Axle Truss - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 08-20-2012, 11:23 AM   #1 (permalink)
Member # 167685
Axle Truss
Hows it goin guys, is anyone aware of a Axle Truss kit for a 85 K10, stock axle housings, just looking to toughen them up a bit. Has all new internals, carrier, LSD and gearing, just want to beef up the housing. Appreciate it guys
[B][COLOR="DarkSlateGray"]Ogrestrength[/COLOR][/B]
[I][SIZE="2"]"Do not go where the path may lead; go instead where there is no path and leave a trail"[/SIZE][/I]
Diesel2 is offline   Reply With Quote Quick reply to this message
Old 08-20-2012, 12:13 PM   #2 (permalink)
fcfred's Avatar
Member # 3263
depens on what you want to do with it. some guys run a cable from C to C under the housing. helps keep it straight when jumping. not much use for rockcrawling as it hangs down under the tubes.
Team Tank
old junk, new junk, unfinished junk
Live Large-RIP Jason Payne
fcfred is offline   Reply With Quote Quick reply to this message
Old 08-20-2012, 12:29 PM   #3 (permalink)
Member # 167685
Just a simple top axle truss would suffice, just looking for a way to strengthen the housing essentially.
Old 08-20-2012, 01:02 PM   #4 (permalink)
Member # 139150
are they 10 bolt housings?
if so not worth trussing, the axle shafts will snap off the ends or you'll grenade a wheel bearing LONG before that axle housing bends.
if your still gonna put money in it, check Ruffstuff, they have universal axle truss's
(input truck specs here to prove level of badass and gain Pirate street cred)
<< post picture of badass pirate approved truck doing some epic wheeling
sjracer is offline   Reply With Quote Quick reply to this message
Old 08-20-2012, 01:24 PM   #5 (permalink)
Member # 130483
this
you will break a shaft long before the housing bends
99 Silverado,35's,locked 14b,4.8L,nv4500
92 s dime is offline   Reply With Quote Quick reply to this message
Old 08-20-2012, 02:38 PM   #6 (permalink)
Member # 167685
I have installed higher quality shafts, along with internals from eastern gear. 1541H with a high stress trajectory The shafts are no issue
Old 08-20-2012, 03:18 PM   #7 (permalink)
MNorby's Avatar
Member # 11448
Send a message via Yahoo to MNorby
LOL
Posted with mistakes from my phone.
MNorby is offline   Reply With Quote Quick reply to this message
Old 08-20-2012, 03:23 PM   #8 (permalink)
Member # 167685
Originally Posted by MNorby View Post
LOL
I am by no means new to this, I fabricated Truss' on my Bronco. I do not have the time right now so I'd rather buy some weld on pre-fabricated that I can get done over the course of a weeknight.
In regards to the K10 shafts, They seem to be handling this just fine:
Old 08-20-2012, 07:39 PM   #9 (permalink)
Member # 183520
Just buy the trusses out from under the fall guy truck.
Then again, his were probably 3/4 ton or ton axles. Something tells me he found out the axles will break if there put under that much stress.
I never get stuck, only temporarily delayed!
OutlawRider is offline   Reply With Quote Quick reply to this message
Old 08-20-2012, 09:37 PM   #10 (permalink)
Member # 139150
i'm sure they'll get you all the way to the scene of the accident.
"and in other news, a busload of orphans and nuns was killed today when some stubborn ass that didn't want to listen to the voice of experience had the wheel come off his truck and plow through the bus window. it apparently then plunged off of a 100 foot cliff and burst into flames. the driver of the truck only had his pride injured and is currently seeking a 14 bolt axle to replace a weak design 10 bolt axle that his truck had installed. back to you Chet....."
have a spectacular day!!
Old 08-20-2012, 11:13 PM   #11 (permalink)
cr480r's Avatar
Member # 157418
Originally Posted by 92 s dime View Post
this
Actually a front housing WILL bend and/or snap quite easily... IF you jump it.. Otherwise dont bother with it. An under the axle truss really kills ground clearance, and going above the axle is a mess at best when leaf sprung
cr480r is offline   Reply With Quote Quick reply to this message
Old 08-20-2012, 11:21 PM   #12 (permalink)
Member # 167685
The idiocy is phenomenal on here. Congratulations, you've proven you know shit about axle components. PS. It is not being jumped, although Id prefer to strengthen its overall integrity.
Explain to me specifically what part of the axle, besides the housing, is so inferior?
