Member # 212864
chev power pump to toyota ifs box help
So I am wondering how to hook up my chevy power-steering pump to my toyota gear box. is there and adapter or where to get a custom hose made. I dont have the chevy hose just the toyotas.... if that info helps.
skullfuckery
Member # 29016
you can 6+ different an- fittings to cover the various o-ring and flare diams, that + the high psi earls hose and you can make any box fit any pump and work in any situation with out a dead hard commitment of a custom pre made line.
Impeach or revolt, which will it be? buy my quad http://www.pirate4x4.com/forum/vehic...00-2500-a.html I WILL TRADE FOR A ROAD WORTHY 55-57 or 71-87 CHEVY 2WD PICK UP |
Member # 32786
When I did a 4.3L V6 swap on a 84 Toyota P/U, I used a chevy high pressure power steering hose. I cut the line at the steering box end, removed saginaw fitting, did the same to stock toyota hose and put the fitting on the chevy hose and flared line. If I remember right I used a single flare die and it worked for years and years without problem.
79' K10 350 F.I./ TH350/ NP203/NP205/D60/14FF & 42's 02' GMC crew cab D-Max 79chevyk10 everywhere else. Save The Hammers Rally Post #314 Tellico Rally Post #20 |
