gm 10 bolt options? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-15-2012, 08:53 PM   #1 (permalink)
Member # 211678
gm 10 bolt options?
i have a GM 8.5 10 bolt, wanting to beef it up and go posi, but im wanting to still drive it on the road, but when i go to do a burnout i want both tires to light up all the time no problems, and i have heard a spool can be dangerous, so if you guys can give me some options and a list of stuff i need to do along with it! thanks
swanksta is offline   Reply With Quote
Old 02-15-2012, 08:56 PM   #2 (permalink)
Whatever Works
JM93LiftedYJ's Avatar
Member # 128472
First.
Samurai Build on a Low Buck Budget: The Tin Can
1. NEVER, EVER date a single mother.
Work harder. Millions on welfare depend on you.
JM93LiftedYJ is offline   Reply With Quote
Old 02-15-2012, 08:57 PM   #3 (permalink)
Member # 174101
Step 1: Toss that POS in the garbage.
Step 2: Install a 14-bolt in its place.
Step 3: ????
Step 4: Profit.
i960 is offline   Reply With Quote
Old 02-16-2012, 04:45 AM   #4 (permalink)
Member # 211678
around what year would i find one under thats semi float?
Old 02-16-2012, 06:06 AM   #5 (permalink)
KyleQ's Avatar
Member # 83837
It's a time bomb, it will explode, it's just a matter of time. Any money put into a 10b is money thrown in the trash...
74' Bronco - Mustang Injected 5.8 - 105:1- Locked D60/70HD - NP435 -Atlas2 3.8 - PSC Full Hydro - 5.5" lift - Cage Arms - 37" Cut & Grooved Boggers
Bronco Build Thread
KyleQ is offline   Reply With Quote
Old 02-16-2012, 06:42 AM   #6 (permalink)
Member # 139990
there is a thread started about the 14 bolt semi float 6 lug already just scroll down and start reading bud
its on page two in this chevy section
trucks are built, maintained, repaired by humans, you are a human you can do anything
adam765 is offline   Reply With Quote
Old 02-16-2012, 07:03 AM   #7 (permalink)
Member # 183520
Do what? Search and read? That is only for literate people.
I never get stuck, only temporarily delayed!
OutlawRider is offline   Reply With Quote
Old 02-16-2012, 08:25 AM   #8 (permalink)
Member # 13786
10 bolt+posi+ burnouts.................hmmm, we want a video of the carnage
KWTMECH is offline   Reply With Quote
Old 02-16-2012, 08:28 AM   #9 (permalink)
party wagon
FordX4-offroad's Avatar
Member # 202878
x2
jeep is getting a new home!
NEW PROJECT ON THE HORIZON!!!
E-350
12 valve cummins, 2006 F350 axles, 6" lift and 37's
FordX4-offroad is offline   Reply With Quote
Old 02-16-2012, 02:00 PM   #10 (permalink)
Member # 83920
First thing I would do, is get a new screen name, and never use that one again, for a number of reasons.
This isn't meant to be a flame job, but Jesus, do you guys ever read or search? Do you suppose your question has already been answered somewhere? Look it up for your fuckin self.
dahoyle is offline   Reply With Quote
Old 02-16-2012, 06:57 PM   #11 (permalink)
party wagon
Member # 202878
E-350
Old 02-16-2012, 09:25 PM   #12 (permalink)
Devout Newbie Hater
Grumpy_old_fart's Avatar
Member # 20147
shit.... we've seen the carnage.. why bother?
for the OP...
Take your right hand...
put it 10 inches behind your head
now SWING!
sympathy, empathy and apathy... i dont know which one is which....
But i know you can find sympathy between shit and syphilis in the dictionary.
Win this car for a whole BUCK!
Grumpy_old_fart is offline   Reply With Quote
Old 02-17-2012, 12:05 PM   #13 (permalink)
Member # 13786
For the brief 10 seconds of mild entertainment
Old 02-23-2012, 10:31 PM   #14 (permalink)
Member # 198400
it all depends on the tire size you are running, and what gear ratio you want to throw in there. Any increase in tires size over stock will put more strain on the axles and joints. Changing to a lower gear ration will also put more strain on the axle shafts. The posi unit will help slightely offroad but is nothing compaired to a locker. The posi unit will increase your chances of breaking a shaft offroad. Now depending what size tire, gear ratio, and how much power you are putting behind all of this is what you need to consider. That axle is fine on road and offroad without mods, the second you change anything is when you really need to be careful. This happens with every axle, if you run 44inch tires on a stock dana 60 you will break it all day long.