Old 08-20-2012, 11:32 PM   #13 (permalink)
Beat95YJ's Avatar
Member # 22176
1541 material is essentially stock quality. Chromoly would have been a much better choice.
Well he's a PR genius like you're a Camarogenius
Beat95YJ is online now   Reply With Quote Quick reply to this message
Old 08-20-2012, 11:40 PM   #14 (permalink)
Jason4x4's Avatar
Member # 104033
http://www.artecindustries.com/Dana-...ss-_p_160.html
might be able to modify that?
Jason4x4 is offline   Reply With Quote Quick reply to this message
Old 08-21-2012, 04:53 AM   #15 (permalink)
Member # 167685
Found your post about how they "could be better or worse, depending on mfg".
Just ordered some Chromoly shafts to be sure of it.
Originally Posted by Jason4x4 View Post
Possibly, was looking to run it out to the leaf perches but I may be able to stem off of that.
Old 08-21-2012, 08:01 AM   #16 (permalink)
Member # 139150
really, cause i didn't go down this road. do whatever you want it's your truck. for the money your talking you could have gotten a 14 bolt, put a detroit in it and upgraded the rear brakes to disk. at some point you'll realize like i did that you were wasting your money.
Old 08-21-2012, 08:30 AM   #17 (permalink)
Member # 167685
It's by no means a waste. There are local guys who say building a K10 is a waste because I could have gotten a K20/K30 with the "stronger" parts already on it. It's just preference.
Same when I had my jeeps, one had a D44, the other had a D30. I put a little money into the D30 and it held up fine with 36's at Rausch and various other locations.
Although I was forced to do a SAS on my Bronco, shitty scissor design is a joke.
Old 08-21-2012, 09:57 AM   #18 (permalink)
91extsas's Avatar
Member # 184697
imo its dumb to build a ten bolt. i and other people i know have broken ten bolts when they were open diff. i have maybe 400 bucks into my 60 and 14 bolt together. i didn't rebuild them but all brakes are new and everything is tight. and my 400 dollar axles are both going to be stronger in every way than your built ten bolts...
and for what is week on the axles. um....
the wheel bearing are very week. i broke (not wore out) 3 wheel bearings on my last 10 bolt. at the same tire ruining the spindal and hub. the ball joints are also week. and as everyone else mentioned the housing. there is nothing good about a ten bolt and they should be used for boat ankers
91 chevy extcab short shortbed, d60welded, 14ffwelded, 350, sm465, np208, 37 boggers for now
91extsas is offline   Reply With Quote Quick reply to this message
Old 08-21-2012, 10:03 AM   #19 (permalink)
Member # 185237
I blew up a 10 bolt going up a hill offroad. No bouncing, not difficult terrain, I wasn't stuck, it just went pop and exploded the spider gears. Then a few months later I sold a suburban to a guy and it had a 10 bolt rear in it. The road was iced over and he got stuck on a slippery part of the neighborhood while trying to leave. Just from spinning the tires he grenaded the spider gears as well.
10bolts aren't worth it
Sent from the road while ignoring traffic
kryptonitecb is offline   Reply With Quote Quick reply to this message
Old 08-21-2012, 10:04 AM   #20 (permalink)
Member # 167685
Appreciate the input, I have access to a 14 bolt. Might turn this into a short winter project.
Old 08-21-2012, 10:14 AM   #21 (permalink)
Member # 219344
the point isnt that it holds up wile ur at a lil run were u have ur trailer u want the ability to know that it will hold up wile ur 20 miles back in some place u cant get towed out of
ben h is offline   Reply With Quote Quick reply to this message
Old 08-21-2012, 10:49 AM   #22 (permalink)
Beat95YJ's Avatar
Member # 22176
What the fawk are you saying? Learn grammar and punctuation.
Old 08-21-2012, 10:56 AM   #23 (permalink)
fcfred's Avatar
Member # 3263
ha ha ha ha
here frank:
I bended my frunt 10 bolt ascle, and stil drived it home. axel shaftz dinded braik. I jumpsted it reel good.
not a tottlly crappy ascle
butts i agreez, i'm nots gunna keap tenz-boltz, gunnas gets me-a dana 60's frunt rear-end.....
Team Tank
Old 08-21-2012, 12:24 PM   #24 (permalink)
Beat95YJ's Avatar
Member # 22176
You were in Tn too long.
Old 08-21-2012, 04:16 PM   #25 (permalink)
Member # 139150
the reason they said to build a k-20 is that the frame is stronger by alot. but i'm sure you call bullshit on me again for that so........
