super 10 kit from off road direct - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-16-2012, 11:12 AM   #1 (permalink)
Member # 195346
are any of you guys using the super 10 kit from off road direct?? how you guys like it? it says it uses cherokee coils, so would i be able to ran rustys off road 8" lift? what kinda lift and tires can you run with the super 10 kit im looking to run 35"boggers im not into hardcore wheeling but just do trail rides. should i use this kit? i can buy the d30&35 for $175 for both axles
forddestroyer is offline   Reply With Quote
Old 03-16-2012, 06:24 PM   #2 (permalink)
_Stucky's Avatar
Member # 182743
In case anyone is wondering wtf the super 10 kit is:
https://www.4wdfactory.com/store/pro...uper-10%22-Kit
http://shop.synergyoffroad.com/82-04...it-Super10.htm
Some tech: I believe what you are looking for starts on about page 6
http://www.s10forum.com/forum/f221/n...34/index6.html
And a guy that bought the kit:
http://www.s10forum.com/forum/f221/s...37/index2.html
Can you tell I've been lurking the s10 forums?
Edit: from the 2nd link:
•Kit is designed to use the Jeep XJ lifted coils. Listed lift heights for the coils will be the same for the S10. I.e. 4.5" lifted jeep coils will provide 4.5" of lift on the S10. Although you could use stock coils, it is not recommend as this will limit up travel of the radius arms.
•The S10 lug pattern and ABS system may be retained by using the S10 unit bearing to XJ adapter ring and re-drilling the jeep rotors. (Not included in the kit but available from Off-Road Direct).
_Stucky is offline   Reply With Quote
Old 03-16-2012, 06:36 PM   #3 (permalink)
Member # 145566
Haven't used this particular kit. However i can say that i am running the fullsize sas kit and shock hoop's etc. I'm pleased with the product's and would not second guess ordering a different kit from them.
dagen is offline   Reply With Quote
Old 03-17-2012, 07:40 AM   #4 (permalink)
Member # 195346
but i would have to ext. the arms if i go any real height i read that but what about the arms thats going to change. might have to buy and try
Old 03-17-2012, 10:04 PM   #5 (permalink)
Member # 128462
You will destroy a D30 and D35 with 35" boggers. My buddy just snapped a D35 axle on his jeep TJ and he's only running 33's. S10's are close to 1/2 weight so I'd suggest running at least 1/2 ton axles. Lift wise, you'll need about 5-6" to stuff 33's. I'm running about 9-10" with 38's on 15x8 wheels with some trimming. I suggest you study up on SAS's for a while before you make your decision. It may not be worth the trouble depending on how serious you plan to wheel
My Build Page: [url]http://pirate4x4.com/forum/showthread.php?t=912671[/url]
S10ZR2 is offline   Reply With Quote
