just a welder
I went through this thread and I thought why is this in the Chevy section? Is that a Toyota engine? Then I seen the last post and now I see where this is going. I think I would have waited to put the tube over the engine after the swap so you could get the most visibility as possible but it might work out.
My S10 truggy 42's, Atlas 4 speed, tons and whole lot of rolled tube 4bd1t/NV4500/205 and some tube ready to into the next daily driver expedition vehicle with "modest" size tires.
The new heart transplant begins
![]() ![]() Cutting the firewall for placement ![]() its Christmas ![]() not all the way bolted in or even near. Looking to see what else we need to cut to make way for the headers.. ![]() bye bye floorboard.. Making new mounts cause the other ones was SHITTY!!.. Very badly welded and misplaced. A big weak point.. ![]()
#12 (permalink) |
Member # 192110
Cool build, probably the best way and most affordable is to buy a buggy like you did then redesign like you want. You probably saved lots of $$$$ buying a used buggy. I dig your new tube work looks good! Now ditch the patio furniture grill and it will be smokin!
1992 chevy 1500 350tbi, HPdana60 open, Sterling 10.5 truetrac. Fishin/winter truck |
#13 (permalink) |
Awesome Fab Tools
Member # 84883
what are the links made out of? Cool tube work. I like the look so much better. And it looks a lot stronger as well. How is the visibility?
ROGUE FABRICATION -Portland, OR Air/Hydraulic Tubing Bender $580 with 180 Degree Dies Drill Press Reduction Kits $119 Shipped Joe@RogueFab.com www.RogueFab.com |
#14 (permalink) |
The links are VERY VERY cheap. The driver rear bent double the first time out thanks to a painted aluminum bar. Who'd thunk it!!.. Actually the visibility is good.. My head is about 2 inches from the roof. My buddy and I actually done the tube work (his first one).. He done a great job.. Couldnt be more happy with the way it came out.. Now im looking forward to shortening it about 7-10 inches in wheelbase cause its 125 now and its way to long for what I do.. Im completely cutting off the front from motor mounts up (keeping the hood) and redoing the front. Throwing away the lawn grill and running a double frame with a upward spike to almost touch the hood.. Hopefully with a lil planning I can do it..
#16 (permalink) |
Member # 192110
Throwing away the lawn grill and running a double frame with a upward spike to almost touch the hood.. Hopefully with a lil planning I can do it..[/QUOTE]
That will be the icing on the cake.
#19 (permalink) | |
Sticks and Stones
Member # 115122
Piss on everything I'm going four wheelin! |
#20 (permalink) |
As for now.. I'm leaving the closed knuckle drum.. It works good enough for me.. And I AGREE!!. I need some sort of bump stop. The 22R that was pushing it was crawler speed only. When I down graded from a 305 TBI, even tho it wasn't ate up with power it still had lots more than the 22R. All my buddies run a 22r and I figured "what the hell". But soon realized its not for me. and I do need to make the pan-hard bar a lot longer.. I am planning on completely cutting off the lower front section this winter when riding season is out.. And at that time Im going to delete about 10 inches of whee-base as well.. as of now its 125 inches... I'm goaling for around 115-117 inches and at that time (income taxes pending lol) I'll upgrade my heim joints.
#21 (permalink) |
Member # 137
You're cage design looks
![]() Those axles were a good match for the 'lil 22R. Now that you way upgraded the motor's HP, you should at least think about swapping in cromo shafts for those M715 axles. Now, finding someone to cut you course splined shafts may be a problem. Or, you may need to just swap, if that's possible, the side gears in each of your carriers to get fine splines.
'72 FJ55 http://forum.ih8mud.com/showthread.php?t=76835 '73 FJ40 http://s132.photobucket.com/albums/q...&addtype=local '78 FJ40 '91 Ram W250 5 spd. CTD '93 Ram W350 5 spd. CTD '99 Ram 3500 4X4 5 spd. CTD Welding is like sex, it's all about the penetration! Last edited by LC Hamma; 07-11-2012 at 10:35 AM. |
#23 (permalink) |
Member # 166945
Pretty much bad. I think the shafts are comparable to a 44, the obvious drum brakes, coarse splined, and I think next to impossible to find parts for, as they are unlike all other 60's, other than gear sets
2nd Gen s10 thing. 4.3 4l60e twin 241, 60/14 welded 5.38's 56's on slider boxes, 63's |
