Member # 8635
Difference between Military Dana 60 and non?
As it relates to the GMC/Chevy Dana 60 front end... Is there a difference between the ubolts on a Military Dana60 and a non-military D60?
I have sold tons of aftermarket ubolts for Dana 60 front ends over the years and I have a customer who says the aftermarket ubolts I sold him are too long for his military Dana 60. He says his stock passenger side studs are 2.5" long. That seems really short considering the ubolt/spring plate thickness, leaf pack thickness and getting enough thread into the axle housing to be safe. I was not aware of any differences. Are there any? |
Way tougher than you
Member # 141446
A previous owner probably cut the studs down for some reason. Ask if he has had those studs on a running truck at that length.
I carry a gun, because a cop is too heavy ECV 3-Lord Sholto Douglas |
#3 (permalink) | |
Member # 8635
I asked for pics of the stock leaf springs but he says he doesn't have them anymore. I asked him if he chased the threads to rule out rust/grim and he said he did. |
Member # 141446
I'm calling BS on his side of the story then. If anything, the leafs on the CUCV trucks are a thicker pack for MORE weight carrying capacity, not less. There is one for sale that I'll be driving by tomorrow. I will measure and see if I can get a picture as well.
#7 (permalink) | |
Member # 8635
Do you know if the mounting area where the leaves meet the axle or where the studs attach to the axle are different than non-military Dana 60's? |
skullfuckery
Member # 29016
no they are the same.
some people will claim that mil axles have better inner axle shafts because they are non-neck down shafts. they are half right, all mil axles are non-neck down, but so are all other gm 60s after 1980ish.
Impeach or revolt, which will it be? buy my quad http://www.pirate4x4.com/forum/vehic...00-2500-a.html I WILL TRADE FOR A ROAD WORTHY 55-57 or 71-87 CHEVY 2WD PICK UP |
skullfuckery
Member # 29016
because they are designed for thicker shitty lift kit packs.
buy the ruffstuff ones, cheaper and will work with thin packs.
Impeach or revolt, which will it be? buy my quad http://www.pirate4x4.com/forum/vehic...00-2500-a.html I WILL TRADE FOR A ROAD WORTHY 55-57 or 71-87 CHEVY 2WD PICK UP Last edited by trkklr77; 05-07-2012 at 09:32 PM. |
#12 (permalink) | |
Devout Newbie Hater
sympathy, empathy and apathy... i dont know which one is which.... But i know you can find sympathy between shit and syphilis in the dictionary. Win this car for a whole BUCK! |
#14 (permalink) |
Devout Newbie Hater
This is what he is saying.
#16 (permalink) |
Member # 147260
never heard of such a thing and swapped plenty of dana 60's hes
something
it will never be done 84 shortbox ,b52's, dana 60 14 bolt 4.88's detroits, 383/400/203/205, 44 boggers on h1's = junk /forum/chevy/1077202-shortbox.html http://www.facebook.com/jacob.buchanan.52 |
#17 (permalink) | |
Member # 35786
For that reason, we have our own u-bolt kits and studs that are actually right. I didn't see that they have the right size u-bolts or the studs, am I missing it?
We specialize in full size Chevy parts but if you need steering, transfer case gearing, suspension etc. for just about anything give us a call! chrish@offroaddesign.com offroaddesign.com 970-945-7777 |
#18 (permalink) | |
Member # 8635
I use them on my personal vehicles as well. Mostly Rough Country lift kits, but one Superlift kit. Here is one of mine I just took a pic of with my cell phone: ![]() I clearly list all the measurements in my ads, but long story short he is returning them and I am giving him a refund. All is good.
#19 (permalink) | |
skullfuckery
Member # 29016
#21 (permalink) |
Member # 38563
I have the U-bolt kit from ORD on my 84' M1031 which is a K30 D60. The pass. side bolts have two lengths in the ORD kit. With the new ORD supplied springs, I had to use the longer bolts with two washers up top to keep the bolts from bottoming out before the U-bolt plate became tight. Other than that, it was bolt in easy peezy. All of the u-bolts needed to be trimmed after final tightening. Not sure what the issue is
![]() The ONLY difference on the mil. spec D60 is the OEM 4.56 gears and if you made the correct military vehicle purchase such as myself, a stock traclok up front
95' 4Runner with 5VZ engine WTB...winch bumper 84' M1031 CUCV 37's, 8kW gen |
#22 (permalink) | |
Member # 140580
1996 DODGE 2500, 4X4, CUMMINS, 370'S, 5GSK, MACK PLUG, STUDS, SFI FLEX PLATE, DERALE DEEP PAN, EMS HUB KIT WITH 35 SPLINE INNER AND OUTTER MOSER AXLES, WARN GOLD LOCK-OUTS, 3 IN. LEVELING KIT, DUAL EDELBROCK REMOTE RESERVOIR SHOCKS, ROUGH COUNTRY STEERING STABILIZER, STEERING BOX BRACE.
#23 (permalink) | |
Member # 35786
The u-bolts and studs are all our own now, correct length and work with pretty much anything. It's common to have to trim u-bolts, it allows us to make the u-bolts work on a variety of spring packs.
#24 (permalink) | |
Member # 38563
#25 (permalink) |
Member # 8635
The guy who bought the ubolts from me ran out of threads on the passenger side diff studs.
The orange circle in the image below is the area that ran out of threads. This image is just an example since there were plenty of threads on this install. ![]() Makes me wonder how many other people I've sold these ubolts to have had the same problem but ended up stacking washers or ??? |
