were up to temp I didn't stop welding for anything! Done with a WP20 watercooled TIG torch and 3/32 tungsten, 200 amps and pedal to the metal. These will be for the rear sway bar, still figuring out the front.
Well every build needs a beefy part or two, so just for grins, here's some meat on this truck's bones...
A Dana 60 stub yoke next to a 10 bolt.... I think a see a puny little 10 bolt shaft back there somewhere...
And here is one of many reasons why I like the Eaton HO72/52 axles... the absolutely MASSIVE pinion shaft, what other axle out there short of 2.5t's has a pinion shaft that big? That ruler doesn't lie, 2'' and huge splines.
That's all of the pictures for now folks! Please feel free to comment, suggest things, criticize things, question things, or request tech for anything posted! And thanks for all of the welcomes and interest in the build! Much appreciated!
Old 01-22-2012, 11:06 AM   #6 (permalink)
63GMCKid's Avatar
Member # 121634
More cool transfer case mount tech to follow soon, been sick for the past week so I haven't been able to do anything with this. Next up will be welding on tabs and such for the tcase mounts, doing some work on the motor mounts, and an engine/trans mid plate mount.
Old 01-22-2012, 12:26 PM   #7 (permalink)
Bad Doctor
Odin K30's Avatar
Member # 86878
Cool project, Ive always liked that body style.
Good info too.
-Vinny
-from Elizabeth
Nobody cares about your rigs specs...
"Me too" short Crew build
/forum/chevy/994394-odins-me-too-short-crew-build.html
Odin K30 is offline   Reply With Quote
Old 01-22-2012, 03:07 PM   #8 (permalink)
Member # 138801
Amazing work ! Keep it up please for the sake of the Chevy tech section.
geo in a K5 is offline   Reply With Quote
Old 01-22-2012, 06:16 PM   #9 (permalink)
63GMCKid's Avatar
Member # 121634
Thanks guys!
Anyone have a preferred driveshaft parts supplier? I know that HAD is popular around here but I want to build my own shafts. The best 2 so far that I've found have been www.drive-lines.com which is Drive Line Service of Fresno, and then www.northerndrivetrain.com which is a little pricier than DLSF but similar selection. DLSF seems to have EVERYTHING of any u joint size series. I have ordered from them before with good luck, but wondering what other options do I have out there?
Now on the driveline tech side of things, when I built my motor mount crossmember I inadvertently raised the engine/crank centerline straight up by like 2'' or 3'', so my t-case, even though its divorced and I can put it where I want, will also be higher up. It will also be further back since it's a divorced case. Well all of this means steeper rear drive shaft angles. I am only slightly concerned about running 1350 joints, but the cost difference of going to a 1410 setup at the tcase (vs 1350 parts, prices being for a flange yoke, slip yoke, and weld on slip stub shaft) for the rear shaft is only a few more bucks for parts from DLSF. However, I already have a 1350 flange yoke though, so I'd have to spend another $43 for a 1410 flange yoke.
Anyway, my question is, is it really worth it to do to 1410 at the rear output of the tcase if I don't really have to? Lets assume that a 1350 joint will be able to reliably run in this setup in a single joint configuration, but we'll say that the angle is close to being where one would switch... I also want to avoid running a CV setup if possible.
So my options the way I see it currently...
1350 joint at rear output in the single joint configuration (no CV), already have the flange yoke, don't have any more parts for the rear shaft.
1410 joint at rear output in the single joint configuration (no CV), would have to buy the flange yoke and the rest of the 1410 parts for the rear shaft. Cost of the 1410 shaft parts are only a few bucks more, but a 1410 flange yoke adds another $43 to the cost. Remember I am on a starving student budget.
1350 CV at the rear output IF a CV can be run at the slip yoke end. I'd like to not have the slip at the diff if possible, but I don't know if a CV can be used on the slip end of the shaft, can someone school me there?