If I were you I would keep my tire size under 35inch, and lower if possible. Also I would not go over a 4:10 gear ratio, anything over that and you will be pushing it. As far as a posi unit goes, why put a posi unit in a weak axle. On the one hand a posi unit doesn't help much, and it costs almost as much as a regular locker. If you are completely decided on a posi unit consider going with a lockrite and some manual locking hubs, that way when you pull on the street you can unlock your hubs and not break your axle shafts. Next I would get a forged diff cover of some sort, like a dynatrac or an ARB if you can find one. For the price it increases the overall axle tube strength and prevents flex in the tubes and helps the gears to stay more closely mated. This would be a relatively cheap axle build and would keep you from breaking as easily as a stock unit, however you are starting with a weak axle so there is only so much you can do. There are other options out there like forged knuckles and chromoly axle shafts. This is not the end of the road for this axle, you just need to figure out what you need it to withstand and develop a plan for making it strong enough to take the beating you put on it.
hope this helped
-Daniel
dpdatsunman is offline   Reply With Quote
Old 02-24-2012, 10:46 AM   #15 (permalink)
Member # 132811
This is why you dont piss money at them
1979 Bronco 390 swap c6 in process.
oldschoolrides is offline   Reply With Quote
Old 02-24-2012, 10:58 AM   #16 (permalink)
Member # 13644
You like banana's? Only way to get a 10 bolt to live is to pack the housing with banana peels before adding the oils.
classicgm is offline   Reply With Quote
Old 02-24-2012, 11:16 AM   #17 (permalink)
Member # 83920
-Daniel
Bullshit. If you break an axle on a 60, you might or might not be able to drive out, with three wheels pulling if you are locked, or front wheel drive if you aren't. You break an axle on the POS 10 bolt, then you get a tricycle.
The OP's stated goal is 2 wheel burnouts, which implies that he intends to abuse it. Nothing about the 10 bolt is suited to abuse. The fact that you can break anything, doesn't make the 10 bolt a better axle. It's a POS barely suited to mild DD use with light loads, and low to moderate power levels.
Oh, a little reading comprehension goes a long way. He is interested in 2 wheel burnouts. How exactly does installing lockouts up front help prevent rear axle breakage? Same goes for forged knuckles, if any such thing actually existed, and it doesn't. They are all cast.
In any case, the entire thread is fucking stupid. It isn't like there isn't a ton of info out there about the axle, it's weaknesses, and what parts are available to "build" it.
Lastly, the idiot who posted the question combined the words "swank" and "gangsta" to come up with a screen name. There is nothing I can possible say about that, other than marvel at it's ...... Fuck, I don't know, I'm lost for words on that, other than it just makes me nauseous.
Old 02-24-2012, 11:27 AM   #18 (permalink)
Member # 185237
This happened to me twice with a 10 bolt. Once on a trail the diff blew up, and I mean broken teeth, ring gear in pieces, spider gears in pieces, carrier in half broken. Then once on the road, I had just sold a suburban to a guy, road was iced, he made it down the street tire started to spin and BOOM, same problem. Go 14 bolt, it'll save you money.
Sent from the road while ignoring traffic
kryptonitecb is offline   Reply With Quote
Old 02-24-2012, 06:18 PM   #19 (permalink)
just4cuz's Avatar
Member # 98655
Originally Posted by blazerman71 View Post
theres not much parts to beef up a 10 bolt.....if your axle is 6 lug I would suggest finding a 6 lug 14 bolt semi float under a tahoe and swapping it in........ 10bolt axle + locker+ burnout= blown up axle or busted axle shafts
Not gonna find very many in Tahoes unless it is a 2 door diesel. Better to look at pickups with the F-44 code. 6 lug 2500's all have them from what I have seen and experienced. If you want to do burnouts why spend so much money, just weld it up. When it blows up, go buy another and weld it again. They are, cheap plentiful, and suit your purpose just fine. When you have a hardcore 4x4 question you should come back. Until that point you should post general questions like this in the general, 4x4 newbie, I'm a swanksta in my dreams forum.
just4cuz is offline   Reply With Quote
Old 02-27-2012, 11:16 PM   #20 (permalink)
Member # 110034
2-door Tahoes came with a 10 bolt, for both gas and diesel.
93_Burrito is offline   Reply With Quote
Old 02-28-2012, 12:05 AM   #21 (permalink)
Member # 138801
how old are you ?
geo in a K5 is offline   Reply With Quote
Old 02-28-2012, 09:28 AM   #22 (permalink)
Member # 198851
GM 8.5 10 bolts can be found under 10 second cars at the drag strip.....They are fine with a good posi,not Gov-Loc, for street use with the usual auto tranny.
Abuse off road with big tires and something always seems to break.........
ADChevy4x4 is online now   Reply With Quote
Old 02-28-2012, 09:32 AM   #23 (permalink)
Member # 160119
beef up a ten bolt=swap to something stronger
the end
TTC 2011 Competitor
77WarPig is offline   Reply With Quote
Old 02-28-2012, 09:40 AM   #24 (permalink)
just4cuz's Avatar
Member # 98655
Pre 95 full size blazers with a 6.5 had a 14 bolt semi-floater in them and a 4l80 trans.
Old 02-29-2012, 10:37 AM   #25 (permalink)
Member # 130928
When people say things like "go posi" or "is it posi" It makes me want to punt them.
86 Silvy - 355/TH350/208/60F/12bolt(14FF Soon)/4.56s/37x13 Boggers
ryan_thompson87 is offline   Reply With Quote
