After searching i pretty much came up with take the rear most vss from the 246 and cut the connector off and splice it into the vss on the 241 case. Everyone says the wire color even matches, green and purple. My problem is the 241 case i am using didnt have the connector on its vss. Does it matter which wires goes to which side on the vss? Or is it as simple as trying it one way to see if it works, then switching them if it doesn't. I dont want to hook it up backwards and screw up the sensor.