I guess I am not totally against the idea of a CV joint, but for ease of maintenance and ease of repair in case of breakage is a big factor here.
I also have some questions regarding slip stubs, the idea of only having say 2.5'' - 3'' of spline on the slip stub is not very appealing to me, but is this normal? Seems like the shorter length splines would wear quicker and have more slop and potential for vibration? Most of the high end shafts I see have full length splines on the male end of the weld on slip stub, but for a DD/Trail rig/remote offroad welding rig, is something like that going to be more than enough? Does anyone know where I could get the 1.5''x16spline weld on slip stubs with full length splines?
EDIT: Also looking for a weld yoke/tube yoke that will work with 3''x.120'' wall tube, anyone know where to get one? The yokes meant to work with that wimpy .083'' wall stuff just isn't going to cut it for me. I've searched a bunch of sites and anything meant to work with .120 wall tubing is aluminum...
And has anyone purchased from www.arizonadrivelines.com also known as "Drive Shaft Super Store" ? They have some of the long slip stuff that I'm after, but I remember hearing something a while back about them not being very reputable?
Old 01-22-2012, 06:28 PM   #10 (permalink)
poorboy1's Avatar
Member # 57031
Not exactly local but I have gotten a few parts from Tom Woods.
www.4xshaft.com
You mentioned a longer spline for your slip, I think he sells 22" long spline shafts.
My Chevy Build
TTC 2010
F-O-A.com
RUFF STUFF Specialties
Originally Posted by rus-t View Post
You guys keep building bad ass rigs, we'll keep building tiny versions of em'
poorboy1 is offline   Reply With Quote
Old 01-22-2012, 06:40 PM   #11 (permalink)
63GMCKid's Avatar
Member # 121634
Thanks for the link, I might give them a call, however, I'm not necessarily after long slip, more so full length splines on the weld on stub shaft. I just prefer the idea of maximum spline contact at all times vs. only 2.5'' at all times, especially for a rear drive shaft on a truck that will be "every other day" driven.
Old 01-22-2012, 06:45 PM   #12 (permalink)
Member # 37340
Great project. I will be watching this one. Love to see new life breathed into old iron.
zainyD is offline   Reply With Quote
Old 01-22-2012, 07:25 PM   #13 (permalink)
Newbie
smokinjimmy's Avatar
Member # 195558
Nice build.
72 jimmy 63" ers, 52"ers, 37"s soon
05 cummins 6spd 3500non dually short bed tow pig
http://www.pirate4x4.com/forum/showt...705&highlight=
smokinjimmy is offline   Reply With Quote
Old 01-23-2012, 03:58 AM   #14 (permalink)
Member # 192237
They do that because the transition from splines to yoke or tube is a much larger stress riser than splines to shaft [cut down to minor diameter of the splines] to whatever larger diameter thing.
Keep doing what you're doing, you seem to be doing plenty well.
[486] is offline   Reply With Quote
Old 01-23-2012, 05:13 AM   #15 (permalink)
Member # 173265
Cool looking build man, I say go the single 1410 route! Saying this I must admit I haven't finished my rig enough to drive it yet, but its what I decided on too. With a single joint(I have divorced case as well) there may be a bit of vibration over a cv but alot of the time the cv is what fails so I wanted to eliminate a cv. With a 1350 single joint i would have had to limit some of my downtravel so I went 1410 single for the extra angle and strenght!
1981 K20 pirate4x4.com/forum/showthread.php?t=996844
chevy_phil is offline   Reply With Quote
Old 01-24-2012, 06:42 PM   #16 (permalink)
Member # 137644
Send a message via MSN to HEAVY METAL
very cool !!
WHEELIN A P40 WARHAWK
HEAVY METAL is offline   Reply With Quote
Old 01-25-2012, 03:45 AM   #17 (permalink)
Member # 23452
Very cool build, can't wate to see the front Ho72 axle, or at least on a driving rig.
Jason.
93 yj 4.0 700r/241 HP 60 front 5.38's, Chevy 60 rearsteer 5.38's, bolth spooled and beating it like it owes me money.
420willys is offline   Reply With Quote
Old 03-10-2012, 09:39 PM   #18 (permalink)
63GMCKid's Avatar
Member # 121634
Sorry for the lack of updates folks, I'm on spring break now so I'll be doing quite a bit more work on this truck. Did quite a bit already though, so just a quickie update for now, pictures will be uploaded tomorrow....
Extended the frame back out to factory length in the rear, had to cut off the last ~10 inches because the previous owner booger welded a hitch to it and wasn't worth trying to remove it from the frame. Used some 4''x2''x3/16'' wall rectangular tube to put the frame back out to factory length, it fit in between the frame rails perfect and I welded it all around, should be stronger than the original!
Then I got my leaf spring hangers bolted up as well as the shackle hangers. Leaf hangers are from a 2wd 3/4t 73-87 GM truck and the shackle hangers are from a 4x4 3/4t 73-87 GM truck. Using 56'' 3/4t leafs in the rear with a 4'' block. I didn't really want to use lift blocks, but I can't afford new springs right now and I didn't want to use the 73-87 4x4 leaf hangers because they hang really low and it would've looked stupid, and I've seen lots of trucks that have factory lift blocks in the rear, so I think I should be alright. And I am using the 73-87 tension shackle setup, so I don't think axle wrap will be a problem, and because this truck wont be a super hardcore wheeler with flexy springs, I'm not really worried about it. If it becomes a problem, I'll either pony up for custom made Deaver springs or lift springs of w/e brand, or build an anti-wrap bar.
Also made a midplate mount from some 1/4'' 6061 aluminum, cut out on the PlasmaCAM at work, bolts between the engine and transmission and will have a poly-bushing on each side, should never have to worry about cracking a TH400 bellhousing with this midplate.
I also built that GotTrikes air/hydro tube bender since the last update, and I am very pleased with how it turned out. Still learning how to set up my bends so they are in the right places, but its super easy to work with since it bends in the vertical plane. Expect to see some tube work on this truck in future updates!
I cut up a rusted out 64/5/6 chevy cab to use as a mock-up floor and firewall, just cut the back off right below the big dimples and cut the windshield pillows a couple inches above the dash. Has a perfect unmolested dash and firewall to work with for mockup purposes, and its a large hump cab like my GMC cab, great to checking driveline to cab clearance and its light enough without the roof/back that it can be picked up and moved around easily with 2 people. I put it on my frame today after I got the Eaton back under the rear springs and back to rolling frame status again.
Tomorrow I'll be working in boxing the frame from the core support forward, since my front leaf hanger crossmember is there and that supports alot of weight, figured it would be better off if I boxed it in. I've got a badly bent 63 1/2t 2wd frame that I can cut the front end off of just ahead of the core support, perfect match for boxing in my frame. After that I'll be starting on my transfer case crossmember and transmission mount crossmember.
Pictures of the current progress should be up tomorrow!
Old 03-11-2012, 09:50 PM   #19 (permalink)
63GMCKid's Avatar
Member # 121634
Alrighty, here's the pics....
BEFORE YOU POST SAYING "GET RID OF THE LIFT BLOCKS", I KNOW, LIFT BLOCKS SUCK.... But this isn't a super hardcore wheeler by any means, it just needs to get me to wherever I want to go in the back country and highway reliably, and lots of trucks come with blocks in the rear from the factory and don't have problems, so again, I know everyone here thinks blocks suck, I know that I should eventually get rid of them, no need to post saying such things. Have to use this disclaimer because I know someone will post about the blocks anyway.
Mockup cab with bare block and empty TH400 case in place, everything clears, lots of room behind the engine!
Mid plate mount, and engine/trans to firewall/floor hump clearance
Gotta show off the aluminum welds! :metal:
Rear suspension and Eaton HO72 with disc brakes and a Detroit/No-Spin inside
Extended frame and shackle hangers, still need to plate the rectangular tube between the shackle hangers and the tube so the surface is flush with the side of the frame.
Showing off some more welding, nice beads all the way around the rectangular tube
More of welds, also note the fish mouthed frame, less likely to crack and with a longer weld, stronger overall.
They didn't come this pimped out from the factory! Awesome paint scheme (flat black and Chevy orange), and a Detroit and discs, doesn't get any better than that!
Old 03-11-2012, 09:51 PM   #20 (permalink)
63GMCKid's Avatar
Member # 121634
And here are those transfer case mount plates, everything fits up perfectly! Don't mind the funky plate bolted to one of the factory mounting bosses with 2 poly bushings, that was a failed attempt at a cool setup, going to go with a single wide poly bushing there instead of 2 angled ones.
Front...
Back...
Now I am working on the transfer case crossmember(s), since the factory divorced tcase crossmember has to come out, I needed another structural piece to add to the frame, so I cut 2.5'' square holes in the frame, going to weld in the 2.5''x1/4'' wall square tube (not yet cut to length), have holes drilled through those 2.5'' tubes, then have 2''x1/4'' wall square tube that goes through the 2.5'', and bolts will run through that as well. Should stiffen up the frame quite a bit in this area, and will serve double duty as a skid plate mount and transfer case mount. The case itself will have poly bushings, but these crossmembers are obviously solidly mounted. The individual tubes that will go up to the poly bushings will bolt into the 2'' tube after its slid through the frame. The long winded explanation may be a little difficult to picture, I've got a pic now with just some scraps of tube in place to give you a better idea of what I'm going for here. Should have this finished by tomorrow with more pics.
Old 03-11-2012, 10:22 PM   #21 (permalink)
mega hack!!
sjracer's Avatar
Member # 139150
i like it so far. good detailed build. why is the cab cut in the last set of pics?
74 chev tbi 350 sm465/203/205 d60 ARB/14b detroit 56's/64's on 40's!
/forum/chevy/933618-new-old-black-getting-1-ton-makeover.html
sjracer is offline   Reply With Quote
Old 03-11-2012, 10:48 PM   #22 (permalink)
63GMCKid's Avatar
Member # 121634
Thanks!
That cab was rusted out so I turned it into a mock up cab, the drivers rocker internal sheetmetal, external rocker sheetmetal, and floor right next to the rocker is only about half there, and the cab corners aren't in much better condition, but the back of the cab and roof were still good. Figured the floor/firewall/dash would be good as a mock up cab, and with the back and roof cut off, its light enough that it can be picked up with just 2 people.
Old 03-11-2012, 10:58 PM   #23 (permalink)
Devout Newbie Hater
Grumpy_old_fart's Avatar
Member # 20147
i finally get to see pics... I cant see them at work.
looks pretty damned good from here. if you ever get bored, i could use some welding lessons, and I would probably take them from you... damn you can lay a nice bead.
Keep up the good work.
and dont give me any shit about making a compliment.
sympathy, empathy and apathy... i dont know which one is which....
But i know you can find sympathy between shit and syphilis in the dictionary.
Win this car for a whole BUCK!
Grumpy_old_fart is offline   Reply With Quote
Old 03-11-2012, 11:08 PM   #24 (permalink)
63GMCKid's Avatar
Member # 121634
Thanks!
About the welding though, if you are near a community college look into what they might have for a welding program, that's where I learned and got my certifications, the community college here has an amazing welding program, the tuition cost has been worth every penny.
lol at your invisible font
Old 03-11-2012, 11:33 PM   #25 (permalink)
Member # 179016
With your fab skills and the plasma make a flipped shackle setup for the rear. It'll get rid of the lift block and you can make it to reuse the same shackle.
This is ORDs, also the first one to come up in a google image search.
lowrollin70gmc is offline   Reply With Quote
